cgal-discuss - Re: [cgal-discuss] Periodic_3_triangulation example linking errors on MacOS 10.9 with Clang 5
  • To:
  • Subject: Re: [cgal-discuss] Periodic_3_triangulation example linking errors on MacOS 10.9 with Clang 5
  • Date: Fri, 15 Nov 2013 06:58:47 +0100
On 11/15/2013 02:47 AM, Adam Getchell wrote:
On Nov 14, 2013, at 3:34 AM, Laurent Rineau (CGAL/GeometryFactory)
wrote:
My guess is that the CGAL libraries are linked, but for some reason are binary
incompatible. Have you also compiled the CGAL libraries with the same
compiler? Or do they come from something like "macports", or "brew"? Or did
you compile them with a different version of the compiler (for example before
you upgraded to Darwin 13)?
Laurent,
Thank you very much!
Yes, that was it.
I uninstalled CGAL and all of its dependencies (boost, gmp, mpfr), then
reinstalled:
http://pastebin.com/amRpjqRt
Now everything compiles.
I went back and built boost built c++11 support, and cgal with imaging,
lapack, and eigen3 support. Everything works fine now.
Note that if you have eigen3, lapack is not needed.
Sebastien.
Thanks again!
