cgal-discuss - [cgal-discuss] cannot find an arrangement
  • To:
  • Subject: [cgal-discuss] cannot find an arrangement
  • Date: Thu, 19 Dec 2013 04:50:00 -0800 (PST)
Hi,
I try to use Arrangement part of the code. It seems to work properly,
however, for the the following example it cannot find correct arrangement.
here are the data which I add to the CGAL
example/arrangement_on_surface/face_extenstion.cpp
Segment_2 s_1 (Point_2(1.5375, 0.83125), Point_2(1.575, 0.6625));
Segment_2 s_2 (Point_2(1.5375, 0.83125), Point_2(1.2875, 0.70625));
Segment_2 s_3 (Point_2(1.575, 0.6625), Point_2(1.2875, 0.70625));
Segment_2 s_4 (Point_2(1.43526, 0.780128), Point_2(1.45,0.73));
Segment_2 s_5 (Point_2(1.45,0.73), Point_2(1.47624, 0.677529));
Segment_2 s_6 (Point_2(1.30709, 0.716047), Point_2(1.3011, 0.70418));
the fist three segment are the coordinate of a triangle, and the rest are
the intersections with triangle boundaries.
below image show the position of the segments.
it worth to mention that all of the intersection also found by CGAL library.
<http://cgal-discuss.949826.n4.nabble.com/file/n4658571/drawing.png>
any help would be appreciated.
Thanks,
Hosein
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/cannot-find-an-arrangement-tp4658571.html
