- To:
- Subject: Re: [cgal-discuss] nD Grid Map
- Date: Tue, 04 Mar 2014 07:10:45 +0100
On 02/27/2014 09:38 AM, Javi V. wrote:
Hello everybody,Hello,
I have spent the last weeks implementing a nD Grid Map container based onThere is no such things in CGAL right now.
std::vector. Although there are boost multiarrays and new fancy ways of
creating nD vectors with variadic templates, my implementation is based on a
flat vector, in which I work only with indices and the 4connectivity
neighbour search is generalized to n-dimensions, also the conversion from
index to coordinates and viceversa. The best advantage is that the only
thing we need to know in compilation time is the number of dimensions (not
even the size). There were another version in which dimension could also be
decided in runtime, however this was a bit slower since the compiler could
not optimize the loops so much.
I would like to know if there is something similar in this library and, if
not, is it interesting to be included? How I can contribute in order to
include this container? I think it could be useful for other people.
To give us an idea of why it would be useful to have it in CGAL, what
are you using it for?
Sebastien.
Thank you!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/nD-Grid-Map-tp4658879.html
- Re: [cgal-discuss] nD Grid Map, Sebastien Loriot (GeometryFactory), 03/04/2014
- Re: [cgal-discuss] nD Grid Map, Javi V., 03/04/2014
