Re: [cgal-discuss] Assertion converting Polyhedron_3 to Nef_polyhedron_3 / Nef_polyhedron VERY slow with extended kernel
- To:
- Subject: Re: [cgal-discuss] Assertion converting Polyhedron_3 to Nef_polyhedron_3 / Nef_polyhedron VERY slow with extended kernel
- Date: Thu, 19 Dec 2013 14:28:07 +0100
- Organization: Fraunhofer ITWM
On 12/15/2013 07:30 PM, Marius Kintel wrote:
>> Is there a way to directly construct the Nef polyhedron without first
>> serializing to/from an OFF string?
> Hi Andre,
> Did you ever figure this out?
> I have a very similar issue..
> It looks like the OFF_to_nef_3() function manually projects all polygons
> into a 2D plane, performs a constrained triangulation before constructing
> the Nef from the triangles. Since this functionality is not specific to OFF
> files, it would make sense to have a more robust builder which could
> construct Nef polyhedrons from polygon meshes, including Polyhedron_3.
> Kind Regards,
> -Marius
Hi Marius,
sorry, but no, I did not look into this any further.
Best regards,
Andre
- Re: [cgal-discuss] Assertion converting Polyhedron_3 to Nef_polyhedron_3 / Nef_polyhedron VERY slow with extended kernel, Marius Kintel, 12/15/2013
- Re: [cgal-discuss] Assertion converting Polyhedron_3 to Nef_polyhedron_3 / Nef_polyhedron VERY slow with extended kernel, Andre Schmeisser, 12/19/2013
