Re: [cgal-discuss] Problem with Polyhedron_3 demo - intersection of objects with the same vertices
- To:
- Subject: Re: [cgal-discuss] Problem with Polyhedron_3 demo - intersection of objects with the same vertices
- Date: Wed, 5 Mar 2014 22:52:21 -0800 (PST)
Thanks for quick response.
The exampliar input files are here:
https://www.dropbox.com/s/nywdv80yzr0wpxp/henley_3D.off
https://www.dropbox.com/s/slxzfwhchpuix2p/henley_shift_3D.off
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Problem-with-Polyhedron-3-demo-intersection-of-objects-with-the-same-vertices-tp4658911p4658913.html
- [cgal-discuss] Problem with Polyhedron_3 demo - intersection of objects with the same vertices, swistak06, 03/06/2014
- Re: [cgal-discuss] Problem with Polyhedron_3 demo - intersection of objects with the same vertices, Sebastien Loriot (GeometryFactory), 03/06/2014
- Re: [cgal-discuss] Problem with Polyhedron_3 demo - intersection of objects with the same vertices, swistak06, 03/06/2014
- Re: [cgal-discuss] Problem with Polyhedron_3 demo - intersection of objects with the same vertices, swistak06, 03/08/2014
- Re: [cgal-discuss] Problem with Polyhedron_3 demo - intersection of objects with the same vertices, Sebastien Loriot (GeometryFactory), 03/10/2014
- Re: [cgal-discuss] Problem with Polyhedron_3 demo - intersection of objects with the same vertices, swistak06, 03/12/2014
- Re: [cgal-discuss] Problem with Polyhedron_3 demo - intersection of objects with the same vertices, Sebastien Loriot (GeometryFactory), 03/12/2014
- Re: [cgal-discuss] Problem with Polyhedron_3 demo - intersection of objects with the same vertices, swistak06, 03/13/2014
