- To:
- Subject: Re: [cgal-discuss] build error when reconstruction surface without normals
- Date: Mon, 03 Feb 2014 14:04:49 +0100
My patch was over CGAL-4.3, the file attached should be OK with CGAL-4.2.
Sebastien.
On 02/03/2014 11:58 AM, vanessa wrote:
Hi Sebastien,<Kernel>>,CGAL::Triangulation_ds_vertex_base_3<CGAL::Triangulation_data_structure_3<CGAL::Reconstruction_vertex_base_3<CGAL::Reconstruction_triangulation_default_geom_traits_3<CGAL::Robust_circumcenter_filtered_traits_3<Kernel>>>,CGAL::Triangulation_cell_base_with_info_3<int,CGAL::Reconstruction_triangulation_default_geom_traits_3<CGAL::Robust_circumcenter_filtered_traits_3<Kernel>>>>>>>>>,
When I replaced the header file, a new error occurs:
c:\program
files\cgal-4.2-beta1\include\cgal\poisson_reconstruction_function.h(348):
error C3861: 'make_identity_property_map': identifier not found
1> c:\program
files\cgal-4.2-beta1\include\cgal\poisson_reconstruction_function.h(443) :
see reference to function template instantiation
'CGAL::Poisson_reconstruction_function<Gt>::Poisson_reconstruction_function<CGAL::Filter_iterator<I,P>,CGAL::Normal_of_point_with_normal_pmap<Gt>>(InputIterator,InputIterator,NormalPMap,void
*)' being compiled
1> with
1> [
1> Gt=Kernel,
1>
I=CGAL::Iterator_project<CGAL::Filter_iterator<CGAL::Triangulation_3<CGAL::Reconstruction_triangulation_default_geom_traits_3<CGAL::Robust_circumcenter_filtered_traits_3<Kernel>>,CGAL::Triangulation_data_structure_3<CGAL::Reconstruction_vertex_base_3<CGAL::Reconstruction_triangulation_default_geom_traits_3<CGAL::Robust_circumcenter_filtered_traits_3<Kernel>>>,CGAL::Triangulation_cell_base_with_info_3<int,CGAL::Reconstruction_triangulation_default_geom_traits_3<CGAL::Robust_circumcenter_filtered_traits_3<Kernel>>>>>::Finite_vertices_iterator,CGAL::Reconstruction_triangulation_3<CGAL::Robust_circumcenter_filtered_traits_3<Kernel>>::Is_steiner_point>,CGAL::Project_point<CGAL::Reconstruction_vertex_base_3<CGAL::Reconstruction_triangulation_default_geom_traits_3<CGAL::Robust_circumcenter_filtered_traits_3<Kernel>>,CGAL::Triangulation_vertex_base_3<CGAL::Reconstruction_triangulation_default_geom_traits_3<CGAL::Robust_circumcenter_filtered_traits_3
1> P=CGAL::Poisson_skip_vertices,Robust_circumcenter_filtered_traits_3<Kernel>>,CGAL::Triangulation_ds_vertex_base_3<CGAL::Triangulation_data_structure_3<CGAL::Reconstruction_vertex_base_3<CGAL::Reconstruction_triangulation_default_geom_traits_3<CGAL::Robust_circumcenter_filtered_traits_3<Kernel>>>,CGAL::Triangulation_cell_base_with_info_3<int,CGAL::Reconstruction_triangulation_default_geom_traits_3<CGAL::Robust_circumcenter_filtered_traits_3<Kernel>>>>>>>>>,CGAL::Poisson_skip_vertices>,
1>
InputIterator=CGAL::Filter_iterator<CGAL::Iterator_project<CGAL::Filter_iterator<CGAL::Triangulation_3<CGAL::Reconstruction_triangulation_default_geom_traits_3<CGAL::Robust_circumcenter_filtered_traits_3<Kernel>>,CGAL::Triangulation_data_structure_3<CGAL::Reconstruction_vertex_base_3<CGAL::Reconstruction_triangulation_default_geom_traits_3<CGAL::Robust_circumcenter_filtered_traits_3<Kernel>>>,CGAL::Triangulation_cell_base_with_info_3<int,CGAL::Reconstruction_triangulation_default_geom_traits_3<CGAL::Robust_circumcenter_filtered_traits_3<Kernel>>>>>::Finite_vertices_iterator,CGAL::Reconstruction_triangulation_3<CGAL::Robust_circumcenter_filtered_traits_3<Kernel>>::Is_steiner_point>,CGAL::Project_point<CGAL::Reconstruction_vertex_base_3<CGAL::Reconstruction_triangulation_default_geom_traits_3<CGAL::Robust_circumcenter_filtered_traits_3<Kernel>>,CGAL::Triangulation_vertex_base_3<CGAL::Reconstruction_triangulation_default_geom_traits_3<CGAL::
1>
NormalPMap=CGAL::Normal_of_point_with_normal_pmap<CGAL::Epick>
1> ]
1> c:\program
files\cgal-4.2-beta1\include\cgal\poisson_reconstruction_function.h(531) :
see reference to function template instantiation 'bool
CGAL::Poisson_reconstruction_function<Gt>::compute_implicit_function<SparseLinearAlgebraTraits_d,CGAL::Poisson_visitor>(SparseLinearAlgebraTraits_d,Visitor,double,double)'
being compiled
1> with
1> [
1> Gt=Kernel,
1> SparseLinearAlgebraTraits_d=Solver,
1> Visitor=CGAL::Poisson_visitor
1> ]
1> c:\program
files\cgal-4.2-beta1\include\cgal\poisson_reconstruction_function.h(542) :
CGAL::Poisson_reconstruction_function<Gt>::compute_implicit_function<Solver>(SparseLinearAlgebraTraits_d,bool)'
being compiled
1> with
1> [
1> Gt=Kernel,
1> ]
1> c:\program
files\cgal-4.2-beta1\include\cgal\poisson_reconstruction_function.h(540) :
while compiling class template member function 'bool
CGAL::Poisson_reconstruction_function<Gt>::compute_implicit_function(bool)'
1> with
1> [
1> Gt=Kernel
1> ]
1> f:\surfacewithoutnormal.cpp(88) : see reference to class
template instantiation 'CGAL::Poisson_reconstruction_function<Gt>' being
compiled
1> with
1> [
1> Gt=Kernel
1> ]
1>
1>Build FAILED.
