- To:
- Subject: Re: [cgal-discuss] build error when reconstruction surface without normals
- Date: Mon, 03 Feb 2014 07:54:15 +0100
Hi Vanessa,
Sorry about that, it's a bug in CGAL.
I attached the patched header file.
The fix will be in the next release of CGAL.
Sebastien.
On 02/02/2014 06:32 PM, vanessa wrote:
Hi all
I'm currently trying to reconstruct some meshes based on a xyz point set
without normals.
Managed to do it with normals_example and poisson_reconstruction_example,
but when I am trying to merge them together, the errors occur as follows:
1>c:\program files\cgal-4.2-beta1\include\cgal\kernel_traits.h(33): error
C2039: 'R' : is not a member of 'std::pair<_Ty1,_Ty2>'
1> with
1> [
1> _Ty1=Point,
1> _Ty2=Vector
1> ]
1> c:\program
files\cgal-4.2-beta1\include\cgal\poisson_reconstruction_function.h(304) :
see reference to class template instantiation 'CGAL::Kernel_traits<T>' being
compiled
1> with
1> [
1> T=std::pair<Point,Vector>
1> ]
1> f:\surfacewithoutnormal.cpp(88) : see reference to function
'CGAL::Poisson_reconstruction_function<Gt>::Poisson_reconstruction_function<std::_List_iterator<_Mylist>,CGAL::First_of_pair_property_map<Pair>,CGAL::Second_of_pair_property_map<Pair>>(InputIterator,InputIterator,PointPMap,NormalPMap)'
being compiled
1> with
1> [
1> Gt=Kernel,
1>
_Mylist=std::_List_val<PointVectorPair,std::allocator<PointVectorPair>>,
1> Pair=PointVectorPair,
1>
InputIterator=std::_List_iterator<std::_List_val<PointVectorPair,std::allocator<PointVectorPair>>>,
1> PointPMap=CGAL::First_of_pair_property_map<PointVectorPair>,
1>
NormalPMap=CGAL::Second_of_pair_property_map<PointVectorPair>
1> ]
C2146: syntax error : missing ';' before identifier 'Kernel'
C4430: missing type specifier - int assumed. Note: C++ does not support
default-int
C2208: 'CGAL::Exact_predicates_inexact_constructions_kernel' : no members
defined using this type
1>c:\program files\cgal-4.2-beta1\include\cgal\kernel_traits.h(33): fatal
error C1903: unable to recover from previous error(s); stopping compilation
1>
1>Build FAILED.
Here I use <Point, Vector> to represent the points with normals and use the
First_of_pair_property_map and Second_of_pair_property_map as the parameters
in the poisson function. Attached is the combined code.
I have no ideas about what is wrong.
Any help will be greated appreciated. surfacewithoutnormal.cpp
<http://cgal-discuss.949826.n4.nabble.com/file/n4658740/surfacewithoutnormal.cpp>
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/build-error-when-reconstruction-surface-without-normals-tp4658740.html
// Copyright (c) 2007-09 INRIA (France). // All rights reserved. // // This file is part of CGAL (www.cgal.org). // You can redistribute it and/or modify it under the terms of the GNU // General Public License as published by the Free Software Foundation, // either version 3 of the License, or (at your option) any later version. // // Licensees holding a valid commercial license may use this file in // accordance with the commercial license agreement provided with the software. // // This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE // WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. // // $URL$ // $Id$ // // Author(s) : Laurent Saboret, Pierre Alliez #ifndef CGAL_POISSON_RECONSTRUCTION_FUNCTION_H #define CGAL_POISSON_RECONSTRUCTION_FUNCTION_H #ifndef CGAL_DIV_NORMALIZED # ifndef CGAL_DIV_NON_NORMALIZED # define CGAL_DIV_NON_NORMALIZED 1 # endif #endif #include <vector> #include <deque> #include <algorithm> #include <cmath> #include <iterator> #include <CGAL/trace.h> #include <CGAL/Reconstruction_triangulation_3.h> #include <CGAL/spatial_sort.h> #ifdef CGAL_EIGEN3_ENABLED #include <CGAL/Eigen_solver_traits.h> #else #ifdef CGAL_TAUCS_ENABLED #include <CGAL/Taucs_solver_traits.h> #endif #endif #include <CGAL/centroid.h> #include <CGAL/property_map.h> #include <CGAL/surface_reconstruction_points_assertions.h> #include <CGAL/poisson_refine_triangulation.h> #include <CGAL/Robust_circumcenter_filtered_traits_3.h> #include <CGAL/compute_average_spacing.h> #include <CGAL/Timer.h> #include <boost/shared_ptr.hpp> #include <boost/array.hpp> #include <boost/type_traits/is_convertible.hpp> #include <boost/utility/enable_if.hpp> /*! \file Poisson_reconstruction_function.h */ namespace CGAL { namespace internal { template <class RT> bool invert( const RT& a0, const RT& a1, const RT& a2, const RT& a3, const RT& a4, const RT& a5, const RT& a6, const RT& a7, const RT& a8, RT& i0, RT& i1, RT& i2, RT& i3, RT& i4, RT& i5, RT& i6, RT& i7, RT& i8) { // Compute the adjoint. i0 = a4*a8 - a5*a7; i1 = a2*a7 - a1*a8; i2 = a1*a5 - a2*a4; i3 = a5*a6 - a3*a8; i4 = a0*a8 - a2*a6; i5 = a2*a3 - a0*a5; i6 = a3*a7 - a4*a6; i7 = a1*a6 - a0*a7; i8 = a0*a4 - a1*a3; RT det = a0*i0 + a1*i3 + a2*i6; if(det != 0) { RT idet = (RT(1.0))/det; i0 *= idet; i1 *= idet; i2 *= idet; i3 *= idet; i4 *= idet; i5 *= idet; i6 *= idet; i7 *= idet; i8 *= idet; return true; } return false; } } /// \cond SKIP_IN_MANUAL struct Poisson_visitor { void before_insertion() const {} }; struct Poisson_skip_vertices { double ratio; Random& m_random; Poisson_skip_vertices(const double ratio, Random& random) : ratio(ratio), m_random(random) {} template <typename Iterator> bool operator()(Iterator) const { return m_random.get_double() < ratio; } }; // Given f1 and f2, two sizing fields, that functor wrapper returns // max(f1, f2*f2) // The wrapper stores only pointers to the two functors. template <typename F1, typename F2> struct Special_wrapper_of_two_functions_keep_pointers { F1 *f1; F2 *f2; Special_wrapper_of_two_functions_keep_pointers(F1* f1, F2* f2) : f1(f1), f2(f2) {} template <typename X> double operator()(const X& x) const { return (std::max)((*f1)(x), CGAL::square((*f2)(x))); } template <typename X> double operator()(const X& x) { return (std::max)((*f1)(x), CGAL::square((*f2)(x))); } }; // end struct Special_wrapper_of_two_functions_keep_pointers<F1, F2> /// \endcond /*! \ingroup PkgSurfaceReconstructionFromPointSets \brief Implementation of the Poisson Surface Reconstruction method. Given a set of 3D points with oriented normals sampled on the boundary of a 3D solid, the Poisson Surface Reconstruction method \cgalCite{Kazhdan06} solves for an approximate indicator function of the inferred solid, whose gradient best matches the input normals. The output scalar function, represented in an adaptive octree, is then iso-contoured using an adaptive marching cubes. `Poisson_reconstruction_function` implements a variant of this algorithm which solves for a piecewise linear function on a 3D Delaunay triangulation instead of an adaptive octree. \tparam Gt Geometric traits class. \cgalModels `ImplicitFunction` */ template <class Gt> class Poisson_reconstruction_function { // Public types public: /// \name Types /// @{ typedef Gt Geom_traits; ///< Geometric traits class /// \cond SKIP_IN_MANUAL typedef Reconstruction_triangulation_3<Robust_circumcenter_filtered_traits_3<Gt> > Triangulation; /// \endcond typedef typename Triangulation::Cell_handle Cell_handle; // Geometric types typedef typename Geom_traits::FT FT; ///< number type. typedef typename Geom_traits::Point_3 Point; ///< point type. typedef typename Geom_traits::Vector_3 Vector; ///< vector type. typedef typename Geom_traits::Sphere_3 Sphere; /// @} // Private types private: // Internal 3D triangulation, of type Reconstruction_triangulation_3. // Note: poisson_refine_triangulation() requires a robust circumcenter computation. // Repeat Triangulation types typedef typename Triangulation::Triangulation_data_structure Triangulation_data_structure; typedef typename Geom_traits::Ray_3 Ray; typedef typename Geom_traits::Plane_3 Plane; typedef typename Geom_traits::Segment_3 Segment; typedef typename Geom_traits::Triangle_3 Triangle; typedef typename Geom_traits::Tetrahedron_3 Tetrahedron; typedef typename Triangulation::Vertex_handle Vertex_handle; typedef typename Triangulation::Cell Cell; typedef typename Triangulation::Vertex Vertex; typedef typename Triangulation::Facet Facet; typedef typename Triangulation::Edge Edge; typedef typename Triangulation::Cell_circulator Cell_circulator; typedef typename Triangulation::Facet_circulator Facet_circulator; typedef typename Triangulation::Cell_iterator Cell_iterator; typedef typename Triangulation::Facet_iterator Facet_iterator; typedef typename Triangulation::Edge_iterator Edge_iterator; typedef typename Triangulation::Vertex_iterator Vertex_iterator; typedef typename Triangulation::Point_iterator Point_iterator; typedef typename Triangulation::Finite_vertices_iterator Finite_vertices_iterator; typedef typename Triangulation::Finite_cells_iterator Finite_cells_iterator; typedef typename Triangulation::Finite_facets_iterator Finite_facets_iterator; typedef typename Triangulation::Finite_edges_iterator Finite_edges_iterator; typedef typename Triangulation::All_cells_iterator All_cells_iterator; typedef typename Triangulation::Locate_type Locate_type; // Data members. // Warning: the Surface Mesh Generation package makes copies of implicit functions, // thus this class must be lightweight and stateless. private: // operator() is pre-computed on vertices of *m_tr by solving // the Poisson equation Laplacian(f) = divergent(normals field). boost::shared_ptr<Triangulation> m_tr; mutable boost::shared_ptr<std::vector<boost::array<double,9> > > m_Bary; mutable std::vector<Point> Dual; mutable std::vector<Vector> Normal; // contouring and meshing Point m_sink; // Point with the minimum value of operator() mutable Cell_handle m_hint; // last cell found = hint for next search FT average_spacing; /// function to be used for the different constructors available that are /// doing the same thing but with default template parameters template <typename InputIterator, typename PointPMap, typename NormalPMap, typename Visitor > void forward_constructor( InputIterator first, InputIterator beyond, PointPMap point_pmap, NormalPMap normal_pmap, Visitor visitor) { CGAL::Timer task_timer; task_timer.start(); CGAL_TRACE_STREAM << "Creates Poisson triangulation...