Re: [cgal-discuss] want to use CGAL in Matlab, but can't compile mex file in matlab,
- To:
- Subject: Re: [cgal-discuss] want to use CGAL in Matlab, but can't compile mex file in matlab,
- Date: Sun, 12 Jan 2014 12:46:29 -0800 (PST)
Marc Glisse wrote
> You need to add --reinstall somewhere in that line, probably between
> apt-get and install. Then check that the file /usr/bin/ld has reappeared.
> Marc Glisse
The following page is also suggesting the same method (as you are
suggesting), but unfortunately, I am not able to see ld file in /usr/bin/
directory (even though ldd, ld.bfd and ld.gold files do exist and I don't
know if they are related or not).
http://askubuntu.com/questions/86923/how-can-i-reinstall-binary-file-usr-bin-ld
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/want-to-use-CGAL-in-Matlab-but-can-t-compile-mex-file-in-matlab-tp3521519p4658632.html
- Re: [cgal-discuss] want to use CGAL in Matlab, but can't compile mex file in matlab,, , 01/12/2014
- Re: [cgal-discuss] want to use CGAL in Matlab, but can't compile mex file in matlab,, Marc Glisse, 01/12/2014