Is it another bug?
I am new to CGAL, so maybe the answer is obvious.
Thanks for your help.
Zeya
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/build-error-when-reconstruction-surface-without-normals-tp4658740p4658750.html
// Copyright (c) 2007-09 INRIA (France). // All rights reserved. // // This file is part of CGAL (www.cgal.org). // You can redistribute it and/or modify it under the terms of the GNU // General Public License as published by the Free Software Foundation, // either version 3 of the License, or (at your option) any later version. // // Licensees holding a valid commercial license may use this file in // accordance with the commercial license agreement provided with the software. // // This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE // WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. // // $URL$ // $Id$ // // Author(s) : Laurent Saboret, Pierre Alliez #ifndef CGAL_POISSON_RECONSTRUCTION_FUNCTION_H #define CGAL_POISSON_RECONSTRUCTION_FUNCTION_H #ifndef CGAL_DIV_NORMALIZED # ifndef CGAL_DIV_NON_NORMALIZED # define CGAL_DIV_NON_NORMALIZED 1 # endif #endif #include <vector> #include <deque> #include <algorithm> #include <cmath> #include <CGAL/trace.h> #include <CGAL/Reconstruction_triangulation_3.h> #include <CGAL/spatial_sort.h> #ifdef CGAL_EIGEN3_ENABLED #include <CGAL/Eigen_solver_traits.h> #else #ifdef CGAL_TAUCS_ENABLED #include <CGAL/Taucs_solver_traits.h> #endif #endif #include <CGAL/centroid.h> #include <CGAL/property_map.h> #include <CGAL/surface_reconstruction_points_assertions.h> #include <CGAL/poisson_refine_triangulation.h> #include <CGAL/Robust_circumcenter_filtered_traits_3.h> #include <CGAL/compute_average_spacing.h> #include <boost/shared_ptr.hpp> #include <boost/array.hpp> #include <boost/type_traits/is_convertible.hpp> #include <boost/utility/enable_if.hpp> /*! \file Poisson_reconstruction_function.h */ namespace CGAL { namespace internal { template <class RT> bool invert( const RT& a0, const RT& a1, const RT& a2, const RT& a3, const RT& a4, const RT& a5, const RT& a6, const RT& a7, const RT& a8, RT& i0, RT& i1, RT& i2, RT& i3, RT& i4, RT& i5, RT& i6, RT& i7, RT& i8) { // Compute the adjoint. i0 = a4*a8 - a5*a7; i1 = a2*a7 - a1*a8; i2 = a1*a5 - a2*a4; i3 = a5*a6 - a3*a8; i4 = a0*a8 - a2*a6; i5 = a2*a3 - a0*a5; i6 = a3*a7 - a4*a6; i7 = a1*a6 - a0*a7; i8 = a0*a4 - a1*a3; RT det = a0*i0 + a1*i3 + a2*i6; if(det != 0) { RT idet = (RT(1.0))/det; i0 *= idet; i1 *= idet; i2 *= idet; i3 *= idet; i4 *= idet; i5 *= idet; i6 *= idet; i7 *= idet; i8 *= idet; return true; } return false; } } /// \cond SKIP_IN_MANUAL struct Poisson_visitor { void before_insertion() const {} }; struct Poisson_skip_vertices { double ratio; Random& m_random; Poisson_skip_vertices(const double ratio, Random& random) : ratio(ratio), m_random(random) {} template <typename Iterator> bool operator()(Iterator) const { return m_random.get_double() < ratio; } }; // Given f1 and f2, two sizing fields, that functor wrapper returns // max(f1, f2*f2) // The wrapper stores only pointers to the two functors. template <typename F1, typename F2> struct Special_wrapper_of_two_functions_keep_pointers { F1 *f1; F2 *f2; Special_wrapper_of_two_functions_keep_pointers(F1* f1, F2* f2) : f1(f1), f2(f2) {} template <typename X> double operator()(const X& x) const { return (std::max)((*f1)(x), CGAL::square((*f2)(x))); } template <typename X> double operator()(const X& x) { return (std::max)((*f1)(x), CGAL::square((*f2)(x))); } }; // end struct Special_wrapper_of_two_functions_keep_pointers<F1, F2> /// \endcond /*! \ingroup PkgSurfaceReconstructionFromPointSets \brief Implementation of the Poisson Surface Reconstruction method. Given a set of 3D points with oriented normals sampled on the boundary of a 3D solid, the Poisson Surface Reconstruction method \cite Kazhdan06 solves for an approximate indicator function of the inferred solid, whose gradient best matches the input normals. The output scalar function, represented in an adaptive octree, is then iso-contoured using an adaptive marching cubes. `Poisson_reconstruction_function` implements a variant of this algorithm which solves for a piecewise linear function on a 3D Delaunay triangulation instead of an adaptive octree. \tparam Gt Geometric traits class. \cgalModels `ImplicitFunction` */ template <class Gt> class Poisson_reconstruction_function { // Public types public: /// \name Types /// @{ typedef Gt Geom_traits; ///< Geometric traits class /// \cond SKIP_IN_MANUAL typedef Reconstruction_triangulation_3<Robust_circumcenter_filtered_traits_3<Gt> > Triangulation; /// \endcond typedef typename Triangulation::Cell_handle Cell_handle; // Geometric types typedef typename Geom_traits::FT FT; ///< number type. typedef typename Geom_traits::Point_3 Point; ///< point type. typedef typename Geom_traits::Vector_3 Vector; ///< vector type. typedef typename Geom_traits::Sphere_3 Sphere; /// @} // Private types private: // Internal 3D triangulation, of