\n"; // Inserts points in triangulation m_tr->insert( first,beyond, point_pmap, normal_pmap, visitor); // Prints status CGAL_TRACE_STREAM << "Creates Poisson triangulation: " << task_timer.time() << " seconds, " << std::endl; } // Public methods public: /// \name Creation /// @{ /*! Creates a Poisson implicit function from the range of points `[first, beyond)`. \tparam InputIterator iterator over input points. \tparam PointPMap is a model of `ReadablePropertyMap` with a `value_type = Point`. It can be omitted if `InputIterator` `value_type` is convertible to `Point`. \tparam NormalPMap is a model of `ReadablePropertyMap` with a `value_type = Vector`. */ template <typename InputIterator, typename PointPMap, typename NormalPMap > Poisson_reconstruction_function( InputIterator first, ///< iterator over the first input point. InputIterator beyond, ///< past-the-end iterator over the input points. PointPMap point_pmap, ///< property map: `value_type of InputIterator` -> `Point` (the position of an input point). NormalPMap normal_pmap ///< property map: `value_type of InputIterator` -> `Vector` (the *oriented* normal of an input point). ) : m_tr(new Triangulation), m_Bary(new std::vector<boost::array<double,9> > ) , average_spacing(CGAL::compute_average_spacing(first, beyond, point_pmap, 6)) { forward_constructor(first, beyond, point_pmap, normal_pmap, Poisson_visitor()); } /// \cond SKIP_IN_MANUAL template <typename InputIterator, typename PointPMap, typename NormalPMap, typename Visitor > Poisson_reconstruction_function( InputIterator first, ///< iterator over the first input point. InputIterator beyond, ///< past-the-end iterator over the input points. PointPMap point_pmap, ///< property map: `value_type of InputIterator` -> `Point` (the position of an input point). NormalPMap normal_pmap, ///< property map: `value_type of InputIterator` -> `Vector` (the *oriented* normal of an input point). Visitor visitor) : m_tr(new Triangulation), m_Bary(new std::vector<boost::array<double,9> > ) , average_spacing(CGAL::compute_average_spacing(first, beyond, point_pmap, 6)) { forward_constructor(first, beyond, point_pmap, normal_pmap, visitor); } // This variant creates a default point property map = Identity_property_map and Visitor=Poisson_visitor template <typename InputIterator, typename NormalPMap > Poisson_reconstruction_function( InputIterator first, ///< iterator over the first input point. InputIterator beyond, ///< past-the-end iterator over the input points. NormalPMap normal_pmap, ///< property map: `value_type of InputIterator` -> `Vector` (the *oriented* normal of an input point). typename boost::enable_if< boost::is_convertible<typename InputIterator::value_type, Point> >::type* = 0 ) : m_tr(new Triangulation), m_Bary(new std::vector<boost::array<double,9> > ) , average_spacing(CGAL::compute_average_spacing(first, beyond, 6)) { forward_constructor(first, beyond, #ifdef CGAL_USE_PROPERTY_MAPS_API_V1 make_dereference_property_map(first), #else make_identity_property_map( typename std::iterator_traits<InputIterator>::value_type()), #endif normal_pmap, Poisson_visitor()); CGAL::Timer task_timer; task_timer.start(); } /// \endcond /// @} /// \name Operations /// @{ /// Returns a sphere bounding the inferred surface. Sphere bounding_sphere() const { return m_tr->bounding_sphere(); } /// \cond SKIP_IN_MANUAL const Triangulation& tr() const { return *m_tr; } // This variant requires all parameters. template <class SparseLinearAlgebraTraits_d, class Visitor> bool compute_implicit_function( SparseLinearAlgebraTraits_d solver,// = SparseLinearAlgebraTraits_d(), Visitor visitor, double approximation_ratio = 0, double average_spacing_ratio = 5) { CGAL::Timer task_timer; task_timer.start(); CGAL_TRACE_STREAM << "Delaunay refinement...