- To:
- Subject: [cgal-discuss] Building a library that uses CGAL
- Date: Sun, 19 Jan 2014 06:50:01 -0800
Hi all,
I'm building a library that uses CGAL internally.
Unfortunately, I could only find instructions on how to build stand-alone applications, not libraries.
For stand-alone applications, I used cgal_create_cmake_script to generate the CMake environment.
Could you please tell me (or point me to a description of) how that should be done when building a library?
Thank you,
Mate Kovacs
Thank you,
Mate Kovacs
- [cgal-discuss] Building a library that uses CGAL, Máté Kovács, 01/19/2014
- Re: [cgal-discuss] Building a library that uses CGAL, Philipp Moeller, 01/19/2014
- Re: [cgal-discuss] Building a library that uses CGAL, Máté Kovács, 01/20/2014