type Reconstruction_triangulation_3. // Note: poisson_refine_triangulation() requires a robust circumcenter computation. // Repeat Triangulation types typedef typename Triangulation::Triangulation_data_structure Triangulation_data_structure; typedef typename Geom_traits::Ray_3 Ray; typedef typename Geom_traits::Plane_3 Plane; typedef typename Geom_traits::Segment_3 Segment; typedef typename Geom_traits::Triangle_3 Triangle; typedef typename Geom_traits::Tetrahedron_3 Tetrahedron; typedef typename Triangulation::Vertex_handle Vertex_handle; typedef typename Triangulation::Cell Cell; typedef typename Triangulation::Vertex Vertex; typedef typename Triangulation::Facet Facet; typedef typename Triangulation::Edge Edge; typedef typename Triangulation::Cell_circulator Cell_circulator; typedef typename Triangulation::Facet_circulator Facet_circulator; typedef typename Triangulation::Cell_iterator Cell_iterator; typedef typename Triangulation::Facet_iterator Facet_iterator; typedef typename Triangulation::Edge_iterator Edge_iterator; typedef typename Triangulation::Vertex_iterator Vertex_iterator; typedef typename Triangulation::Point_iterator Point_iterator; typedef typename Triangulation::Finite_vertices_iterator Finite_vertices_iterator; typedef typename Triangulation::Finite_cells_iterator Finite_cells_iterator; typedef typename Triangulation::Finite_facets_iterator Finite_facets_iterator; typedef typename Triangulation::Finite_edges_iterator Finite_edges_iterator; typedef typename Triangulation::All_cells_iterator All_cells_iterator; typedef typename Triangulation::Locate_type Locate_type; // Data members. // Warning: the Surface Mesh Generation package makes copies of implicit functions, // thus this class must be lightweight and stateless. private: // operator() is pre-computed on vertices of *m_tr by solving // the Poisson equation Laplacian(f) = divergent(normals field). boost::shared_ptr<Triangulation> m_tr; mutable boost::shared_ptr<std::vector<boost::array<double,9> > > m_Bary; mutable std::vector<Point> Dual; mutable std::vector<Vector> Normal; // contouring and meshing Point m_sink; // Point with the minimum value of operator() mutable Cell_handle m_hint; // last cell found = hint for next search FT average_spacing; /// function to be used for the different constructors available that are /// doing the same thing but with default template parameters template <typename InputIterator, typename PointPMap, typename NormalPMap, typename Visitor > void forward_constructor( InputIterator first, InputIterator beyond, PointPMap point_pmap, NormalPMap normal_pmap, Visitor visitor) { CGAL::Timer task_timer; task_timer.start(); CGAL_TRACE_STREAM << "Creates Poisson triangulation...\n"; // Inserts points in triangulation m_tr->insert( first,beyond, point_pmap, normal_pmap, visitor); // Prints status CGAL_TRACE_STREAM << "Creates Poisson triangulation: " << task_timer.time() << " seconds, " << std::endl; } // Public methods public: /// \name Creation /// @{ /*! Creates a Poisson implicit function from the range of points `[first, beyond)`. \tparam InputIterator iterator over input points. \tparam PointPMap is a model of `ReadablePropertyMap` with a `value_type = Point`. It can be omitted if `InputIterator` `value_type` is convertible to `Point`. \tparam NormalPMap is a model of `ReadablePropertyMap` with a `value_type = Vector`. */ template <typename InputIterator, typename PointPMap, typename NormalPMap > Poisson_reconstruction_function( InputIterator first, ///< iterator over the first input point. InputIterator beyond, ///< past-the-end iterator over the input points. PointPMap point_pmap, ///< property map to access the position of an input point. NormalPMap normal_pmap ///< property map to access the *oriented* normal of an input point. ) : m_tr(new Triangulation), m_Bary(new std::vector<boost::array<double,9> > ) , average_spacing(CGAL::compute_average_spacing(first, beyond, point_pmap, 6)) { forward_constructor(first, beyond, point_pmap, normal_pmap, Poisson_visitor()); } /// \cond SKIP_IN_MANUAL template <typename InputIterator, typename PointPMap, typename NormalPMap, typename Visitor > Poisson_reconstruction_function( InputIterator first, ///< iterator over the first input point. InputIterator beyond, ///< past-the-end iterator over the input points. PointPMap point_pmap, ///< property map to access the position of an input point. NormalPMap normal_pmap, ///< property map to access the *oriented* normal of an input point. Visitor visitor) : m_tr(new Triangulation), m_Bary(new std::vector<boost::array<double,9> > ) , average_spacing(CGAL::compute_average_spacing(first, beyond, point_pmap, 6)) { forward_constructor(first, beyond, point_pmap, normal_pmap, visitor); } // This variant creates a default point property map = Dereference_property_map and Visitor=Poisson_visitor template <typename InputIterator, typename NormalPMap > Poisson_reconstruction_function( InputIterator first, ///< iterator