\n"; // Delaunay refinement const FT radius_edge_ratio_bound = 2.5; const unsigned int max_vertices = (unsigned int)1e7; // max 10M vertices const FT enlarge_ratio = 1.5; const FT radius = sqrt(bounding_sphere().squared_radius()); // get triangulation's radius const FT cell_radius_bound = radius/5.; // large internal::Poisson::Constant_sizing_field<Triangulation> sizing_field(CGAL::square(cell_radius_bound)); std::vector<int> NB; NB.push_back( delaunay_refinement(radius_edge_ratio_bound,sizing_field,max_vertices,enlarge_ratio)); while(m_tr->insert_fraction(visitor)){ NB.push_back( delaunay_refinement(radius_edge_ratio_bound,sizing_field,max_vertices,enlarge_ratio)); } if(approximation_ratio > 0. && approximation_ratio * std::distance(m_tr->input_points_begin(), m_tr->input_points_end()) > 20) { // Add a pass of Delaunay refinement. // // In that pass, the sizing field, of the refinement process of the // triangulation, is based on the result of a poisson function with a // sample of the input points. The ratio is 'approximation_ratio'. // // For optimization reasons, the cell criteria of the refinement // process uses two sizing fields: // // - the minimum of the square of 'coarse_poisson_function' and the // square of the constant field equal to 'average_spacing', // // - a second sizing field that is constant, and equal to: // // average_spacing*average_spacing_ratio // // If a given cell is smaller than the constant second sizing field, // then the cell is considered as small enough, and the first sizing // field, more costly, is not evaluated. typedef Filter_iterator<typename Triangulation::Input_point_iterator, Poisson_skip_vertices> Some_points_iterator; //make it deterministic Random random(0); Poisson_skip_vertices skip(1.-approximation_ratio,random); CGAL_TRACE_STREAM << "SPECIAL PASS that uses an approximation of the result (approximation ratio: " << approximation_ratio << ")" << std::endl; CGAL::Timer approximation_timer; approximation_timer.start(); CGAL::Timer sizing_field_timer; sizing_field_timer.start(); Poisson_reconstruction_function<Geom_traits> coarse_poisson_function(Some_points_iterator(m_tr->input_points_end(), skip, m_tr->input_points_begin()), Some_points_iterator(m_tr->input_points_end(), skip), Normal_of_point_with_normal_pmap<Geom_traits>() ); coarse_poisson_function.compute_implicit_function(solver, Poisson_visitor(), 0.); internal::Poisson::Constant_sizing_field<Triangulation> min_sizing_field(CGAL::square(average_spacing)); internal::Poisson::Constant_sizing_field<Triangulation> sizing_field_ok(CGAL::square(average_spacing*average_spacing_ratio)); Special_wrapper_of_two_functions_keep_pointers< internal::Poisson::Constant_sizing_field<Triangulation>, Poisson_reconstruction_function<Geom_traits> > sizing_field2(&min_sizing_field, &coarse_poisson_function); sizing_field_timer.stop(); std::cerr << "Construction time of the sizing field: " << sizing_field_timer.time() << " seconds" << std::endl; NB.push_back( delaunay_refinement(radius_edge_ratio_bound, sizing_field2, max_vertices, enlarge_ratio, sizing_field_ok) ); approximation_timer.stop(); CGAL_TRACE_STREAM << "SPECIAL PASS END (" << approximation_timer.time() << " seconds)" << std::endl; } // Prints status CGAL_TRACE_STREAM << "Delaunay refinement: " << "added "; for(std::size_t i = 0; i < NB.size()-1; i++){ CGAL_TRACE_STREAM << NB[i] << " + "; } CGAL_TRACE_STREAM << NB.back() << " Steiner points, " << task_timer.time() << " seconds, " << std::endl; task_timer.reset(); #ifdef CGAL_DIV_NON_NORMALIZED CGAL_TRACE_STREAM << "Solve Poisson equation with non-normalized divergence...\n"; #else CGAL_TRACE_STREAM << "Solve Poisson equation with normalized divergence...\n"; #endif // Computes the Poisson indicator function operator() // at each vertex of the triangulation. double lambda = 0.1; if ( ! solve_poisson(solver, lambda) ) { std::cerr << "Error: cannot solve Poisson equation" << std::endl; return false; } // Shift and orient operator() such that: // - operator() = 0 on the input points, // - operator() < 0 inside the surface. set_contouring_value(median_value_at_input_vertices()); // Prints status CGAL_TRACE_STREAM << "Solve Poisson equation: " << task_timer.time() << " seconds, " << std::endl; task_timer.reset(); return true; } /// \endcond /*! This function must be called after the insertion of oriented points. It computes the piecewise linear scalar function operator() by: applying Delaunay refinement, solving for operator() at each vertex of the triangulation with a sparse linear solver, and shifting and orienting operator() such that it is 0 at all input points and negative inside the inferred surface. \tparam SparseLinearAlgebraTraits_d Symmetric definite positive sparse linear solver. If \ref thirdpartyEigen "Eigen" 3.1 (or greater) is available and `CGAL_EIGEN3_ENABLED` is defined, an overload with \link Eigen_solver_traits <tt>Eigen_solver_traits<Eigen::ConjugateGradient<Eigen_sparse_symmetric_matrix<double>::EigenType> ></tt> \endlink as default solver is provided. \param solver sparse linear solver. \param smoother_hole_filling controls if the Delaunay refinement is done for the input points, or for an approximation of the surface obtained from a first pass of the algorithm on a sample of the points. \return `false` if the linear solver fails. */ template <class SparseLinearAlgebraTraits_d> bool compute_implicit_function(SparseLinearAlgebraTraits_d solver, bool smoother_hole_filling = false) { if (smoother_hole_filling) return compute_implicit_function<SparseLinearAlgebraTraits_d,Poisson_visitor>(solver,Poisson_visitor(),0.02,5); else return compute_implicit_function<SparseLinearAlgebraTraits_d,Poisson_visitor>(solver,Poisson_visitor()); } /// \cond SKIP_IN_MANUAL #ifdef CGAL_EIGEN3_ENABLED // This variant provides the default sparse linear traits class = Eigen_solver_traits. bool compute_implicit_function(bool smoother_hole_filling = false) { typedef Eigen_solver_traits<Eigen::ConjugateGradient<Eigen_sparse_symmetric_matrix<double>::EigenType> > Solver; return compute_implicit_function<Solver>(Solver(), smoother_hole_filling); } #else #ifdef CGAL_TAUCS_ENABLED // This variant provides the default sparse linear traits class = Taucs_symmetric_solver_traits. bool compute_implicit_function(bool smoother_hole_filling = false) { typedef Taucs_symmetric_solver_traits<double> Solver; return compute_implicit_function<Solver>(Solver(), smoother_hole_filling); } #endif #endif boost::tuple<FT, Cell_handle, bool> special_func(const Point& p) const { m_hint = m_tr->locate(p ,m_hint ); // no hint when we use hierarchy if(m_tr->is_infinite(m_hint)) { int i = m_hint->index(m_tr->infinite_vertex()); return boost::make_tuple(m_hint->vertex((i+1)&3)->f(), m_hint, true); } FT a,b,c,d; barycentric_coordinates(p,m_hint,a,b,c,d); return boost::make_tuple(a * m_hint->vertex(0)->f() + b * m_hint->vertex(1)->f() + c * m_hint->vertex(2)->f() + d * m_hint->vertex(3)->f(), m_hint, false); } /// \endcond /*! `ImplicitFunction` interface: evaluates the implicit function at a given 3D query point. The function `compute_implicit_function()` must be called before the first call to `operator()`. */ FT operator()(const Point& p) const { m_hint = m_tr->locate(p ,m_hint); if(m_tr->is_infinite(m_hint)) { int i = m_hint->index(m_tr->infinite_vertex()); return m_hint->vertex((i+1)&3)->f(); } FT a,b,c,d; barycentric_coordinates(p,m_hint,a,b,c,d); return a * m_hint->vertex(0)->f() + b * m_hint->vertex(1)->f() + c * m_hint->vertex(2)->f() + d * m_hint->vertex(3)->f(); } /// \cond SKIP_IN_MANUAL void initialize_cell_indices() { int i=0; for(Finite_cells_iterator fcit = m_tr->finite_cells_begin(); fcit != m_tr->finite_cells_end(); ++fcit){ fcit->info()= i++; } } void initialize_barycenters() const { m_Bary->resize(m_tr->number_of_cells()); for(std::size_t i=0; i< m_Bary->size();i++){ (*m_Bary)[i][0]=-1; } } void initialize_cell_normals() const { Normal.resize(m_tr->number_of_cells()); int i = 0; int N = 0; for(Finite_cells_iterator fcit = m_tr->finite_cells_begin(); fcit != m_tr->finite_cells_end(); ++fcit){ Normal[i] = cell_normal(fcit); if(Normal[i] == NULL_VECTOR){ N++; } ++i; } std::cerr << N << " out of " << i << " cells have NULL_VECTOR as normal" << std::endl; } void initialize_duals() const { Dual.resize(m_tr->number_of_cells()); int i = 0; for(Finite_cells_iterator fcit = m_tr->finite_cells_begin(); fcit != m_tr->finite_cells_end(); ++fcit){ Dual[i++] = m_tr->dual(fcit); } } void clear_duals() const { Dual.clear(); } void clear_normals() const { Normal.clear(); } void initialize_matrix_entry(Cell_handle ch) const { boost::array<double,9> & entry = (*m_Bary)[ch->info()]; const Point& pa = ch->vertex(0)->point(); const Point& pb = ch->vertex(1)->point(); const Point& pc = ch->vertex(2)->point(); const Point& pd = ch->vertex(3)->point(); Vector va = pa - pd; Vector vb = pb - pd; Vector vc = pc - pd; internal::invert(va.x(), va.y(), va.z(), vb.x(), vb.y(), vb.z(), vc.x(), vc.y(), vc.z(), entry[0],entry[1],entry[2],entry[3],entry[4],entry[5],entry[6],entry[7],entry[8]); } /// \endcond /// Returns a point located inside the inferred surface. Point get_inner_point() const { // Gets point / the implicit function is minimum return m_sink; } /// @} // Private methods: private: /// Delaunay refinement (break bad tetrahedra, where /// bad means badly shaped or too big). The normal of /// Steiner points is set to zero. /// Returns the number of vertices inserted. template <typename Sizing_field> unsigned int delaunay_refinement(FT radius_edge_ratio_bound, ///< radius