- To:
- Subject: Re: [cgal-discuss] build error when reconstruction surface without normals
- Date: Mon, 3 Feb 2014 20:47:01 +0000
It is sorted out. Thanks:)
2014-02-03 Sebastien Loriot (GeometryFactory) <>:
My patch was over CGAL-4.3, the file attached should be OK with CGAL-4.2.
Sebastien.
On 02/03/2014 11:58 AM, vanessa wrote:
Hi Sebastien,3
When I replaced the header file, a new error occurs:
c:\program
files\cgal-4.2-beta1\include\cgal\poisson_reconstruction_function.h(348):
error C3861: 'make_identity_property_map': identifier not found
1> c:\program
files\cgal-4.2-beta1\include\cgal\poisson_reconstruction_function.h(443) :
see reference to function template instantiation
'CGAL::Poisson_reconstruction_function<Gt>::Poisson_reconstruction_function<CGAL::Filter_iterator<I,P>,CGAL::Normal_of_point_with_normal_pmap<Gt>>(InputIterator,InputIterator,NormalPMap,void
*)' being compiled
1> with
1> [
1> Gt=Kernel,
1>
I=CGAL::Iterator_project<CGAL::Filter_iterator<CGAL::Triangulation_3<CGAL::Reconstruction_triangulation_default_geom_traits_3<CGAL::Robust_circumcenter_filtered_traits_3<Kernel>>,CGAL::Triangulation_data_structure_3<CGAL::Reconstruction_vertex_base_3<CGAL::Reconstruction_triangulation_default_geom_traits_3<CGAL::Robust_circumcenter_filtered_traits_3<Kernel>>>,CGAL::Triangulation_cell_base_with_info_3<int,CGAL::Reconstruction_triangulation_default_geom_traits_3<CGAL::Robust_circumcenter_filtered_traits_3<Kernel>>>>>::Finite_vertices_iterator,CGAL::Reconstruction_triangulation_3<CGAL::Robust_circumcenter_filtered_traits_3<Kernel>>::Is_steiner_point>,CGAL::Project_point<CGAL::Reconstruction_vertex_base_3<CGAL::Reconstruction_triangulation_default_geom_traits_3<CGAL::Robust_circumcenter_filtered_traits_3<Kernel>>,CGAL::Triangulation_vertex_base_3<CGAL::Reconstruction_triangulation_default_geom_traits_3<CGAL::Robust_circumcenter_filtered_traits_
<Kernel>>,CGAL::Triangulation_ds_vertex_base_3<CGAL::Triangulation_data_structure_3<CGAL::Reconstruction_vertex_base_3<CGAL::Reconstruction_triangulation_default_geom_traits_3<CGAL::Robust_circumcenter_filtered_traits_3<Kernel>>>,CGAL::Triangulation_cell_base_with_info_3<int,CGAL::Reconstruction_triangulation_default_geom_traits_3<CGAL::Robust_circumcenter_filtered_traits_3<Kernel>>>>>>>>>,
1> P=CGAL::Poisson_skip_vertices,:
1>
InputIterator=CGAL::Filter_iterator<CGAL::Iterator_project<CGAL::Filter_iterator<CGAL::Triangulation_3<CGAL::Reconstruction_triangulation_default_geom_traits_3<CGAL::Robust_circumcenter_filtered_traits_3<Kernel>>,CGAL::Triangulation_data_structure_3<CGAL::Reconstruction_vertex_base_3<CGAL::Reconstruction_triangulation_default_geom_traits_3<CGAL::Robust_circumcenter_filtered_traits_3<Kernel>>>,CGAL::Triangulation_cell_base_with_info_3<int,CGAL::Reconstruction_triangulation_default_geom_traits_3<CGAL::Robust_circumcenter_filtered_traits_3<Kernel>>>>>::Finite_vertices_iterator,CGAL::Reconstruction_triangulation_3<CGAL::Robust_circumcenter_filtered_traits_3<Kernel>>::Is_steiner_point>,CGAL::Project_point<CGAL::Reconstruction_vertex_base_3<CGAL::Reconstruction_triangulation_default_geom_traits_3<CGAL::Robust_circumcenter_filtered_traits_3<Kernel>>,CGAL::Triangulation_vertex_base_3<CGAL::Reconstruction_triangulation_default_geom_traits_3<CGAL:
Robust_circumcenter_filtered_traits_3<Kernel>>,CGAL::Triangulation_ds_vertex_base_3<CGAL::Triangulation_data_structure_3<CGAL::Reconstruction_vertex_base_3<CGAL::Reconstruction_triangulation_default_geom_traits_3<CGAL::Robust_circumcenter_filtered_traits_3<Kernel>>>,CGAL::Triangulation_cell_base_with_info_3<int,CGAL::Reconstruction_triangulation_default_geom_traits_3<CGAL::Robust_circumcenter_filtered_traits_3<Kernel>>>>>>>>>,CGAL::Poisson_skip_vertices>,
1>
NormalPMap=CGAL::Normal_of_point_with_normal_pmap<CGAL::Epick>
1> ]
1> c:\program
files\cgal-4.2-beta1\include\cgal\poisson_reconstruction_function.h(531) :
see reference to function template instantiation 'bool
CGAL::Poisson_reconstruction_function<Gt>::compute_implicit_function<SparseLinearAlgebraTraits_d,CGAL::Poisson_visitor>(SparseLinearAlgebraTraits_d,Visitor,double,double)'
being compiled
1> with
1> [
1> Gt=Kernel,
1> SparseLinearAlgebraTraits_d=Solver,
1> Visitor=CGAL::Poisson_visitor
1> ]
1> c:\program
files\cgal-4.2-beta1\include\cgal\poisson_reconstruction_function.h(542) :
CGAL::Poisson_reconstruction_function<Gt>::compute_implicit_function<Solver>(SparseLinearAlgebraTraits_d,bool)'
being compiled
1> with
1> [
1> Gt=Kernel,
1> ]
1> c:\program
files\cgal-4.2-beta1\include\cgal\poisson_reconstruction_function.h(540) :
while compiling class template member function 'bool
CGAL::Poisson_reconstruction_function<Gt>::compute_implicit_function(bool)'
1> with
1> [
1> Gt=Kernel
1> ]
1> f:\surfacewithoutnormal.cpp(88) : see reference to class
template instantiation 'CGAL::Poisson_reconstruction_function<Gt>' being
compiled
1> with
1> [
1> Gt=Kernel
1> ]
1>
1>Build FAILED.
Is it another bug?
I am new to CGAL, so maybe the answer is obvious.
Thanks for your help.
Zeya
View this message in context: http://cgal-discuss.949826.n4.nabble.com/build-error-when-reconstruction-surface-without-normals-tp4658740p4658750.html
- [cgal-discuss] build error when reconstruction surface without normals, vanessa, 02/02/2014
- Re: [cgal-discuss] build error when reconstruction surface without normals, Sebastien Loriot (GeometryFactory), 02/03/2014
- Re: [cgal-discuss] build error when reconstruction surface without normals, vanessa, 02/03/2014
- Re: [cgal-discuss] build error when reconstruction surface without normals, 芮泽亚, 02/03/2014