over the first input point. InputIterator beyond, ///< past-the-end iterator over the input points. NormalPMap normal_pmap, ///< property map to access the *oriented* normal of an input point. typename boost::enable_if< boost::is_convertible<typename InputIterator::value_type, Point> >::type* = 0 ) : m_tr(new Triangulation), m_Bary(new std::vector<boost::array<double,9> > ) , average_spacing(CGAL::compute_average_spacing(first, beyond, 6)) { forward_constructor(first, beyond, make_dereference_property_map(first), normal_pmap, Poisson_visitor()); CGAL::Timer task_timer; task_timer.start(); } /// \endcond /// @} /// \name Operations /// @{ /// Returns a sphere bounding the inferred surface. Sphere bounding_sphere() const { return m_tr->bounding_sphere(); } /// \cond SKIP_IN_MANUAL const Triangulation& tr() const { return *m_tr; } // This variant requires all parameters. template <class SparseLinearAlgebraTraits_d, class Visitor> bool compute_implicit_function( SparseLinearAlgebraTraits_d solver,// = SparseLinearAlgebraTraits_d(), Visitor visitor, double approximation_ratio = 0, double average_spacing_ratio = 5) { CGAL::Timer task_timer; task_timer.start(); CGAL_TRACE_STREAM << "Delaunay refinement...\n"; // Delaunay refinement const FT radius_edge_ratio_bound = 2.5; const unsigned int max_vertices = (unsigned int)1e7; // max 10M vertices const FT enlarge_ratio = 1.5; const FT radius = sqrt(bounding_sphere().squared_radius()); // get triangulation's radius const FT cell_radius_bound = radius/5.; // large internal::Poisson::Constant_sizing_field<Triangulation> sizing_field(CGAL::square(cell_radius_bound)); std::vector<int> NB; NB.push_back( delaunay_refinement(radius_edge_ratio_bound,sizing_field,max_vertices,enlarge_ratio)); while(m_tr->insert_fraction(visitor)){ NB.push_back( delaunay_refinement(radius_edge_ratio_bound,sizing_field,max_vertices,enlarge_ratio)); } if(approximation_ratio > 0. && approximation_ratio * std::distance(m_tr->input_points_begin(), m_tr->input_points_end()) > 20) { // Add a pass of Delaunay refinement. // // In that pass, the sizing field, of the refinement process of the // triangulation, is based on the result of a poisson function with a // sample of the input points. The ratio is 'approximation_ratio'. // // For optimization reasons, the cell criteria of the refinement // process uses two sizing fields: // // - the minimum of the square of 'coarse_poisson_function' and the // square of the constant field equal to 'average_spacing', // // - a second sizing field that is constant, and equal to: // // average_spacing*average_spacing_ratio // // If a given cell is smaller than the constant second sizing field, // then the cell is considered as small enough, and the first sizing // field, more costly, is not evaluated. typedef Filter_iterator<typename Triangulation::Input_point_iterator, Poisson_skip_vertices> Some_points_iterator; //make it deterministic Random random(0); Poisson_skip_vertices skip(1.-approximation_ratio,random); CGAL_TRACE_STREAM << "SPECIAL PASS that uses an approximation of the result (approximation ratio: " << approximation_ratio << ")" << std::endl; CGAL::Timer approximation_timer; approximation_timer.start(); CGAL::Timer sizing_field_timer; sizing_field_timer.start(); Poisson_reconstruction_function<Geom_traits> coarse_poisson_function(Some_points_iterator(m_tr->input_points_end(), skip, m_tr->input_points_begin()), Some_points_iterator(m_tr->input_points_end(), skip), Normal_of_point_with_normal_pmap<Geom_traits>() ); coarse_poisson_function.compute_implicit_function(solver, Poisson_visitor(), 0.); internal::Poisson::Constant_sizing_field<Triangulation> min_sizing_field(CGAL::square(average_spacing)); internal::Poisson::Constant_sizing_field<Triangulation> sizing_field_ok(CGAL::square(average_spacing*average_spacing_ratio)); Special_wrapper_of_two_functions_keep_pointers< internal::Poisson::Constant_sizing_field<Triangulation>, Poisson_reconstruction_function<Geom_traits> > sizing_field2(&min_sizing_field, &coarse_poisson_function); sizing_field_timer.stop(); std::cerr << "Construction time of the sizing field: " << sizing_field_timer.time() << " seconds" << std::endl; NB.push_back( delaunay_refinement(radius_edge_ratio_bound, sizing_field2, max_vertices, enlarge_ratio, sizing_field_ok) ); approximation_timer.stop(); CGAL_TRACE_STREAM << "SPECIAL PASS END (" << approximation_timer.time() << " seconds)" << std::endl; } // Prints status CGAL_TRACE_STREAM << "Delaunay refinement: " << "added "; for(std::size_t i = 0; i < NB.size()-1; i++){ CGAL_TRACE_STREAM << NB[i] << " + "; } CGAL_TRACE_STREAM << NB.back() << " Steiner points, " << task_timer.time() << " seconds, " << std::endl; task_timer.reset(); #ifdef CGAL_DIV_NON_NORMALIZED CGAL_TRACE_STREAM << "Solve Poisson equation with non-normalized divergence...\n"; #else CGAL_TRACE_STREAM << "Solve Poisson equation with normalized divergence...