cgal-discuss - Re: [cgal-discuss] Periodic_3_triangulation example linking errors on MacOS 10.9 with Clang 5
  • To: "" <>
  • Subject: Re: [cgal-discuss] Periodic_3_triangulation example linking errors on MacOS 10.9 with Clang 5
  • Date: Fri, 15 Nov 2013 01:47:48 +0000
  • Accept-language: en-US
On Nov 14, 2013, at 3:34 AM, Laurent Rineau (CGAL/GeometryFactory)
wrote:
> My guess is that the CGAL libraries are linked, but for some reason are
> binary
> incompatible. Have you also compiled the CGAL libraries with the same
> compiler? Or do they come from something like "macports", or "brew"? Or did
> you compile them with a different version of the compiler (for example
> before
> you upgraded to Darwin 13)?
Laurent,
Thank you very much!
Yes, that was it.
I uninstalled CGAL and all of its dependencies (boost, gmp, mpfr), then
reinstalled:
http://pastebin.com/amRpjqRt
Now everything compiles.
I went back and built boost built c++11 support, and cgal with imaging,
lapack, and eigen3 support. Everything works fine now.
Thanks again!
> Laurent Rineau, PhD
> R&D Engineer at GeometryFactory http://www.geometryfactory.com/
> Release Manager of the CGAL Project http://www.cgal.org/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
