cgal-discuss - Re: [cgal-discuss] NN, change the splitting rule of the tree
  • To: Samaras <>
  • Cc:
  • Subject: Re: [cgal-discuss] NN, change the splitting rule of the tree
  • Date: Thu, 21 Nov 2013 16:27:19 +0100
Samaras
writes:
> I cleared the code, in order to produce a minimal example that would work
> and
> let someone augment it, in order to change the splitting rule.
> I had understood from your previous mail, that the problem lies there, but I
> do not know how to fix it. The manhattan distance is something I used with
> no special reason, so I do not mind using the default one. In other words,
> one can omit the two lines that have to do with manhattan distance and go
> on, to produce a piece of code that would change the splitting rule. That is
> the target! It's ok for me, if we change other definitions. :)
typedef Kernel TreeTraits;
// in your case the default distance is Euclidean_distance
typedef CGAL::Euclidean_distance<TreeTraits> Distance;
typedef CGAL::Midpoint_of_max_spread<TreeTraits> SplitRule;
typedef CGAL::K_neighbor_search<TreeTraits,
Distance,
SplitRule> Neighbor_search;
typedef Neighbor_search::Tree Tree;