\n"; #endif // Computes the Poisson indicator function operator() // at each vertex of the triangulation. double lambda = 0.1; if ( ! solve_poisson(solver, lambda) ) { std::cerr << "Error: cannot solve Poisson equation" << std::endl; return false; } // Shift and orient operator() such that: // - operator() = 0 on the input points, // - operator() < 0 inside the surface. set_contouring_value(median_value_at_input_vertices()); // Prints status CGAL_TRACE_STREAM << "Solve Poisson equation: " << task_timer.time() << " seconds, " << std::endl; task_timer.reset(); return true; } /// \endcond /*! This function must be called after the insertion of oriented points. It computes the piecewise linear scalar function operator() by: applying Delaunay refinement, solving for operator() at each vertex of the triangulation with a sparse linear solver, and shifting and orienting operator() such that it is 0 at all input points and negative inside the inferred surface. \tparam SparseLinearAlgebraTraits_d Symmetric definite positive sparse linear solver. If \ref thirdpartyEigen "Eigen" 3.1 (or greater) is available and `CGAL_EIGEN3_ENABLED` is defined, an overload with \link Eigen_solver_traits <tt>Eigen_solver_traits<Eigen::ConjugateGradient<Eigen_sparse_symmetric_matrix<double>::EigenType> ></tt> \endlink as default solver is provided. \param solver sparse linear solver. \param smoother_hole_filling controls if the Delaunay refinement is done for the input points, or for an approximation of the surface obtained from a first pass of the algorithm on a sample of the points. \return `false` if the linear solver fails. */ template <class SparseLinearAlgebraTraits_d> bool compute_implicit_function(SparseLinearAlgebraTraits_d solver, bool smoother_hole_filling = false) { if (smoother_hole_filling) return compute_implicit_function<SparseLinearAlgebraTraits_d,Poisson_visitor>(solver,Poisson_visitor(),0.02,5); else return compute_implicit_function<SparseLinearAlgebraTraits_d,Poisson_visitor>(solver,Poisson_visitor()); } /// \cond SKIP_IN_MANUAL #ifdef CGAL_EIGEN3_ENABLED // This variant provides the default sparse linear traits class = Eigen_solver_traits. bool compute_implicit_function(bool smoother_hole_filling = false) { typedef Eigen_solver_traits<Eigen::ConjugateGradient<Eigen_sparse_symmetric_matrix<double>::EigenType> > Solver; return compute_implicit_function<Solver>(Solver(), smoother_hole_filling); } #else #ifdef CGAL_TAUCS_ENABLED // This variant provides the default sparse linear traits class = Taucs_symmetric_solver_traits. bool compute_implicit_function(bool smoother_hole_filling = false) { typedef Taucs_symmetric_solver_traits<double> Solver; return compute_implicit_function<Solver>(Solver(), smoother_hole_filling); } #endif #endif boost::tuple<FT, Cell_handle, bool> special_func(const Point& p) const { m_hint = m_tr->locate(p ,m_hint ); // no hint when we use hierarchy if(m_tr->is_infinite(m_hint)) { int i = m_hint->index(m_tr->infinite_vertex()); return boost::make_tuple(m_hint->vertex((i+1)&3)->f(), m_hint, true); } FT a,b,c,d; barycentric_coordinates(p,m_hint,a,b,c,d); return boost::make_tuple(a * m_hint->vertex(0)->f() + b * m_hint->vertex(1)->f() + c * m_hint->vertex(2)->f() + d * m_hint->vertex(3)->f(), m_hint, false); } /// \endcond /*! `ImplicitFunction` interface: evaluates the implicit function at a given 3D query point. The function `compute_implicit_function` must be called before the first call to `operator()`. */ FT operator()(const Point& p) const { m_hint = m_tr->locate(p ,m_hint); if(m_tr->is_infinite(m_hint)) { int i = m_hint->index(m_tr->infinite_vertex()); return m_hint->vertex((i+1)&3)->f(); } FT a,b,c,d; barycentric_coordinates(p,m_hint,a,b,c,d); return a * m_hint->vertex(0)->f() + b * m_hint->vertex(1)->f() + c * m_hint->vertex(2)->f() + d * m_hint->vertex(3)->f(); } /// \cond SKIP_IN_MANUAL void initialize_cell_indices() { int i=0; for(Finite_cells_iterator fcit = m_tr->finite_cells_begin(); fcit != m_tr->finite_cells_end(); ++fcit){ fcit->info()= i++; } } void initialize_barycenters() const { m_Bary->resize(m_tr->number_of_cells()); for(std::size_t i=0; i< m_Bary->size();i++){ (*m_Bary)[i][0]=-1; } } void initialize_cell_normals() const { Normal.resize(m_tr->number_of_cells()); int i = 0; int N = 0; for(Finite_cells_iterator fcit = m_tr->finite_cells_begin(); fcit != m_tr->finite_cells_end(); ++fcit){ Normal[i] = cell_normal(fcit); if(Normal[i] == NULL_VECTOR){ N++; } ++i; } std::cerr << N << " out of " << i << " cells have NULL_VECTOR as normal" << std::endl; } void initialize_duals() const { Dual.resize(m_tr->number_of_cells()); int i = 0; for(Finite_cells_iterator fcit = m_tr->finite_cells_begin(); fcit != m_tr->finite_cells_end(); ++fcit){ Dual[i++] = m_tr->dual(fcit); } } void clear_duals() const { Dual.clear(); } void clear_normals() const { Normal.clear(); } void initialize_matrix_entry(Cell_handle ch) const { boost::array<double,9> & entry = (*m_Bary)[ch->info()]; const Point& pa = ch->vertex(0)->point(); const