Re: [cgal-discuss] Periodic Voronoi Tessellation in 3D: Write Cells, Faces and Vertices to File
- To:
- Subject: Re: [cgal-discuss] Periodic Voronoi Tessellation in 3D: Write Cells, Faces and Vertices to File
- Date: Tue, 4 Feb 2014 14:41:21 -0800 (PST)
Dear Monique Teillaud,
thank you for your help. Sorry, I still have a question: The
function "dual (Vertex_handle v, OutputIterator pts)" returns in
the output iterator the vertices of the Voronoi cell with center v.
Is that right? For a cubic Voronoi cell I get 24 points. Are the
facets triangulated? I need to identify the facets, e.g., as the
first one consisting of the points number 1,2,3 and the adjacent
one consisting of the points number 4,3,2; the order of the
points should correspond to the orientation of the facet.
Is that possible?
Thank you very much again.
Best regards,
Michael
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Periodic-Voronoi-Tessellation-in-3D-Write-Cells-Faces-and-Vertices-to-File-tp4658770p4658775.html
- [cgal-discuss] Periodic Voronoi Tessellation in 3D: Write Cells, Faces and Vertices to File, Michael Klatt, 02/04/2014
- Re: [cgal-discuss] Periodic Voronoi Tessellation in 3D: Write Cells, Faces and Vertices to File, Monique Teillaud, 02/04/2014
- Re: [cgal-discuss] Periodic Voronoi Tessellation in 3D: Write Cells, Faces and Vertices to File, Michael Klatt, 02/04/2014
- Re: [cgal-discuss] Periodic Voronoi Tessellation in 3D: Write Cells, Faces and Vertices to File, Monique Teillaud, 02/05/2014
- Re: [cgal-discuss] Periodic Voronoi Tessellation in 3D: Write Cells, Faces and Vertices to File, Olivier Devillers, 02/05/2014
- Re: [cgal-discuss] Periodic Voronoi Tessellation in 3D: Write Cells, Faces and Vertices to File, Michael Klatt, 02/06/2014
- Re: [cgal-discuss] Periodic Voronoi Tessellation in 3D: Write Cells, Faces and Vertices to File, Olivier Devillers, 02/06/2014
- Re: [cgal-discuss] Periodic Voronoi Tessellation in 3D: Write Cells, Faces and Vertices to File, Michael Klatt, 02/10/2014
