- To:
- Subject: Re: [cgal-discuss] Join polygons after using intersection and difference.
- Date: Thu, 5 Dec 2013 17:58:47 +0200
It looks as if you do not take the intersection points but the nearby points of the original polygon.
This does not look like impression; it looks more like a simple bug... ____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
_/
On Thu, Dec 5, 2013 at 5:51 PM, Belén <> wrote:
The problem appears in every polygon that is divided, the new vertex (where the lines intersect) doesn't exactly belong to the boundary, it seems to be a problem with type precision, but I can't find the mistake.
Here I've sent three photos with the problem.
The first one is how I divide a polygon in different parts (blue lines cut the polygon).
The second one is the result after joining them, here we can see the wrong lines.
And the third one has the order the vertex are considered and why those lines aren't right.
Hope it helps.
Thanks for your help.
Date: Thu, 5 Dec 2013 17:16:55 +0200
To:
Subject: Re: [cgal-discuss] Join polygons after using intersection and difference.Then, probably, you one or more of your polygons are invalid, as the message say.You must detect it, fix it, and only then use it as input.
____ _ ____ _
_/
On Thu, Dec 5, 2013 at 4:23 PM, Belén <> wrote:Those are my definitions:
#include <CGAL/Exact_predicates_exact_constructions_kernel.h>#include <CGAL/Boolean_set_operations_2.h>
typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;typedef Kernel::Point_2 Point_2;typedef CGAL::Polygon_2<Kernel> Polygon_2;typedef CGAL::Segment_2<Kernel> Segment_2;typedef CGAL::Polygon_with_holes_2<Kernel> Polygon_with_holes;typedef Polygon_2::Vertex_const_iterator vertex_iterator;typedef Polygon_with_holes::Hole_const_iterator hole_iterator;typedef std::list<Polygon_with_holes> Pwh_list;typedef Kernel::Ray_2 Ray_2;
I'm using the correct kernel, but maybe I'm doing something wrong when I define the new types.
Do you have any idea of what is wrong in my definitions??
Thanks in advance.
Regards.
Belén.
Date: Wed, 4 Dec 2013 19:10:18 +0200
To:
Subject: Re: [cgal-discuss] Join polygons after using intersection and difference.What kernel are you using?
From your message it seems that you are not using an exact-predicate-exact-construction-kernel, as prescribed in the manual.
You must use an exact-predicate-exact-construction-kernel!
____ _ ____ _
_/
On Wed, Dec 4, 2013 at 6:58 PM, <> wrote:Hi!!
I have a problem with my project. Y work with maps (shapefiles) and I need to
divide some polygons (I use intersection and difference to obtain the
different parts) and then, I join this parts separately to another polygons.
The problem is that this join doesn't work fine. First, when it calculates an
important number of polygons, an exception is thrown (the polygons aren't
valid). If I see the visual representation, the boundary of the result has
some lines that should be cut, but they aren't.
I've found that the new vertex in the intersection of the lines doesn't belong
to the boundary, it's very very near, but not exactly in the boundary, I think
it's why the join function doesn't work.
Does anybody know how could I fix that problem, please? I've tried adding the
intersection point to the polygon but the result was even worse.
I can put some photos about the problem if it helps.
I know it's very abstract but I don't know what can I do to solve this
problem.
Thanks a lot in advance.
Regards.
Belén.
Description: JPEG image
- [cgal-discuss] Join polygons after using intersection and difference., beln1, 12/04/2013
- Re: [cgal-discuss] Join polygons after using intersection and difference., Efi Fogel, 12/04/2013
- Re: [cgal-discuss] Join polygons after using intersection and difference., Rémi Cura, 12/04/2013
- RE: [cgal-discuss] Join polygons after using intersection and difference., Belén, 12/05/2013
- Re: [cgal-discuss] Join polygons after using intersection and difference., Efi Fogel, 12/05/2013
- Re: [cgal-discuss] Join polygons after using intersection and difference., Tapadi, 12/05/2013
- Re: [cgal-discuss] Join polygons after using intersection and difference., Efi Fogel, 12/06/2013
- RE: [cgal-discuss] Join polygons after using intersection and difference., Belén, 12/07/2013
