- To: Philipp Moeller <>,
- Subject: Re: [cgal-discuss] [AABB Tree] Custom triangle class
- Date: Mon, 9 Dec 2013 23:23:40 +0100
Thank you Philipp for your answer. I
agree with your slicing idea, but it appears that replacing my
Custom_Triangle_3 with the custom primitve as described in http://doc.cgal.org/latest/AABB_tree/AABB_tree_2AABB_custom_example_8cpp-example.html drops the same problem. Note that I use VS2010 64 + CGAL 4.2.
I am working on a minimal sample which reproduces the problem,
but have to write it from scratch with IO from my applications. Once
done, I will post it on the list with test data.2013/12/9 Philipp Moeller <>
This sounds a lot like slicing is happening somewhere (e.g. an object ofAsher Kamiraze <> writes:
> Hi all,
> I am currently facing a problem with AABB Tree. I have defined my own
> triangle class (because I need to store an integer for each triangle) :
> typedef CGAL::Simple_cartesian<double> Simple_Cartesian;
> typedef Simple_Cartesian::Triangle_3 Simple_Triangle_3;
> class CustomTriangle_3 : public Simple_Triangle_3
> public:
> Simple_Cartesian::Vector_3 _normal;
> Arr::Face_handle _handle; // is an int
> CustomTriangle_3(Simple_Point_3& a, Simple_Point_3& b, Simple_Point_3&
> c) : Simple_Triangle_3(a,b,c) { _handle = -1; _normal =
> CGAL::unit_normal(a,b,c); }
> CustomTriangle_3() : Simple_Triangle_3() { _handle = -1; }
> I then build a std::list of CustomTriangle_3 and insert them in an AABB
> tree:
> typedef std::list<CustomTriangle_3>::iterator Iterator;
> typedef CGAL::AABB_triangle_primitive<Simple_Cartesian,Iterator>
> TrianglePrimitive;
> typedef CGAL::AABB_traits<Simple_Cartesian, TrianglePrimitive>
> AABB_triangle_traits;
> typedef CGAL::AABB_tree<AABB_triangle_traits> Tree;
> typedef Tree::Object_and_primitive_id
> Object_and_primitive_id;
> typedef Tree::Point_and_primitive_id
> Point_and_primitive_id;
> typedef Tree::Primitive_id
> Primitive_id;
> std::list<CustomTriangle_3> triangles;
> // some code to build CustomTriangle_3
> _tree.insert(triangles.begin(),triangles.end());
> _tree.build();
> _tree.accelerate_distance_queries();
> _tree is a class member of type Tree.
> For each created triangle, I set its _handle member to a valid value (a
> positive integer).
> Later, in an other method, I query the _tree:
> if ( _tree.do_intersect(query) )
> std::vector<Primitive_id> intersectedPrimitives;
> _tree.all_intersected_primitives(query,
> std::back_inserter(intersectedPrimitives));
> //for(std::vector<Primitive_id>::iterator
> it=intersectedPrimitives.begin();it!=intersectedPrimitives.end();++it)
> for(unsigned int gh=0;gh<intersectedPrimitives.size();++gh)
> _facetsToPoints[intersectedPrimitives[gh]->_handle].push_back(
> _points[i][j] );
> //_facetsToPoints[(*it)->_handle].push_back(
> _points[i][j] );
> This is where the problem occurs: when I try to access
> intersectedPrimitives[gh]->_handle, I get an inconsistent handle. If I run
> the program in debug mode, I got an assertion:
> _expression_: list iterator not dereferencable
> At the first all_intersected_primitves query, intersectedPrimitives
> contains 3 elements, all inconsistent (bad _handle and normal). I am
> wondering what I am doing wrong, and hope you could help tracking the
> problem.
type A is constructed from an object of type B which inherits of A and
all the extra information of B is lost). Could you check how the object
is constructed and maybe attach a complete, minimal test-case to
reproduce the issue?
- [cgal-discuss] [AABB Tree] Custom triangle class, Asher Kamiraze, 12/06/2013
- Re: [cgal-discuss] [AABB Tree] Custom triangle class, Philipp Moeller, 12/09/2013
- Message not available
- Re: [cgal-discuss] [AABB Tree] Custom triangle class, Asher Kamiraze, 12/09/2013
- Re: [cgal-discuss] [AABB Tree] Custom triangle class, Philipp Moeller, 12/10/2013
- Re: [cgal-discuss] [AABB Tree] Custom triangle class, Asher Kamiraze, 12/11/2013
- Re: [cgal-discuss] [AABB Tree] Custom triangle class, Asher Kamiraze, 12/12/2013
- Re: [cgal-discuss] [AABB Tree] Custom triangle class, Philipp Moeller, 12/12/2013
- Re: [cgal-discuss] [AABB Tree] Custom triangle class, Asher Kamiraze, 12/14/2013
- Re: [cgal-discuss] [AABB Tree] Custom triangle class, Sebastien Loriot (GeometryFactory), 12/18/2013
