- To: Philipp Moeller <>
- Cc: ,
- Subject: Re: [cgal-discuss] [AABB Tree] Custom triangle class
- Date: Wed, 11 Dec 2013 12:26:47 +0100
Hi,
Debugging my app shows the following call stack when crashing:0 Polyhedral_complex_3::Arrangement_3<CGAL::Epeck, CGAL::Homogeneous_d<CGAL::Lazy_exact_nt<CGAL::Gmpq>, CGAL::Linear_algebraHd<CGAL::Lazy_exact_nt<CGAL::Gmpq>, std::allocator<CGAL::Lazy_exact_nt<CGAL::Gmpq> > > > >::Face_handle::Face_handle Arrangement_3.hpp 57 0x820fd64
1 std::pair<Polyhedral_complex_3::Arrangement_3<CGAL::Epeck, CGAL::Homogeneous_d<CGAL::Lazy_exact_nt<CGAL::Gmpq>, CGAL::Linear_algebraHd<CGAL::Lazy_exact_nt<CGAL::Gmpq>, std::allocator<CGAL::Lazy_exact_nt<CGAL::Gmpq> > > > >::Face_handle const, std::vector<CGAL::Point_3<CGAL::Simple_cartesian<double> >, std::allocator<CGAL::Point_3<CGAL::Simple_cartesian<double> > > > >::pair stl_pair.h 105 0x821c852
2 std::map<Polyhedral_complex_3::Arrangement_3<CGAL::Epeck, CGAL::Homogeneous_d<CGAL::Lazy_exact_nt<CGAL::Gmpq>, CGAL::Linear_algebraHd<CGAL::Lazy_exact_nt<CGAL::Gmpq>, std::allocator<CGAL::Lazy_exact_nt<CGAL::Gmpq> > > > >::Face_handle, std::vector<CGAL::Point_3<CGAL::Simple_cartesian<double> >, std::allocator<CGAL::Point_3<CGAL::Simple_cartesian<double> > > >, std::less<Polyhedral_complex_3::Arrangement_3<CGAL::Epeck, CGAL::Homogeneous_d<CGAL::Lazy_exact_nt<CGAL::Gmpq>, CGAL::Linear_algebraHd<CGAL::Lazy_exact_nt<CGAL::Gmpq>, std::allocator<CGAL::Lazy_exact_nt<CGAL::Gmpq> > > > >::Face_handle>, std::allocator<std::pair<Polyhedral_complex_3::Arrangement_3<CGAL::Epeck, CGAL::Homogeneous_d<CGAL::Lazy_exact_nt<CGAL::Gmpq>, CGAL::Linear_algebraHd<CGAL::Lazy_exact_nt<CGAL::Gmpq>, std::allocator<CGAL::Lazy_exact_nt<CGAL::Gmpq> > > > >::Face_handle const, std::vector<CGAL::Point_3<CGAL::Simple_cartesian<double> >, std::allocator<CGAL::Point_3<CGAL::Simple_cartesian<double> > > > > > >::operator[] stl_map.h 458 0x821c5fe
3 PlanesToPolyhedral<EnergyPolicyRandom>::buildFacetsToPointMapping PlanesToPolyhedral.inl 282 0x822539e
4 main PlanesToPolyhedral.cpp 133 0x821e464
typedef std::vector<CustomTriangle_3>::iterator Iterator;
typedef CGAL::AABB_triangle_primitive<Simple_Cartesian,Iterator> TrianglePrimitive;
typedef CGAL::AABB_traits<Simple_Cartesian, TrianglePrimitive> AABB_triangle_traits;
typedef CGAL::AABB_tree<AABB_triangle_traits> Tree;
typedef Tree::Object_and_primitive_id Object_and_primitive_id;
typedef Tree::Point_and_primitive_id Point_and_primitive_id;
typedef Tree::Primitive_id Primitive_id;
2013/12/11 Asher Kamiraze <>
Philipp,Here is a minimal sample which does NOT reproduces the problem. This is nearly a copy / paste of some parts of my original code. The only difference are:
- in my code, AABBTree tree and std::map<...,...> facetsToQuery are class members
- in my code, std::map< Face_handle, std::vector<Simple_Segment_3> > facetsToQuery; is defined as std::map< Face_handle, std::vector<Simple_Point_3> > facetsToPoints; and the segment query in the attached sample is build from Simple_Point_3
Attached archive contains triangles and queries from a real case which causes a problem in my application.
So, if you have any hint on why the attached code works and my not, I am really interested :)
Regards,
Asher
2013/12/10 Philipp Moeller <>
Asher Kamiraze <> writes:By "the same problem" you mean that extra data in My_triangle is not
> Thank you Philipp for your answer. I agree with your slicing idea, but it
> appears that replacing my Custom_Triangle_3 with the custom primitve as
> described in
> http://doc.cgal.org/latest/AABB_tree/AABB_tree_2AABB_custom_example_8cpp-example.htmldrops
> the same problem. Note that I use VS2010 64 + CGAL 4.2.
properly preserved? That sounds very much like it shouldn't happen. I
can have a look at it this week to see what is going on.
