Re: [cgal-discuss] want to use CGAL in Matlab, but can't compile mex file in matlab,
- To:
- Subject: Re: [cgal-discuss] want to use CGAL in Matlab, but can't compile mex file in matlab,
- Date: Sun, 12 Jan 2014 21:53:05 +0100 (CET)
On Sun, 12 Jan 2014,
wrote:
Marc Glisse wrote
You need to add --reinstall somewhere in that line, probably between
apt-get and install. Then check that the file /usr/bin/ld has reappeared.
The following page is also suggesting the same method (as you are
suggesting), but unfortunately, I am not able to see ld file in /usr/bin/
directory (even though ldd, ld.bfd and ld.gold files do exist and I don't
know if they are related or not).
http://askubuntu.com/questions/86923/how-can-i-reinstall-binary-file-usr-bin-ld
You probably mistyped something... An alternative, now I know you are using ubuntu:
sudo ln -s ld.bfd /usr/bin/ld
Marc Glisse
- Re: [cgal-discuss] want to use CGAL in Matlab, but can't compile mex file in matlab,, , 01/12/2014
- Re: [cgal-discuss] want to use CGAL in Matlab, but can't compile mex file in matlab,, Marc Glisse, 01/12/2014
