cgal-discuss - Re: [cgal-discuss] how to check whether the two polyhedrons is in contact
  • To:
  • Subject: Re: [cgal-discuss] how to check whether the two polyhedrons is in contact
  • Date: Tue, 04 Feb 2014 16:32:58 +0100
You can use this package:
http://doc.cgal.org/latest/Box_intersection_d/index.html
and use an intersection predicate matching your need.
Sebastien.
On 02/04/2014 04:24 PM, 芮泽亚 wrote:
Hi
I mean the two polyhedrons touch(share a common point, edge, or face).
It seems when I use the function, it will output the two polyhedrons
intersect in this case.
But in my problem, this case requires to be considered no intersection.
Can you give me some hints about how to check this case?
Thanks for your help.
Vanessa
2014-02-04 Sebastien Loriot (GeometryFactory)
<mailto:>>:
On 02/04/2014 02:27 PM, vanessa wrote:
Hi all
I'm trying to do the intersection test for two 3D polyhedrons
using the
function"CGAL::intersection___Polyhedron_3_Polyhedron_3(__Poly1,
Poly2,
std::back_inserter(polylines))__;".
It performs well.But when one polyhedron is in contact to the
other, the
output (size of polylines) shows 1 instead of 0. Is there any
method to
check the case that two polyhedrons are in contact?
What do you mean by in contact?
IIRC, note that this function is will not report intersection points.
Sebastien.
Many thanks
Vanessa
View this message in context:
http://cgal-discuss.949826.n4.__nabble.com/how-to-check-__whether-the-two-polyhedrons-__is-in-contact-tp4658761.html
<http://cgal-discuss.949826.n4.nabble.com/how-to-check-whether-the-two-polyhedrons-is-in-contact-tp4658761.html>
https://sympa.inria.fr/sympa/__info/cgal-discuss
<https://sympa.inria.fr/sympa/info/cgal-discuss>
