- To:
- Subject: Re: [cgal-discuss] how to use extreme points functions in convex hull 2D
- Date: Fri, 17 Jan 2014 23:37:24 +0100
Hi,
I believe solved my problem defining
std::vector<K::Point_2>::iterator est_point;
and so replacing it to my "????????"
About the andrew_graham_scan() what I understood it is that it returns what is described into the manual if the input is the convex hull polyline or a piece of them. At the beginning I was passing to the scan() function all set of points and the result was not that one I was expecting.
Is it right ?
Best
Alessandro
On 16 January 2014 23:00, Alessandro Attanasi <> wrote:
Hello,I'm studying CGAL and C++ because I want to develop a piece of code that uses convex hull. I had some problem in the usage of functions with iterators (more or less everything in CGAL :-P )to be more specific I defined a vector of CGAL::Point_2 called points_vectthen I want to callCGAL::ch_e_point(points_vect.begin(), points_vect.end(), ??????? );
std::cout << "Extreme EST point = " << *(?????????) << std::endl;
what I need to define and to put as forwardIterator?
Regards
PS: for the andrew_graham_scan() applied to a set of points, if I use a std::back_inserter() of a vector for the output iterator, is it right?
CGAL::ch_graham_andrew_scan( points_vect.begin(), points_vect.end(), std::back_inserter(hull) );
- [cgal-discuss] how to use extreme points functions in convex hull 2D, Alessandro Attanasi, 01/16/2014
- Re: [cgal-discuss] how to use extreme points functions in convex hull 2D, Alessandro Attanasi, 01/17/2014
