- To:
- Subject: Re: [cgal-discuss] how to check whether the two polyhedrons is in contact
- Date: Tue, 04 Feb 2014 16:06:33 +0100
On 02/04/2014 02:27 PM, vanessa wrote:
Hi allWhat do you mean by in contact?
I'm trying to do the intersection test for two 3D polyhedrons using the
function"CGAL::intersection_Polyhedron_3_Polyhedron_3(Poly1, Poly2,
std::back_inserter(polylines));".
It performs well.But when one polyhedron is in contact to the other, the
output (size of polylines) shows 1 instead of 0. Is there any method to
check the case that two polyhedrons are in contact?
IIRC, note that this function is will not report intersection points.
Sebastien.
Many thanks
Vanessa
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/how-to-check-whether-the-two-polyhedrons-is-in-contact-tp4658761.html
- [cgal-discuss] how to check whether the two polyhedrons is in contact, vanessa, 02/04/2014
- Re: [cgal-discuss] how to check whether the two polyhedrons is in contact, Sebastien Loriot (GeometryFactory), 02/04/2014
- Re: [cgal-discuss] how to check whether the two polyhedrons is in contact, 芮泽亚, 02/04/2014
- Re: [cgal-discuss] how to check whether the two polyhedrons is in contact, Sebastien Loriot (GeometryFactory), 02/05/2014
- Re: [cgal-discuss] how to check whether the two polyhedrons is in contact, vanessa, 02/05/2014
