cgal-discuss - Re: [cgal-discuss] graham_andrew_scan() problem
  • To:
  • Subject: Re: [cgal-discuss] graham_andrew_scan() problem
  • Date: Sun, 19 Jan 2014 11:15:13 +0100
Alessandro,
What about reading the manual before USING something???
http://doc.cgal.org/latest/Convex_hull_2/group__PkgConvexHull2Subsequence.html#gafa026d25f9fee686e7a58af0ff365f86
andreas
On 18/01/2014 23:25, Alessandro Attanasi wrote:
Hi,
I'm not understanding the behaviour of the graham_andrew_scan()
what should I expect if I have the following points?
q7
q4
q1 q2 q3
q5
q6
q1 (-1,0)
q2 (0,0)
q3 (1,0)
q4 (2,1)
q5 (2,-1)
q6 (1.5,-2)
q7 (1.5,2)
I filled a std::vector<Point_2> scan_test with this points in the order
given by the numbers above, then I called
CGAL::graham_andrew_scan(scan_test.begin(),scan_test.end(),std::back_inserter(scan_result));
being std::vector<Point_2> scan_result.
And as result I obtained
q1,q3,q4 into scan_result. Why?
Thanks
Alessandro
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
