- To: Philipp Moeller <>
- Cc: ,
- Subject: Re: [cgal-discuss] [AABB Tree] Custom triangle class
- Date: Thu, 12 Dec 2013 13:46:59 +0100
They are in my previous email from 11 december, 12:41. Can send them again but do not want to overload the list. Let me know.
Asher
2013/12/12 Philipp Moeller <>
> I finally managed to have a minimal test case which reproduces the problem.It seems that there is a file missing. Could you please attach
> It is attached as a new main cpp file. As you will see, the problem arises
> when I build the AABB tree from triangles in a method, then try to query it
> in another method. If I build the AABB tree and query it in the same
> method, the problem does not appear, although the code is strictly the same.
> Sorry for the ugly code, but please consider it as a one shot test case to
> reproduce the problem. Just pass on the commad line the full path to
> triangles.txt and queries.txt
"AABBTreeTestTypes.hpp" as well as triangles.txt and queries.txt?
>>> - in my code, AABBTree tree and std::map<...,...> facetsToQuery are
> Hope you could help.
> Regards,
> Asher
> 2013/12/11 Asher Kamiraze <>
>> Sorry,
>> I reduced the files size to not exceed the ML limit.
>> Regards,
>> Asher
>>> Philipp,
>>> Here is a minimal sample which does NOT reproduces the problem. This is
>>> nearly a copy / paste of some parts of my original code. The only
>>> difference are:
>>> class members
>>> - in my code, std::map< Face_handle, std::vector<Simple_Segment_3> >
>>> facetsToQuery; is defined as std::map< Face_handle,
>>> std::vector<Simple_Point_3> > facetsToPoints; and the segment query in the
>>> attached sample is build from Simple_Point_3
>>> Attached archive contains triangles and queries from a real case which
>>> causes a problem in my application.
>>> So, if you have any hint on why the attached code works and my not, I am
>>> really interested :)
>>> Regards,
>>> Asher
>>> 2013/12/10 Philipp Moeller <>
>>>> Asher Kamiraze <> writes:
>>>> > Thank you Philipp for your answer. I agree with your slicing idea, but
>>>> it
>>>> > appears that replacing my Custom_Triangle_3 with the custom primitve as
>>>> > described in
>>>> http://doc.cgal.org/latest/AABB_tree/AABB_tree_2AABB_custom_example_8cpp-example.htmldrops
>>>> > the same problem. Note that I use VS2010 64 + CGAL 4.2.
>>>> By "the same problem" you mean that extra data in My_triangle is not
>>>> properly preserved? That sounds very much like it shouldn't happen. I
>>>> can have a look at it this week to see what is going on.
>>>> > I am working on a minimal sample which reproduces the problem, but
>>>> have to
>>>> > write it from scratch with IO from my applications. Once done, I will
>>>> post
>>>> > it on the list with test data.
>>>> > You also suggest me to check how the object is constructed. Should I
>>>> track
>>>> > in debug its insertion in the AABB tree to see what exactly happen?
>>>> > Best regards,
>>>> > Asher K
>>>> >> 2013/12/9 Philipp Moeller <>
>>>> >>> > Hi all,
>>>> >>> > I am currently facing a problem with AABB Tree. I have defined my
>>>> own
>>>> >>> > triangle class (because I need to store an integer for each
>>>> triangle) :
>>>> >>> > typedef CGAL::Simple_cartesian<double> Simple_Cartesian;
>>>> >>> > typedef Simple_Cartesian::Triangle_3 Simple_Triangle_3;
>>>> >>> > class CustomTriangle_3 : public Simple_Triangle_3
>>>> >>> > public:
>>>> >>> > Simple_Cartesian::Vector_3 _normal;
>>>> >>> > Arr::Face_handle _handle; // is an int
>>>> >>> > CustomTriangle_3(Simple_Point_3& a, Simple_Point_3& b,
>>>> >>> Simple_Point_3&
>>>> >>> > c) : Simple_Triangle_3(a,b,c) { _handle = -1; _normal =
>>>> >>> > CGAL::unit_normal(a,b,c); }
>>>> >>> > CustomTriangle_3() : Simple_Triangle_3() { _handle = -1; }
>>>> >>> > I then build a std::list of CustomTriangle_3 and insert them in an
>>>> AABB
>>>> >>> > tree:
>>>> >>> > typedef std::list<CustomTriangle_3>::iterator
>>>> Iterator;
>>>> >>> > typedef CGAL::AABB_triangle_primitive<Simple_Cartesian,Iterator>
>>>> >>> > TrianglePrimitive;
>>>> >>> > typedef CGAL::AABB_traits<Simple_Cartesian, TrianglePrimitive>
>>>> >>> > AABB_triangle_traits;
>>>> >>> > typedef CGAL::AABB_tree<AABB_triangle_traits>
>>>> Tree;
>>>> >>> > typedef Tree::Object_and_primitive_id
>>>> >>> > Object_and_primitive_id;
>>>> >>> > typedef Tree::Point_and_primitive_id
>>>> >>> > Point_and_primitive_id;
>>>> >>> > typedef Tree::Primitive_id
>>>> >>> > Primitive_id;
>>>> >>> > std::list<CustomTriangle_3> triangles;
>>>> >>> > // some code to build CustomTriangle_3
>>>> >>> > _tree.insert(triangles.begin(),triangles.end());
>>>> >>> > _tree.build();
>>>> >>> > _tree.accelerate_distance_queries();
>>>> >>> > _tree is a class member of type Tree.
