- To:
- Subject: Re: [cgal-discuss] Join polygons after using intersection and difference.
- Date: Thu, 5 Dec 2013 08:14:30 -0800 (PST)
Hi,
Have you checked all conversions between inexact values (like double) and
exact values (like CGAL::gmpq)?
In particular, you should check that when you're importing inexact geometric
data from files, you must convert them into exact representation and then
only use this exact representation. Convert them back in inexact
representation *only* for display / export purposes.
I've already done this kind of mistake:
My_inexact_structure a = import_from_file("...")
CGAL::Exact_structure b = convert_to_exact(a)
CGAL::Exact_structure c = CGAL::apply_some_algorithm(b)
My_inexact_structure d = convert_to_inexact(c)
display(d)
CGAL::Exact_structure e = convert_to_exact(d) // Gives cgal assertion
violation or some indesirable stuff
I hope this advice to be helpful for solving your problem.
Regards,
Hugo Loi
PhD student at Inria - Maverick team
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Join-polygons-after-using-intersection-and-difference-tp4658509p4658522.html
- [cgal-discuss] Join polygons after using intersection and difference., beln1, 12/04/2013
- Re: [cgal-discuss] Join polygons after using intersection and difference., Efi Fogel, 12/04/2013
- Re: [cgal-discuss] Join polygons after using intersection and difference., Rémi Cura, 12/04/2013
- RE: [cgal-discuss] Join polygons after using intersection and difference., Belén, 12/05/2013
- Re: [cgal-discuss] Join polygons after using intersection and difference., Efi Fogel, 12/05/2013
- Re: [cgal-discuss] Join polygons after using intersection and difference., Tapadi, 12/05/2013
- Re: [cgal-discuss] Join polygons after using intersection and difference., Efi Fogel, 12/06/2013
- RE: [cgal-discuss] Join polygons after using intersection and difference., Belén, 12/07/2013