Point& pb = ch->vertex(1)->point(); const Point& pc = ch->vertex(2)->point(); const Point& pd = ch->vertex(3)->point(); Vector va = pa - pd; Vector vb = pb - pd; Vector vc = pc - pd; internal::invert(va.x(), va.y(), va.z(), vb.x(), vb.y(), vb.z(), vc.x(), vc.y(), vc.z(), entry[0],entry[1],entry[2],entry[3],entry[4],entry[5],entry[6],entry[7],entry[8]); } /// \endcond /// Returns a point located inside the inferred surface. Point get_inner_point() const { // Gets point / the implicit function is minimum return m_sink; } /// @} // Private methods: private: /// Delaunay refinement (break bad tetrahedra, where /// bad means badly shaped or too big). The normal of /// Steiner points is set to zero. /// Returns the number of vertices inserted. template <typename Sizing_field> unsigned int delaunay_refinement(FT radius_edge_ratio_bound, ///< radius edge ratio bound (ignored if zero) Sizing_field sizing_field, ///< cell radius bound (ignored if zero) unsigned int max_vertices, ///< number of vertices bound FT enlarge_ratio) ///< bounding box enlarge ratio { return delaunay_refinement(radius_edge_ratio_bound, sizing_field, max_vertices, enlarge_ratio, internal::Poisson::Constant_sizing_field<Triangulation>()); } template <typename Sizing_field, typename Second_sizing_field> unsigned int delaunay_refinement(FT radius_edge_ratio_bound, ///< radius edge ratio bound (ignored if zero) Sizing_field sizing_field, ///< cell radius bound (ignored if zero) unsigned int max_vertices, ///< number of vertices bound FT enlarge_ratio, ///< bounding box enlarge ratio Second_sizing_field second_sizing_field) { Sphere elarged_bsphere = enlarged_bounding_sphere(enlarge_ratio); unsigned int nb_vertices_added = poisson_refine_triangulation(*m_tr,radius_edge_ratio_bound,sizing_field,second_sizing_field,max_vertices,elarged_bsphere); return nb_vertices_added; } /// Poisson reconstruction. /// Returns false on error. /// /// @commentheading Template parameters: /// @param SparseLinearAlgebraTraits_d Symmetric definite positive sparse linear solver. template <class SparseLinearAlgebraTraits_d> bool solve_poisson( SparseLinearAlgebraTraits_d solver, ///< sparse linear solver double lambda) { CGAL_TRACE("Calls solve_poisson()\n"); double time_init = clock(); double duration_assembly = 0.0; double duration_solve = 0.0; initialize_cell_indices(); initialize_barycenters(); // get #variables constrain_one_vertex_on_convex_hull(); m_tr->index_unconstrained_vertices(); unsigned int nb_variables = static_cast<unsigned int>(m_tr->number_of_vertices()-1); CGAL_TRACE(" Number of variables: %ld\n", (long)(nb_variables)); // Assemble linear system A*X=B typename SparseLinearAlgebraTraits_d::Matrix A(nb_variables); // matrix is symmetric definite positive typename SparseLinearAlgebraTraits_d::Vector X(nb_variables), B(nb_variables); initialize_duals(); #ifndef CGAL_DIV_NON_NORMALIZED initialize_cell_normals(); #endif Finite_vertices_iterator v, e; for(v = m_tr->finite_vertices_begin(), e = m_tr->finite_vertices_end(); v != e; ++v) { if(!m_tr->is_constrained(v)) { #ifdef CGAL_DIV_NON_NORMALIZED B[v->index()] = div(v); // rhs -> divergent #else // not defined(CGAL_DIV_NORMALIZED) B[v->index()] = div_normalized(v); // rhs -> divergent #endif // not defined(CGAL_DIV_NORMALIZED) assemble_poisson_row<SparseLinearAlgebraTraits_d>(A,v,B,lambda); } } clear_duals(); clear_normals(); duration_assembly = (clock() - time_init)/CLOCKS_PER_SEC; CGAL_TRACE(" Creates matrix: done (%.2lf s)\n", duration_assembly); CGAL_TRACE(" Solve sparse linear system...\n"); // Solve "A*X = B". On success, solution is (1/D) * X. time_init = clock(); double D; if(!solver.linear_solver(A, B, X, D)) return false; CGAL_surface_reconstruction_points_assertion(D == 1.0); duration_solve = (clock() - time_init)/CLOCKS_PER_SEC; CGAL_TRACE(" Solve sparse linear system: done (%.2lf s)\n", duration_solve); // copy function's values to vertices unsigned int index = 0; for (v = m_tr->finite_vertices_begin(), e = m_tr->finite_vertices_end(); v!= e; ++v) if(!m_tr->is_constrained(v)) v->f() = X[index++]; CGAL_TRACE("End of solve_poisson()\n"); return true; } /// Shift and orient the implicit function such that: /// - the implicit function = 0 for points / f() = contouring_value, /// - the implicit function < 0 inside the surface. /// /// Returns the minimum value of the implicit function. FT set_contouring_value(FT contouring_value) { // median value set to 0.0 shift_f(-contouring_value); // check value on convex hull (should be positive) Vertex_handle v = any_vertex_on_convex_hull(); if(v->f() < 0.0) flip_f(); // Update m_sink FT sink_value = find_sink(); return sink_value; } /// Gets median value of the implicit function over input vertices. FT median_value_at_input_vertices() const { std::deque<FT> values; Finite_vertices_iterator v, e; for(v = m_tr->finite_vertices_begin(), e= m_tr->finite_vertices_end(); v != e; v++) if(v->type() == Triangulation::INPUT) values.push_back(v->f()); std::size_t