Re: [cgal-discuss] Periodic Voronoi Tessellation in 3D: Write Cells, Faces and Vertices to File
- To:
- Subject: Re: [cgal-discuss] Periodic Voronoi Tessellation in 3D: Write Cells, Faces and Vertices to File
- Date: Thu, 06 Feb 2014 08:02:55 -0400
Le 2/5/14 9:39 PM, Michael Klatt a écrit :
Dear Monique Teillaud, Dear Olivier Devillers,If you add enough points at random, then youo should not have
thank you very much for your help!
The cubic lattice was an example, which I think I now understand.
Now, I work on random point processes/ tessellations.
degenerate cases anymore.
I have just two more questions.exact predicates inexact construction should be
I use exact predicates and exact constructions as it is recommended
enough and much faster
for the dual constructions. Can I (or is it wise to) use theyes for points
operator== in order to check whether two points (of two different
facets) are identical?
(http://doc.cgal.org/latest/Kernel_23/classCGAL_1_1Point__2.html#a8ab6bac29380a19ffb4b2b4486fb96e9)
no for vertices (Vertex_handle) which is a combinatorial object
- [cgal-discuss] Periodic Voronoi Tessellation in 3D: Write Cells, Faces and Vertices to File, Michael Klatt, 02/04/2014
- Re: [cgal-discuss] Periodic Voronoi Tessellation in 3D: Write Cells, Faces and Vertices to File, Monique Teillaud, 02/04/2014
- Re: [cgal-discuss] Periodic Voronoi Tessellation in 3D: Write Cells, Faces and Vertices to File, Michael Klatt, 02/04/2014
- Re: [cgal-discuss] Periodic Voronoi Tessellation in 3D: Write Cells, Faces and Vertices to File, Monique Teillaud, 02/05/2014
- Re: [cgal-discuss] Periodic Voronoi Tessellation in 3D: Write Cells, Faces and Vertices to File, Olivier Devillers, 02/05/2014
- Re: [cgal-discuss] Periodic Voronoi Tessellation in 3D: Write Cells, Faces and Vertices to File, Michael Klatt, 02/06/2014
- Re: [cgal-discuss] Periodic Voronoi Tessellation in 3D: Write Cells, Faces and Vertices to File, Olivier Devillers, 02/06/2014
- Re: [cgal-discuss] Periodic Voronoi Tessellation in 3D: Write Cells, Faces and Vertices to File, Michael Klatt, 02/10/2014
