cgal-discuss - Re: [cgal-discuss] how to check whether the two polyhedrons is in contact
  • To:
  • Subject: Re: [cgal-discuss] how to check whether the two polyhedrons is in contact
  • Date: Wed, 05 Feb 2014 07:17:07 +0100
On 02/04/2014 06:56 PM, 芮泽亚 wrote:
> Hi Sebastien
> What do you mean" intersection predicate "?
> It seems all the intersection tests output intersection even if the two
> objects touch.
> After the box intersection, I may further do the triangle intersection.
> But if two triangles touch, the intersection function would always say
> they intersect.
> In my problem, I would say they do not intersect if they touch cause the
> optimal solution of my problem may occur when the objects touch.
An easy way to do it is to compute the intersection and check if it's an
edge or
a vertex of the triangle.
Sebastien.
> Thanks:)
> Vanessa
> 2014-02-04 Sebastien Loriot (GeometryFactory)
> <mailto:>>:
> You can use this package:
> http://doc.cgal.org/latest/__Box_intersection_d/index.html
> <http://doc.cgal.org/latest/Box_intersection_d/index.html>
> and use an intersection predicate matching your need.
> Sebastien.
> On 02/04/2014 04:24 PM, 芮泽亚 wrote:
> Hi
> I mean the two polyhedrons touch(share a common point, edge, or
> face).
> It seems when I use the function, it will output the two polyhedrons
> intersect in this case.
> But in my problem, this case requires to be considered no
> intersection.
> Can you give me some hints about how to check this case?
> Thanks for your help.
> Vanessa
> <mailto:>
> <mailto:
> <mailto:>>>__:
> On 02/04/2014 02:27 PM, vanessa wrote:
> Hi all
> I'm trying to do the intersection test for two 3D
> polyhedrons
> using the
> function"CGAL::intersection_____Polyhedron_3_Polyhedron_3(____Poly1,
> Poly2,
> std::back_inserter(polylines))____;".
> It performs well.But when one polyhedron is in contact
> to the
> other, the
> output (size of polylines) shows 1 instead of 0. Is
> there any
> method to
> check the case that two polyhedrons are in contact?
> What do you mean by in contact?
> IIRC, note that this function is will not report
> intersection points.
> Sebastien.
> Many thanks
> Vanessa
> View this message in context:
> http://cgal-discuss.949826.n4.____nabble.com/how-to-check-____whether-the-two-polyhedrons-____is-in-contact-tp4658761.html
> <http://nabble.com/how-to-check-__whether-the-two-polyhedrons-__is-in-contact-tp4658761.html>
> <http://cgal-discuss.949826.__n4.nabble.com/how-to-check-__whether-the-two-polyhedrons-__is-in-contact-tp4658761.html
> <http://cgal-discuss.949826.n4.nabble.com/how-to-check-whether-the-two-polyhedrons-is-in-contact-tp4658761.html>>
> Sent from the cgal-discuss mailing list archive at
> Nabble.com.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/____info/cgal-discuss
> <https://sympa.inria.fr/sympa/__info/cgal-discuss>
> <https://sympa.inria.fr/sympa/info/cgal-discuss>>