size = values.size(); if(size == 0) { std::cerr << "Contouring: no input points\n"; return 0.0; } std::sort(values.begin(),values.end()); std::size_t index = size/2; // return values[size/2]; return 0.5 * (values[index] + values[index+1]); // avoids singular cases } void barycentric_coordinates(const Point& p, Cell_handle cell, FT& a, FT& b, FT& c, FT& d) const { // const Point& pa = cell->vertex(0)->point(); // const Point& pb = cell->vertex(1)->point(); // const Point& pc = cell->vertex(2)->point(); const Point& pd = cell->vertex(3)->point(); #if 1 //Vector va = pa - pd; //Vector vb = pb - pd; //Vector vc = pc - pd; Vector vp = p - pd; //FT i00, i01, i02, i10, i11, i12, i20, i21, i22; //internal::invert(va.x(), va.y(), va.z(), // vb.x(), vb.y(), vb.z(), // vc.x(), vc.y(), vc.z(), // i00, i01, i02, i10, i11, i12, i20, i21, i22); const boost::array<double,9> & i = (*m_Bary)[cell->info()]; if(i[0]==-1){ initialize_matrix_entry(cell); } // UsedBary[cell->info()] = true; a = i[0] * vp.x() + i[3] * vp.y() + i[6] * vp.z(); b = i[1] * vp.x() + i[4] * vp.y() + i[7] * vp.z(); c = i[2] * vp.x() + i[5] * vp.y() + i[8] * vp.z(); d = 1 - ( a + b + c); #else FT v = volume(pa,pb,pc,pd); a = std::fabs(volume(pb,pc,pd,p) / v); b = std::fabs(volume(pa,pc,pd,p) / v); c = std::fabs(volume(pb,pa,pd,p) / v); d = std::fabs(volume(pb,pc,pa,p) / v); std::cerr << "_________________________________\n"; std::cerr << aa << " " << bb << " " << cc << " " << dd << std::endl; std::cerr << a << " " << b << " " << c << " " << d << std::endl; #endif } FT find_sink() { m_sink = CGAL::ORIGIN; FT min_f = 1e38; Finite_vertices_iterator v, e; for(v = m_tr->finite_vertices_begin(), e= m_tr->finite_vertices_end(); v != e; v++) { if(v->f() < min_f) { m_sink = v->point(); min_f = v->f(); } } return min_f; } void shift_f(const FT shift) { Finite_vertices_iterator v, e; for(v = m_tr->finite_vertices_begin(), e = m_tr->finite_vertices_end(); v!= e; v++) v->f() += shift; } void flip_f() { Finite_vertices_iterator v, e; for(v = m_tr->finite_vertices_begin(), e = m_tr->finite_vertices_end(); v != e; v++) v->f() = -v->f(); } Vertex_handle any_vertex_on_convex_hull() { Cell_handle ch = m_tr->infinite_vertex()->cell(); return ch->vertex( (ch->index( m_tr->infinite_vertex())+1)%4); } void constrain_one_vertex_on_convex_hull(const FT value = 0.0) { Vertex_handle v = any_vertex_on_convex_hull(); m_tr->constrain(v); v->f() = value; } // TODO: Some entities are computed too often // - nn and area should not be computed for the face and its opposite face // // divergent FT div_normalized(Vertex_handle v) { std::vector<Cell_handle> cells; cells.reserve(32); m_tr->incident_cells(v,std::back_inserter(cells)); FT div = 0; typename std::vector<Cell_handle>::iterator it; for(it = cells.begin(); it != cells.end(); it++) { Cell_handle cell = *it; if(m_tr->is_infinite(cell)) continue; // compute average normal per cell Vector n = get_cell_normal(cell); // zero normal - no need to compute anything else if(n == CGAL::NULL_VECTOR) continue; // compute n' int index = cell->index(v); const Point& x = cell->vertex(index)->point(); const Point& a = cell->vertex((index+1)%4)->point(); const Point& b = cell->vertex((index+2)%4)->point(); const Point& c = cell->vertex((index+3)%4)->point(); Vector nn = (index%2==0) ? CGAL::cross_product(b-a,c-a) : CGAL::cross_product(c-a,b-a); nn = nn / std::sqrt(nn*nn); // normalize Vector p = a - x; Vector q = b - x; Vector r = c - x; FT p_n = std::sqrt(p*p); FT q_n = std::sqrt(q*q); FT r_n = std::sqrt(r*r); FT solid_angle = p*(CGAL::cross_product(q,r)); solid_angle = std::abs(solid_angle / (p_n*q_n*r_n + (p*q)*r_n + (q*r)*p_n + (r*p)*q_n)); FT area = std::sqrt(squared_area(a,b,c)); FT length = p_n + q_n + r_n; div += n * nn * area / length ; } return div * FT(3.0); } FT div(Vertex_handle v) { std::vector<Cell_handle> cells; cells.reserve(32); m_tr->incident_cells(v,std::back_inserter(cells)); FT div = 0.0; typename std::vector<Cell_handle>::iterator it; for(it = cells.begin(); it != cells.end(); it++) { Cell_handle cell = *it; if(m_tr->is_infinite(cell)) continue; const int index = cell->index(v); const Point& a = cell->vertex(m_tr->vertex_triple_index(index, 0))->point(); const Point& b = cell->vertex(m_tr->vertex_triple_index(index, 1))->point(); const Point& c = cell->vertex(m_tr->vertex_triple_index(index, 2))->point(); const Vector nn = CGAL::cross_product(b-a,c-a); div+= nn * (//v->normal() + cell->vertex((index+1)%4)->normal() + cell->vertex((index+2)%4)->normal() + cell->vertex((index+3)%4)->normal()); } return div; } Vector get_cell_normal(Cell_handle cell) { return Normal[cell->info()]; } Vector cell_normal(Cell_handle cell) const { const Vector& n0 = cell->vertex(0)->normal(); const Vector& n1 = cell->vertex(1)->normal(); const Vector& n2 = cell->vertex(2)->normal(); const Vector& n3 = cell->vertex(3)->normal(); Vector n = n0 + n1 + n2 + n3; if(n != NULL_VECTOR){ FT sq_norm = n*n; if(sq_norm != 