- To:
- Subject: Re: [cgal-discuss] NN, change the splitting rule of the tree
- Date: Thu, 21 Nov 2013 07:03:47 -0800 (PST)
I cleared the code, in order to produce a minimal example that would work and
let someone augment it, in order to change the splitting rule.
I had understood from your previous mail, that the problem lies there, but I
do not know how to fix it. The manhattan distance is something I used with
no special reason, so I do not mind using the default one. In other words,
one can omit the two lines that have to do with manhattan distance and go
on, to produce a piece of code that would change the splitting rule. That is
the target! It's ok for me, if we change other definitions. :)
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/NN-change-the-splitting-rule-of-the-tree-tp4658440p4658448.html
- [cgal-discuss] NN, change the splitting rule of the tree, Samaras, 11/20/2013
- Re: [cgal-discuss] NN, change the splitting rule of the tree, Philipp Moeller, 11/20/2013
- Re: [cgal-discuss] NN, change the splitting rule of the tree, Samaras, 11/20/2013
- Re: [cgal-discuss] NN, change the splitting rule of the tree, Philipp Moeller, 11/21/2013
- Re: [cgal-discuss] NN, change the splitting rule of the tree, Samaras, 11/21/2013
