- To:
- Subject: Re: [cgal-discuss] graham_andrew_scan() problem
- Date: Sun, 19 Jan 2014 15:53:50 +0100
Hi all,
thanks for the replies, I read all the documentation on convex hull 2D before using it and to be specific to this problem the key sentence from the manual is:
"The function
ch_graham_andrew_scan()
generates the counterclockwise sequence of extreme points from a given set of input points that are not left of the line defined by the first and last points in this sequence."As I interpreted it, I first gave to the function the result of a previous convex hull computation obtaining what I was expecting, i.e. a subset of point of the input hull that are between the the two point p and q that I specified (this is in line with the Panos' reply for which input points has to be sorted). After that I asked myself what's happening if I feed the function with points belonging to a convex hull but they not define ccw polygon, or if more generally I feed the function with a generic set of points. The function returns to me something and I was asking myself if it was right.
Into the manual I read after the ch_graham_anderson() example the precondition
"The range [
first
,beyond
) contains at least two different points. The points in [first
,beyond
) are sorted with respect to pq, i.e. the sequence of points in [first
,beyond
) define a counterclockwise polygon, for which the Graham-Sklansky-procedure [11] works"that I was thinking was related only to the example, maybe not, it is general.
However, sorry if I was boring yourself with my questions, or worst if I was wasting your time. I'm going to learn the library and I have on one desktop the manual every time open, I really want to use it because I think it is really a valuable resource to implement computational geometry algorithms. If the mailing-list is devoted only to bug problems, ok I stop immediately myself to post other stuff, learning the library by myself doing mistakes and hoping to find the solution in some way.
As a software developer I know how difficult and time expansive is to write clear and accurate documentation, and your documentation is really good so for sure I interpreted it in a bad way, sorry again.
The reason for which I was playing with the function in that strange ways is that I used to stressed library functions in many ways in order to deep understand its behaviour, because before using an external library I would be sure to don't use it in an inappropriate way into a my software.
Best
Alessandro
On 19 January 2014 11:15, Andreas Fabri <> wrote:
Alessandro,
What about reading the manual before USING something???
http://doc.cgal.org/latest/Convex_hull_2/group__PkgConvexHull2Subsequence.html#gafa026d25f9fee686e7a58af0ff365f86
andreas--
On 18/01/2014 23:25, Alessandro Attanasi wrote:
Hi,
I'm not understanding the behaviour of the graham_andrew_scan()
what should I expect if I have the following points?
q7
q4
q1 q2 q3
q5
q6
q1 (-1,0)
q2 (0,0)
q3 (1,0)
q4 (2,1)
q5 (2,-1)
q6 (1.5,-2)
q7 (1.5,2)
I filled a std::vector<Point_2> scan_test with this points in the order
given by the numbers above, then I called
CGAL::graham_andrew_scan(scan_test.begin(),scan_test.end(),std::back_inserter(scan_result));
being std::vector<Point_2> scan_result.
And as result I obtained
q1,q3,q4 into scan_result. Why?
Thanks
Alessandro
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] graham_andrew_scan() problem, Alessandro Attanasi, 01/18/2014
- Re: [cgal-discuss] graham_andrew_scan() problem, Panagiotis Cheilaris, 01/19/2014
- Re: [cgal-discuss] graham_andrew_scan() problem, Andreas Fabri, 01/19/2014
- Re: [cgal-discuss] graham_andrew_scan() problem, Alessandro Attanasi, 01/19/2014