edge ratio bound (ignored if zero) Sizing_field sizing_field, ///< cell radius bound (ignored if zero) unsigned int max_vertices, ///< number of vertices bound FT enlarge_ratio) ///< bounding box enlarge ratio { return delaunay_refinement(radius_edge_ratio_bound, sizing_field, max_vertices, enlarge_ratio, internal::Poisson::Constant_sizing_field<Triangulation>()); } template <typename Sizing_field, typename Second_sizing_field> unsigned int delaunay_refinement(FT radius_edge_ratio_bound, ///< radius edge ratio bound (ignored if zero) Sizing_field sizing_field, ///< cell radius bound (ignored if zero) unsigned int max_vertices, ///< number of vertices bound FT enlarge_ratio, ///< bounding box enlarge ratio Second_sizing_field second_sizing_field) { Sphere elarged_bsphere = enlarged_bounding_sphere(enlarge_ratio); unsigned int nb_vertices_added = poisson_refine_triangulation(*m_tr,radius_edge_ratio_bound,sizing_field,second_sizing_field,max_vertices,elarged_bsphere); return nb_vertices_added; } /// Poisson reconstruction. /// Returns false on error. /// /// @commentheading Template parameters: /// @param SparseLinearAlgebraTraits_d Symmetric definite positive sparse linear solver. template <class SparseLinearAlgebraTraits_d> bool solve_poisson( SparseLinearAlgebraTraits_d solver, ///< sparse linear solver double lambda) { CGAL_TRACE("Calls solve_poisson()\n"); double time_init = clock(); double duration_assembly = 0.0; double duration_solve = 0.0; initialize_cell_indices(); initialize_barycenters(); // get #variables constrain_one_vertex_on_convex_hull(); m_tr->index_unconstrained_vertices(); unsigned int nb_variables = static_cast<unsigned int>(m_tr->number_of_vertices()-1); CGAL_TRACE(" Number of variables: %ld\n", (long)(nb_variables)); // Assemble linear system A*X=B typename SparseLinearAlgebraTraits_d::Matrix A(nb_variables); // matrix is symmetric definite positive typename SparseLinearAlgebraTraits_d::Vector X(nb_variables), B(nb_variables); initialize_duals(); #ifndef CGAL_DIV_NON_NORMALIZED initialize_cell_normals(); #endif Finite_vertices_iterator v, e; for(v = m_tr->finite_vertices_begin(), e = m_tr->finite_vertices_end(); v != e; ++v) { if(!m_tr->is_constrained(v)) { #ifdef CGAL_DIV_NON_NORMALIZED B[v->index()] = div(v); // rhs -> divergent #else // not defined(CGAL_DIV_NORMALIZED) B[v->index()] = div_normalized(v); // rhs -> divergent #endif // not defined(CGAL_DIV_NORMALIZED) assemble_poisson_row<SparseLinearAlgebraTraits_d>(A,v,B,lambda); } } clear_duals(); clear_normals(); duration_assembly = (clock() - time_init)/CLOCKS_PER_SEC; CGAL_TRACE(" Creates matrix: done (%.2lf s)\n", duration_assembly); CGAL_TRACE(" Solve sparse linear system...\n"); // Solve "A*X = B". On success, solution is (1/D) * X. time_init = clock(); double D; if(!solver.linear_solver(A, B, X, D)) return false; CGAL_surface_reconstruction_points_assertion(D == 1.0); duration_solve = (clock() - time_init)/CLOCKS_PER_SEC; CGAL_TRACE(" Solve sparse linear system: done (%.2lf s)\n", duration_solve); // copy function's values to vertices unsigned int index = 0; for (v = m_tr->finite_vertices_begin(), e = m_tr->finite_vertices_end(); v!= e; ++v) if(!m_tr->is_constrained(v)) v->f() = X[index++]; CGAL_TRACE("End of solve_poisson()\n"); return true; } /// Shift and orient the implicit function such that: /// - the implicit function = 0 for points / f() = contouring_value, /// - the implicit function < 0 inside the surface. /// /// Returns the minimum value of the implicit function. FT set_contouring_value(FT contouring_value) { // median value set to 0.0 shift_f(-contouring_value); // check value on convex hull (should be positive) Vertex_handle v = any_vertex_on_convex_hull(); if(v->f() < 0.0) flip_f(); // Update m_sink FT sink_value = find_sink(); return sink_value; } /// Gets median value of the implicit function over input vertices. FT median_value_at_input_vertices() const { std::deque<FT> values; Finite_vertices_iterator v, e; for(v = m_tr->finite_vertices_begin(), e= m_tr->finite_vertices_end(); v != e; v++) if(v->type() == Triangulation::INPUT) values.push_back(v->f()); std::size_t size = values.size(); if(size == 0) { std::cerr << "Contouring: no input points\n"; return 0.0; } std::sort(values.begin(),values.end()); std::size_t index = size/2; // return values[size/2]; return 0.5 * (values[index] + values[index+1]); // avoids singular cases } void barycentric_coordinates(const Point& p, Cell_handle cell, FT& a, FT& b, FT& c, FT& d) const { // const Point& pa = cell->vertex(0)->point(); // const Point& pb = cell->vertex(1)->point(); // const Point& pc = cell->vertex(2)->point(); const Point& pd = cell->vertex(3)->point(); #if 