Re: [cgal-discuss] Periodic_3_triangulation example linking errors on MacOS 10.9 with Clang 5
- To:
- Subject: Re: [cgal-discuss] Periodic_3_triangulation example linking errors on MacOS 10.9 with Clang 5
- Date: Fri, 15 Nov 2013 16:31:20 +0800
unsubscribe
On Thu, Nov 14, 2013 at 5:36 AM, Adam Getchell <> wrote:
Hello all,
I’m looking to use Periodic_3_triangulation_3 for my research project:
I’ve just copied verbatim the example from:
However, compiling/linking generates lots of errors. Here’s my environment:
┌─[getchell][Hapkido][±][master ✓][~/CDT-plusplus]└─▪ clang -vApple LLVM version 5.0 (clang-500.2.79) (based on LLVM 3.3svn)Target: x86_64-apple-darwin13.0.0Thread model: posix
And here’s the results of running make:
My code using standard Delaunay triangulations runs fine:
But the code for tds.cpp generates a similar error:
Is there some incompatibility that was introduced with CGAL 4.3? tds.cpp compiled before fine.
Thanks,
Adam Getchell
- [cgal-discuss] Periodic_3_triangulation example linking errors on MacOS 10.9 with Clang 5, Adam Getchell, 11/13/2013
- Re: [cgal-discuss] Periodic_3_triangulation example linking errors on MacOS 10.9 with Clang 5, Laurent Rineau (CGAL/GeometryFactory), 11/14/2013
- Re: [cgal-discuss] Periodic_3_triangulation example linking errors on MacOS 10.9 with Clang 5, Adam Getchell, 11/15/2013
- Re: [cgal-discuss] Periodic_3_triangulation example linking errors on MacOS 10.9 with Clang 5, Sebastien Loriot (GeometryFactory), 11/15/2013
- Re: [cgal-discuss] Periodic_3_triangulation example linking errors on MacOS 10.9 with Clang 5, Hailong Yao, 11/15/2013
