- To: "" <>
- Subject: RE: [cgal-discuss] Join polygons after using intersection and difference.
- Date: Thu, 5 Dec 2013 16:41:52 +0000
- Importance: Normal
Thanks a lot!!
This is a great idea! I think this might be the problem. I convert to smaller types between operations.
I'll try your solution!!
Regards and thanks again.
Belén.
Belén.
> Date: Thu, 5 Dec 2013 08:14:30 -0800
> From:
> To:
> Subject: Re: [cgal-discuss] Join polygons after using intersection and difference.
> Hi,
> Have you checked all conversions between inexact values (like double) and
> exact values (like CGAL::gmpq)?
> In particular, you should check that when you're importing inexact geometric
> data from files, you must convert them into exact representation and then
> only use this exact representation. Convert them back in inexact
> representation *only* for display / export purposes.
> I've already done this kind of mistake:
> My_inexact_structure a = import_from_file("...")
> CGAL::Exact_structure b = convert_to_exact(a)
> CGAL::Exact_structure c = CGAL::apply_some_algorithm(b)
> My_inexact_structure d = convert_to_inexact(c)
> display(d)
> CGAL::Exact_structure e = convert_to_exact(d) // Gives cgal assertion
> violation or some indesirable stuff
> I hope this advice to be helpful for solving your problem.
> Regards,
> Hugo Loi
> PhD student at Inria - Maverick team
> View this message in context: http://cgal-discuss.949826.n4.nabble.com/Join-polygons-after-using-intersection-and-difference-tp4658509p4658522.html
> Sent from the cgal-discuss mailing list archive at Nabble.com.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
> From:
> To:
> Hi,
> display(d)
> Regards,
> Hugo Loi
- [cgal-discuss] Join polygons after using intersection and difference., beln1, 12/04/2013
- Re: [cgal-discuss] Join polygons after using intersection and difference., Efi Fogel, 12/04/2013
- Re: [cgal-discuss] Join polygons after using intersection and difference., Rémi Cura, 12/04/2013
- RE: [cgal-discuss] Join polygons after using intersection and difference., Belén, 12/05/2013
- Re: [cgal-discuss] Join polygons after using intersection and difference., Efi Fogel, 12/05/2013
- Re: [cgal-discuss] Join polygons after using intersection and difference., Tapadi, 12/05/2013
- Re: [cgal-discuss] Join polygons after using intersection and difference., Efi Fogel, 12/06/2013
- RE: [cgal-discuss] Join polygons after using intersection and difference., Belén, 12/07/2013
