cgal-discuss - [cgal-discuss] how to use extreme points functions in convex hull 2D
  • To:
  • Subject: [cgal-discuss] how to use extreme points functions in convex hull 2D
  • Date: Thu, 16 Jan 2014 23:00:16 +0100
Hello,
I'm studying CGAL and C++ because I want to develop a piece of code that uses convex hull. I had some problem in the usage of functions with iterators (more or less everything in CGAL :-P )
to be more specific I defined a vector of CGAL::Point_2 called points_vect
then I want to call
CGAL::ch_e_point(points_vect.begin(), points_vect.end(), ??????? );
std::cout << "Extreme EST point = " << *(?????????) << std::endl;
what I need to define and to put as forwardIterator?
Regards
PS: for the andrew_graham_scan() applied to a set of points, if I use a std::back_inserter() of a vector for the output iterator, is it right?
CGAL::ch_graham_andrew_scan( points_vect.begin(), points_vect.end(), std::back_inserter(hull) );