>>>> >>> > For each created triangle, I set its _handle member to a valid
>>>> value (a
>>>> >>> > positive integer).
>>>> >>> > Later, in an other method, I query the _tree:
>>>> >>> > if ( _tree.do_intersect(query) )
>>>> >>> > std::vector<Primitive_id> intersectedPrimitives;
>>>> >>> > _tree.all_intersected_primitives(query,
>>>> >>> > std::back_inserter(intersectedPrimitives));
>>>> >>> > //for(std::vector<Primitive_id>::iterator
>>>> it=intersectedPrimitives.begin();it!=intersectedPrimitives.end();++it)
>>>> >>> > for(unsigned int
>>>> >>> gh=0;gh<intersectedPrimitives.size();++gh)
>>>> >>> > _facetsToPoints[intersectedPrimitives[gh]->_handle].push_back(
>>>> >>> > _points[i][j] );
>>>> >>> > //_facetsToPoints[(*it)->_handle].push_back(
>>>> >>> > _points[i][j] );
>>>> >>> > This is where the problem occurs: when I try to access
>>>> >>> > intersectedPrimitives[gh]->_handle, I get an inconsistent handle.
>>>> If I
>>>> >>> run
>>>> >>> > the program in debug mode, I got an assertion:
>>>> >>> > _expression_: list iterator not dereferencable
>>>> >>> > At the first all_intersected_primitves query, intersectedPrimitives
>>>> >>> > contains 3 elements, all inconsistent (bad _handle and normal). I
>>>> am
>>>> >>> > wondering what I am doing wrong, and hope you could help tracking
>>>> the
>>>> >>> > problem.
>>>> >>> This sounds a lot like slicing is happening somewhere (e.g. an
>>>> object of
>>>> >>> type A is constructed from an object of type B which inherits of A
>>>> and
>>>> >>> all the extra information of B is lost). Could you check how the
>>>> object
>>>> >>> is constructed and maybe attach a complete, minimal test-case to
>>>> >>> reproduce the issue?
- [cgal-discuss] [AABB Tree] Custom triangle class, Asher Kamiraze, 12/06/2013
- Re: [cgal-discuss] [AABB Tree] Custom triangle class, Philipp Moeller, 12/09/2013
- Message not available
- Re: [cgal-discuss] [AABB Tree] Custom triangle class, Asher Kamiraze, 12/09/2013
- Re: [cgal-discuss] [AABB Tree] Custom triangle class, Philipp Moeller, 12/10/2013
- Re: [cgal-discuss] [AABB Tree] Custom triangle class, Asher Kamiraze, 12/11/2013
- Re: [cgal-discuss] [AABB Tree] Custom triangle class, Asher Kamiraze, 12/12/2013
- Re: [cgal-discuss] [AABB Tree] Custom triangle class, Philipp Moeller, 12/12/2013
- Re: [cgal-discuss] [AABB Tree] Custom triangle class, Asher Kamiraze, 12/14/2013
- Re: [cgal-discuss] [AABB Tree] Custom triangle class, Sebastien Loriot (GeometryFactory), 12/18/2013
