cgal-discuss - Re: [cgal-discuss] lower_hull_2() problem
  • To: Philipp Moeller <>
  • Cc:
  • Subject: Re: [cgal-discuss] lower_hull_2() problem
  • Date: Thu, 16 Jan 2014 21:23:21 +0100
Hi Philipp,
I understood the behaviour with the STL, I was wondering about C way usage of CGAL as the following , that is working fine even if I used malloc() and free() while for the function lower_hull_points_2() a similar approach doesn't work at all, I was expecting the same behaviour but I missing something.
thanks!
// definition of the input points
  K::Point_2 p1(2,5);
  K::Point_2 p2(0,4);
  K::Point_2 p3(0,0);
  K::Point_2 p4(4,0);
  K::Point_2 p5(4,4);
  K::Point_2 p6(1,3);
  K::Point_2 p7(1,1);
  K::Point_2 p8(3,1);
  K::Point_2 p9(3,3);
  K::Point_2 p10(2,2);
  int totPoints = 10;
 // array storing input points
  K::Point_2 *points = NULL;
  points = (K::Point_2*)malloc(totPoints * sizeof(K::Point_2));
  points[0] = p1;
  points[1] = p2;
  points[2] = p3;
  points[3] = p4;
  points[4] = p5;
  points[5] = p6;
  points[6] = p7;
  points[7] = p8;
  points[8] = p9;
  points[9] = p10;
  // array storing results
  K::Point_2 *result = NULL;
  result = (K::Point_2*)malloc(totPoints * sizeof(K::Point_2));
ptr = CGAL::ch_akl_toussaint( points, points+totPoints, result );
 // see how many points are into the convex hull
  int ch_points = (ptr - result);
  // print out the number of points of the convex hull and the points themselves
  std::cout << "1) Points on the convex hull = " << ch_points << std::endl;
  for(int i =0;i<ch_points;i++)
    std::cout << result[i] << std::endl;
 free(points);
  points = NULL;
  free(result);
  result = NULL;
On 15 January 2014 23:58, Philipp Moeller <> wrote:
Alessandro Attanasi <> writes:
> Ok, but why that procedure was working using all convex_hull
> functions?
It was working because you were using std::vector with a back_inserter
which takes care of those things. At least this is what your code
did. There can be situations where using a malloc'd pointer as an
OutputIterator can work (with a POD-type assignment effectively becomes
a memcpy, IIRC this is still undefined behavior though).
> I started from the cgal example
> http://doc.cgal.org/latest/Convex_hull_2/Convex_hull_2_2array_convex_hull_2_8cpp-example.html
> I freed the malloc at the end :)
Which is exactly the wrong thing to do because it won't call the
destructors of the elements.
> On 15 January 2014 23:31, Philipp Moeller <
>> > Sorry, really stupid error :P. It works as expected!
>> > Just last question about this problem: if I want to use C pointers
>> instead
>> > of stl iterators, why this code is wrong? It gives to me zero points on
>> the
>> > lower hull (I tried to use the same logic of the example for convex hull
>> > computation)
>> > K::Point_2 *ptr2;
>> >   K::Point_2 *result2 = NULL;
>> >   result2 = (K::Point_2*)malloc(totPoints * sizeof(K::Point_2));
>> >   ptr2 = CGAL::lower_hull_points_2( points, points+totPoints, result2 );
>> Why would you ever call malloc instead of new in such a situation? It is
>> exactly where your problem comes from. You cannot simply use raw
>> uninitialized memory as an OutputIterator. You should wrap the pointer
>> into a raw_storage_iterator provided by the standard header memory. [1]
>> You also need to take special care when releasing the memory (call the
>> destructor explicitly).
>> >   ch_points = (ptr2 - result2);
>> >   std::cout << "6) Points on the lower hull = " << ch_points <<
>> std::endl;
>> >     std::cout << result2[i] << std::endl;
>> Footnotes:
>> [1]  http://en.cppreference.com/w/cpp/memory/raw_storage_iterator
