Re: [cgal-discuss] want to use CGAL in Matlab, but can't compile mex file in matlab,
- To:
- Subject: Re: [cgal-discuss] want to use CGAL in Matlab, but can't compile mex file in matlab,
- Date: Sun, 12 Jan 2014 20:38:39 +0100 (CET)
On Sun, 12 Jan 2014,
wrote:
adnan.mujahid@
wrote:
/usr/bin/ld: /usr/local/MATLAB/R2012a/bin/glnxa64/libstdc++.so.6: version
`GLIBCXX_3.4.15' not found (required by /usr/bin/ld)
Try removing that file maybe?
Many thanks for your reply. I removed /usr/bin/ld using rm command. But got
the following error:
collect2: cannot find 'ld'
Any thoughts?
Aaaaaaaaaaaaaaaargh!
Sorry, I thought it was obvious I meant removing /usr/local/MATLAB/R2012a/bin/glnxa64/libstdc++.so.6, not ld. You may need to reinstall the binutils package of your distribution before continuing.
Marc Glisse
- Re: [cgal-discuss] want to use CGAL in Matlab, but can't compile mex file in matlab,, , 01/12/2014
- Re: [cgal-discuss] want to use CGAL in Matlab, but can't compile mex file in matlab,, Marc Glisse, 01/12/2014