1 //Vector va = pa - pd; //Vector vb = pb - pd; //Vector vc = pc - pd; Vector vp = p - pd; //FT i00, i01, i02, i10, i11, i12, i20, i21, i22; //internal::invert(va.x(), va.y(), va.z(), // vb.x(), vb.y(), vb.z(), // vc.x(), vc.y(), vc.z(), // i00, i01, i02, i10, i11, i12, i20, i21, i22); const boost::array<double,9> & i = (*m_Bary)[cell->info()]; if(i[0]==-1){ initialize_matrix_entry(cell); } // UsedBary[cell->info()] = true; a = i[0] * vp.x() + i[3] * vp.y() + i[6] * vp.z(); b = i[1] * vp.x() + i[4] * vp.y() + i[7] * vp.z(); c = i[2] * vp.x() + i[5] * vp.y() + i[8] * vp.z(); d = 1 - ( a + b + c); #else FT v = volume(pa,pb,pc,pd); a = std::fabs(volume(pb,pc,pd,p) / v); b = std::fabs(volume(pa,pc,pd,p) / v); c = std::fabs(volume(pb,pa,pd,p) / v); d = std::fabs(volume(pb,pc,pa,p) / v); std::cerr << "_________________________________\n"; std::cerr << aa << " " << bb << " " << cc << " " << dd << std::endl; std::cerr << a << " " << b << " " << c << " " << d << std::endl; #endif } FT find_sink() { m_sink = CGAL::ORIGIN; FT min_f = 1e38; Finite_vertices_iterator v, e; for(v = m_tr->finite_vertices_begin(), e= m_tr->finite_vertices_end(); v != e; v++) { if(v->f() < min_f) { m_sink = v->point(); min_f = v->f(); } } return min_f; } void shift_f(const FT shift) { Finite_vertices_iterator v, e; for(v = m_tr->finite_vertices_begin(), e = m_tr->finite_vertices_end(); v!= e; v++) v->f() += shift; } void flip_f() { Finite_vertices_iterator v, e; for(v = m_tr->finite_vertices_begin(), e = m_tr->finite_vertices_end(); v != e; v++) v->f() = -v->f(); } Vertex_handle any_vertex_on_convex_hull() { Cell_handle ch = m_tr->infinite_vertex()->cell(); return ch->vertex( (ch->index( m_tr->infinite_vertex())+1)%4); } void constrain_one_vertex_on_convex_hull(const FT value = 0.0) { Vertex_handle v = any_vertex_on_convex_hull(); m_tr->constrain(v); v->f() = value; } // TODO: Some entities are computed too often // - nn and area should not be computed for the face and its opposite face // // divergent FT div_normalized(Vertex_handle v) { std::vector<Cell_handle> cells; cells.reserve(32); m_tr->incident_cells(v,std::back_inserter(cells)); FT div = 0; typename std::vector<Cell_handle>::iterator it; for(it = cells.begin(); it != cells.end(); it++) { Cell_handle cell = *it; if(m_tr->is_infinite(cell)) continue; // compute average normal per cell Vector n = get_cell_normal(cell); // zero normal - no need to compute anything else if(n == CGAL::NULL_VECTOR) continue; // compute n' int index = cell->index(v); const Point& x = cell->vertex(index)->point(); const Point& a = cell->vertex((index+1)%4)->point(); const Point& b = cell->vertex((index+2)%4)->point(); const Point& c = cell->vertex((index+3)%4)->point(); Vector nn = (index%2==0) ? CGAL::cross_product(b-a,c-a) : CGAL::cross_product(c-a,b-a); nn = nn / std::sqrt(nn*nn); // normalize Vector p = a - x; Vector q = b - x; Vector r = c - x; FT p_n = std::sqrt(p*p); FT q_n = std::sqrt(q*q); FT r_n = std::sqrt(r*r); FT solid_angle = p*(CGAL::cross_product(q,r)); solid_angle = std::abs(solid_angle / (p_n*q_n*r_n + (p*q)*r_n + (q*r)*p_n + (r*p)*q_n)); FT area = std::sqrt(squared_area(a,b,c)); FT length = p_n + q_n + r_n; div += n * nn * area / length ; } return div * FT(3.0); } FT div(Vertex_handle v) { std::vector<Cell_handle> cells; cells.reserve(32); m_tr->incident_cells(v,std::back_inserter(cells)); FT div = 0.0; typename std::vector<Cell_handle>::iterator it; for(it = cells.begin(); it != cells.end(); it++) { Cell_handle cell = *it; if(m_tr->is_infinite(cell)) continue; const int index = cell->index(v); const Point& a = cell->vertex(m_tr->vertex_triple_index(index, 0))->point(); const Point& b = cell->vertex(m_tr->vertex_triple_index(index, 1))->point(); const Point& c = cell->vertex(m_tr->vertex_triple_index(index, 2))->point(); const Vector nn = CGAL::cross_product(b-a,c-a); div+= nn * (//v->normal() + cell->vertex((index+1)%4)->normal() + cell->vertex((index+2)%4)->normal() + cell->vertex((index+3)%4)->normal()); } return div; } Vector get_cell_normal(Cell_handle cell) { return Normal[cell->info()]; } Vector cell_normal(Cell_handle cell) const { const Vector& n0 = cell->vertex(0)->normal(); const Vector& n1 = cell->vertex(1)->normal(); const Vector& n2 = cell->vertex(2)->normal(); const Vector& n3 = cell->vertex(3)->normal(); Vector n = n0 + n1 + n2 + n3; if(n != NULL_VECTOR){ FT sq_norm = n*n; if(sq_norm != 0.0){ return n / std::sqrt(sq_norm); // normalize } } return NULL_VECTOR; } // cotan formula as area(voronoi face) / len(primal edge) FT cotan_geometric(Edge& edge) { Cell_handle cell = edge.first; Vertex_handle vi = cell->vertex(edge.second); Vertex_handle vj = cell->vertex(edge.third); // primal