> I am working on a minimal sample which reproduces the problem, but have to
> write it from scratch with IO from my applications. Once done, I will post
> it on the list with test data.
> You also suggest me to check how the object is constructed. Should I track
> in debug its insertion in the AABB tree to see what exactly happen?
> Best regards,
> Asher K
>> 2013/12/9 Philipp Moeller <>
>>> > Hi all,
>>> > I am currently facing a problem with AABB Tree. I have defined my own
>>> > triangle class (because I need to store an integer for each triangle) :
>>> > typedef CGAL::Simple_cartesian<double> Simple_Cartesian;
>>> > typedef Simple_Cartesian::Triangle_3 Simple_Triangle_3;
>>> > class CustomTriangle_3 : public Simple_Triangle_3
>>> > public:
>>> > Simple_Cartesian::Vector_3 _normal;
>>> > Arr::Face_handle _handle; // is an int
>>> > CustomTriangle_3(Simple_Point_3& a, Simple_Point_3& b,
>>> Simple_Point_3&
>>> > c) : Simple_Triangle_3(a,b,c) { _handle = -1; _normal =
>>> > CGAL::unit_normal(a,b,c); }
>>> > CustomTriangle_3() : Simple_Triangle_3() { _handle = -1; }
>>> > I then build a std::list of CustomTriangle_3 and insert them in an AABB
>>> > tree:
>>> > typedef std::list<CustomTriangle_3>::iterator Iterator;
>>> > TrianglePrimitive;
>>> > Primitive_id;
>>> > std::list<CustomTriangle_3> triangles;
>>> > // some code to build CustomTriangle_3
>>> > _tree.insert(triangles.begin(),triangles.end());
>>> > _tree.build();
>>> > _tree.accelerate_distance_queries();
>>> > _tree is a class member of type Tree.
>>> > For each created triangle, I set its _handle member to a valid value (a
>>> > positive integer).
>>> > Later, in an other method, I query the _tree:
>>> > if ( _tree.do_intersect(query) )
>>> > std::vector<Primitive_id> intersectedPrimitives;
>>> > _tree.all_intersected_primitives(query,
>>> > std::back_inserter(intersectedPrimitives));
>>> > //for(std::vector<Primitive_id>::iterator
>>> > it=intersectedPrimitives.begin();it!=intersectedPrimitives.end();++it)
>>> > for(unsigned int
>>> gh=0;gh<intersectedPrimitives.size();++gh)
>>> > _facetsToPoints[intersectedPrimitives[gh]->_handle].push_back(
>>> > _points[i][j] );
>>> > //_facetsToPoints[(*it)->_handle].push_back(
>>> > _points[i][j] );
>>> > This is where the problem occurs: when I try to access
>>> > intersectedPrimitives[gh]->_handle, I get an inconsistent handle. If I
>>> run
>>> > the program in debug mode, I got an assertion:
>>> > _expression_: list iterator not dereferencable
>>> > At the first all_intersected_primitves query, intersectedPrimitives
>>> > contains 3 elements, all inconsistent (bad _handle and normal). I am
>>> > wondering what I am doing wrong, and hope you could help tracking the
>>> > problem.
>>> This sounds a lot like slicing is happening somewhere (e.g. an object of
>>> type A is constructed from an object of type B which inherits of A and
>>> all the extra information of B is lost). Could you check how the object
>>> is constructed and maybe attach a complete, minimal test-case to
>>> reproduce the issue?
Philipp Moeller
GeometryFactory
- [cgal-discuss] [AABB Tree] Custom triangle class, Asher Kamiraze, 12/06/2013
- Re: [cgal-discuss] [AABB Tree] Custom triangle class, Philipp Moeller, 12/09/2013
- Message not available
- Re: [cgal-discuss] [AABB Tree] Custom triangle class, Asher Kamiraze, 12/09/2013
- Re: [cgal-discuss] [AABB Tree] Custom triangle class, Philipp Moeller, 12/10/2013
- Re: [cgal-discuss] [AABB Tree] Custom triangle class, Asher Kamiraze, 12/11/2013
- Re: [cgal-discuss] [AABB Tree] Custom triangle class, Asher Kamiraze, 12/12/2013
- Re: [cgal-discuss] [AABB Tree] Custom triangle class, Philipp Moeller, 12/12/2013
- Re: [cgal-discuss] [AABB Tree] Custom triangle class, Asher Kamiraze, 12/14/2013
- Re: [cgal-discuss] [AABB Tree] Custom triangle class, Sebastien Loriot (GeometryFactory), 12/18/2013