0.0){ return n / std::sqrt(sq_norm); // normalize } } return NULL_VECTOR; } // cotan formula as area(voronoi face) / len(primal edge) FT cotan_geometric(Edge& edge) { Cell_handle cell = edge.first; Vertex_handle vi = cell->vertex(edge.second); Vertex_handle vj = cell->vertex(edge.third); // primal edge const Point& pi = vi->point(); const Point& pj = vj->point(); Vector primal = pj - pi; FT len_primal = std::sqrt(primal * primal); return area_voronoi_face(edge) / len_primal; } // spin around edge // return area(voronoi face) FT area_voronoi_face(Edge& edge) { // circulate around edge Cell_circulator circ = m_tr->incident_cells(edge); Cell_circulator done = circ; std::vector<Point> voronoi_points; voronoi_points.reserve(9); do { Cell_handle cell = circ; if(!m_tr->is_infinite(cell)) voronoi_points.push_back(Dual[cell->info()]); else // one infinite tet, switch to another calculation return area_voronoi_face_boundary(edge); circ++; } while(circ != done); if(voronoi_points.size() < 3) { CGAL_surface_reconstruction_points_assertion(false); return 0.0; } // sum up areas FT area = 0.0; const Point& a = voronoi_points[0]; std::size_t nb_triangles = voronoi_points.size() - 1; for(std::size_t i=1;i<nb_triangles;i++) { const Point& b = voronoi_points[i]; const Point& c = voronoi_points[i+1]; area += std::sqrt(squared_area(a,b,c)); } return area; } // approximate area when a cell is infinite FT area_voronoi_face_boundary(Edge& edge) { FT area = 0.0; Vertex_handle vi = edge.first->vertex(edge.second); Vertex_handle vj = edge.first->vertex(edge.third); const Point& pi = vi->point(); const Point& pj = vj->point(); Point m = CGAL::midpoint(pi,pj); // circulate around each incident cell Cell_circulator circ = m_tr->incident_cells(edge); Cell_circulator done = circ; do { Cell_handle cell = circ; if(!m_tr->is_infinite(cell)) { // circumcenter of cell Point c = Dual[cell->info()]; Tetrahedron tet = m_tr->tetrahedron(cell); int i = cell->index(vi); int j = cell->index(vj); int k = Triangulation_utils_3::next_around_edge(i,j); int l = Triangulation_utils_3::next_around_edge(j,i); Vertex_handle vk = cell->vertex(k); Vertex_handle vl = cell->vertex(l); const Point& pk = vk->point(); const Point& pl = vl->point(); // if circumcenter is outside tet // pick barycenter instead if(tet.has_on_unbounded_side(c)) { Point cell_points[4] = {pi,pj,pk,pl}; c = CGAL::centroid(cell_points, cell_points+4); } Point ck = CGAL::circumcenter(pi,pj,pk); Point cl = CGAL::circumcenter(pi,pj,pl); area += std::sqrt(squared_area(m,c,ck)); area += std::sqrt(squared_area(m,c,cl)); } circ++; } while(circ != done); return area; } /// Assemble vi's row of the linear system A*X=B /// /// @commentheading Template parameters: /// @param SparseLinearAlgebraTraits_d Symmetric definite positive sparse linear solver. template <class SparseLinearAlgebraTraits_d> void assemble_poisson_row(typename SparseLinearAlgebraTraits_d::Matrix& A, Vertex_handle vi, typename SparseLinearAlgebraTraits_d::Vector& B, double lambda) { // for each vertex vj neighbor of vi std::vector<Edge> edges; m_tr->incident_edges(vi,std::back_inserter(edges)); double diagonal = 0.0; for(typename std::vector<Edge>::iterator it = edges.begin(); it != edges.end(); it++) { Vertex_handle vj = it->first->vertex(it->third); if(vj == vi){ vj = it->first->vertex(it->second); } if(m_tr->is_infinite(vj)) continue; // get corresponding edge Edge edge( it->first, it->first->index(vi), it->first->index(vj)); if(vi->index() < vj->index()){ std::swap(edge.second, edge.third); } double cij = cotan_geometric(edge); if(m_tr->is_constrained(vj)){ if(! is_valid(vj->f())){ std::cerr << "vj->f() = " << vj->f() << " is not valid" << std::endl; } B[vi->index()] -= cij * vj->f(); // change rhs if(! is_valid( B[vi->index()])){ std::cerr << " B[vi->index()] = " << B[vi->index()] << " is not valid" << std::endl; } } else { if(! is_valid(cij)){ std::cerr << "cij = " << cij << " is not valid" << std::endl; } A.set_coef(vi->index(),vj->index(), -cij, true /*new*/); // off-diagonal coefficient } diagonal += cij; } // diagonal coefficient if (vi->type() == Triangulation::INPUT){ A.set_coef(vi->index(),vi->index(), diagonal + lambda, true /*new*/) ; } else{ A.set_coef(vi->index(),vi->index(), diagonal, true /*new*/); } } /// Computes enlarged geometric bounding sphere of the embedded triangulation. Sphere enlarged_bounding_sphere(FT ratio) const { Sphere bsphere = bounding_sphere(); // triangulation's bounding sphere return Sphere(bsphere.center(), bsphere.squared_radius() * ratio*ratio); } }; // end of Poisson_reconstruction_function } //namespace CGAL #endif // CGAL_POISSON_RECONSTRUCTION_FUNCTION_H
- [cgal-discuss] build error when reconstruction surface without normals, vanessa, 02/02/2014
- Re: [cgal-discuss] build error when reconstruction surface without normals, Sebastien Loriot (GeometryFactory), 02/03/2014
- Re: [cgal-discuss] build error when reconstruction surface without normals, vanessa, 02/03/2014