edge const Point& pi = vi->point(); const Point& pj = vj->point(); Vector primal = pj - pi; FT len_primal = std::sqrt(primal * primal); return area_voronoi_face(edge) / len_primal; } // spin around edge // return area(voronoi face) FT area_voronoi_face(Edge& edge) { // circulate around edge Cell_circulator circ = m_tr->incident_cells(edge); Cell_circulator done = circ; std::vector<Point> voronoi_points; voronoi_points.reserve(9); do { Cell_handle cell = circ; if(!m_tr->is_infinite(cell)) voronoi_points.push_back(Dual[cell->info()]); else // one infinite tet, switch to another calculation return area_voronoi_face_boundary(edge); circ++; } while(circ != done); if(voronoi_points.size() < 3) { CGAL_surface_reconstruction_points_assertion(false); return 0.0; } // sum up areas FT area = 0.0; const Point& a = voronoi_points[0]; std::size_t nb_triangles = voronoi_points.size() - 1; for(std::size_t i=1;i<nb_triangles;i++) { const Point& b = voronoi_points[i]; const Point& c = voronoi_points[i+1]; area += std::sqrt(squared_area(a,b,c)); } return area; } // approximate area when a cell is infinite FT area_voronoi_face_boundary(Edge& edge) { FT area = 0.0; Vertex_handle vi = edge.first->vertex(edge.second); Vertex_handle vj = edge.first->vertex(edge.third); const Point& pi = vi->point(); const Point& pj = vj->point(); Point m = CGAL::midpoint(pi,pj); // circulate around each incident cell Cell_circulator circ = m_tr->incident_cells(edge); Cell_circulator done = circ; do { Cell_handle cell = circ; if(!m_tr->is_infinite(cell)) { // circumcenter of cell Point c = Dual[cell->info()]; Tetrahedron tet = m_tr->tetrahedron(cell); int i = cell->index(vi); int j = cell->index(vj); int k = Triangulation_utils_3::next_around_edge(i,j); int l = Triangulation_utils_3::next_around_edge(j,i); Vertex_handle vk = cell->vertex(k); Vertex_handle vl = cell->vertex(l); const Point& pk = vk->point(); const Point& pl = vl->point(); // if circumcenter is outside tet // pick barycenter instead if(tet.has_on_unbounded_side(c)) { Point cell_points[4] = {pi,pj,pk,pl}; c = CGAL::centroid(cell_points, cell_points+4); } Point ck = CGAL::circumcenter(pi,pj,pk); Point cl = CGAL::circumcenter(pi,pj,pl); area += std::sqrt(squared_area(m,c,ck)); area += std::sqrt(squared_area(m,c,cl)); } circ++; } while(circ != done); return area; } /// Assemble vi's row of the linear system A*X=B /// /// @commentheading Template parameters: /// @param SparseLinearAlgebraTraits_d Symmetric definite positive sparse linear solver. template <class SparseLinearAlgebraTraits_d> void assemble_poisson_row(typename SparseLinearAlgebraTraits_d::Matrix& A, Vertex_handle vi, typename SparseLinearAlgebraTraits_d::Vector& B, double lambda) { // for each vertex vj neighbor of vi std::vector<Edge> edges; m_tr->incident_edges(vi,std::back_inserter(edges)); double diagonal = 0.0; for(typename std::vector<Edge>::iterator it = edges.begin(); it != edges.end(); it++) { Vertex_handle vj = it->first->vertex(it->third); if(vj == vi){ vj = it->first->vertex(it->second); } if(m_tr->is_infinite(vj)) continue; // get corresponding edge Edge edge( it->first, it->first->index(vi), it->first->index(vj)); if(vi->index() < vj->index()){ std::swap(edge.second, edge.third); } double cij = cotan_geometric(edge); if(m_tr->is_constrained(vj)){ if(! is_valid(vj->f())){ std::cerr << "vj->f() = " << vj->f() << " is not valid" << std::endl; } B[vi->index()] -= cij * vj->f(); // change rhs if(! is_valid( B[vi->index()])){ std::cerr << " B[vi->index()] = " << B[vi->index()] << " is not valid" << std::endl; } } else { if(! is_valid(cij)){ std::cerr << "cij = " << cij << " is not valid" << std::endl; } A.set_coef(vi->index(),vj->index(), -cij, true /*new*/); // off-diagonal coefficient } diagonal += cij; } // diagonal coefficient if (vi->type() == Triangulation::INPUT){ A.set_coef(vi->index(),vi->index(), diagonal + lambda, true /*new*/) ; } else{ A.set_coef(vi->index(),vi->index(), diagonal, true /*new*/); } } /// Computes enlarged geometric bounding sphere of the embedded triangulation. Sphere enlarged_bounding_sphere(FT ratio) const { Sphere bsphere = bounding_sphere(); // triangulation's bounding sphere return Sphere(bsphere.center(), bsphere.squared_radius() * ratio*ratio); } }; // end of Poisson_reconstruction_function } //namespace CGAL #endif // CGAL_POISSON_RECONSTRUCTION_FUNCTION_H
- [cgal-discuss] build error when reconstruction surface without normals, vanessa, 02/02/2014
- Re: [cgal-discuss] build error when reconstruction surface without normals, Sebastien Loriot (GeometryFactory), 02/03/2014
- Re: [cgal-discuss] build error when reconstruction surface without normals, vanessa, 02/03/2014
