Re: [cgal-discuss] Problem with Polyhedron_3 demo - intersection of objects with the same vertices
- To:
- Subject: Re: [cgal-discuss] Problem with Polyhedron_3 demo - intersection of objects with the same vertices
- Date: Mon, 10 Mar 2014 09:04:35 +0100
On 03/08/2014 01:46 PM, swistak06 wrote:
Sebastien, thank you a lot! With your advices it works perfectly. You really
helped me a lot.
Let me ask about one more thing. I would like to get most possibly precise
coordinates for intersecting points. I mean - I can express all vertices of
a given two intersecting polyhedra by 4 integers instead of real number (it
is a kind of linear combination of one real number with only integer
parameters). I can define 4 basic arithmetic operations for my real numbers
expresssed by these 4 integers. This should allow me to perform all
calculations without rounding errors - analitically.
Do you think it would be possible to easily apply this simple 4-digit
calculator to the CGAL code for intersection algorithm?
It should be possible but maybe not easy if you're a CGAL beginner.
What package are you using?
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Problem-with-Polyhedron-3-demo-intersection-of-objects-with-the-same-vertices-tp4658911p4658926.html
- [cgal-discuss] Problem with Polyhedron_3 demo - intersection of objects with the same vertices, swistak06, 03/06/2014
- Re: [cgal-discuss] Problem with Polyhedron_3 demo - intersection of objects with the same vertices, Sebastien Loriot (GeometryFactory), 03/06/2014
- Re: [cgal-discuss] Problem with Polyhedron_3 demo - intersection of objects with the same vertices, swistak06, 03/06/2014
- Re: [cgal-discuss] Problem with Polyhedron_3 demo - intersection of objects with the same vertices, swistak06, 03/08/2014
- Re: [cgal-discuss] Problem with Polyhedron_3 demo - intersection of objects with the same vertices, Sebastien Loriot (GeometryFactory), 03/10/2014
- Re: [cgal-discuss] Problem with Polyhedron_3 demo - intersection of objects with the same vertices, swistak06, 03/12/2014
- Re: [cgal-discuss] Problem with Polyhedron_3 demo - intersection of objects with the same vertices, Sebastien Loriot (GeometryFactory), 03/12/2014
- Re: [cgal-discuss] Problem with Polyhedron_3 demo - intersection of objects with the same vertices, swistak06, 03/13/2014
