- To:
- Subject: Re: [cgal-discuss] compilation error with jet_smooth_point
- Date: Thu, 23 Jan 2014 10:44:53 +0100
Thanks for fixing it!
Could you also attach the patch, then I can submit a bug report along with
the patch for debian package, please?
Thanks
Arnaud
On Jan 23, 2014, at 10:35 AM, "Sebastien Loriot (GeometryFactory)"
wrote:
> Indeed that was a bug not caught by our testsuite.
> I fixed the bug for the next release.
> Thanks for the report,
> Sebastien.
> On 01/22/2014 02:16 PM, Arnaud Gelas wrote:
>> #include <CGAL/jet_smooth_point_set.h>
>> void main()
>> If you just try to compile this example in the case where
>> CGAL_EIGEN3_ENABLED and CGAL_LAPACK_ENABLED, it won't compileā¦
>> Cause Monge_via_jet_fitting expect 3 template parameters but the typedef
>> in jet_smooth_point_set only provides one.
>> It seems to me that it has only been tested with eigen3, or lapack (?)
>> On Jan 22, 2014, at 1:57 PM, "Sebastien Loriot (GeometryFactory)"
>> wrote:
>>> Can you show a minimal example showing the pb?
>>> When those macros are defined, it activates some defaults for some
>>> template parameter. If they are not, then you need to specify
>>> them by end.
>>> Sebastien.
>>> On 01/22/2014 01:23 PM, Arnaud Gelas wrote:
>>>> Hi all,
>>>> I use debian testing packages for debian (i.e. 4.2.5), and I get an
>>>> obvious compilation error when using jet_smooth_point.
>>>> Indeed if CGAL_EIGEN3_ENABLED and CGAL_LACPACK_ENABLED are not defined,
>>>> Monge_via_jet_fitting requires 3 template arguments (there are no
>>>> default template arguments for LocalKernel and for SvdTraits), and in
>>>> jet_smooth_point only 1 template parameter is provided for
>>>> Monge_jet_fittingā¦
>>>> Has the code been fixed in latest release (4.2.3) ?
>>>> Thanks,
>>>> Arnaud
>>> You are currently subscribed to cgal-discuss.
>>> To unsubscribe or access the archives, go to
>>> https://sympa.inria.fr/sympa/info/cgal-discuss
- [cgal-discuss] compilation error with jet_smooth_point, Arnaud Gelas, 01/22/2014
- Re: [cgal-discuss] compilation error with jet_smooth_point, Sebastien Loriot (GeometryFactory), 01/22/2014
- Re: [cgal-discuss] compilation error with jet_smooth_point, Arnaud Gelas, 01/22/2014
- Re: [cgal-discuss] compilation error with jet_smooth_point, Sebastien Loriot (GeometryFactory), 01/23/2014
- Re: [cgal-discuss] compilation error with jet_smooth_point, Arnaud Gelas, 01/23/2014
