cgal-discuss - Re: [cgal-discuss] Alpha Shape 2D: Input point index
  • To:
  • Subject: Re: [cgal-discuss] Alpha Shape 2D: Input point index
  • Date: Thu, 29 May 2014 07:07:55 +0200
You can try to build the triangulation (with simplex types suited for
the Alpha-shape of course) like in this example [1] or any
"insert_with_info*" example [2].
Then you can build the alpha shape from the triangulation [3].
Sebastien.
[1] http://doc.cgal.org/latest/Triangulation_2/Triangulation_2_2info_insert_with_pair_iterator_2_8cpp-example.html
[2] http://doc.cgal.org/latest/Triangulation_2/examples.html
[3] http://doc.cgal.org/latest/Alpha_shapes_2/classCGAL_1_1Alpha__shape__2.html#a9d026da2568aed80884a5053bae0039b
On 05/28/2014 09:24 PM, morrischen2008 wrote:
Hi everyone,
I am currently using Alpha Shape to construct the surface of a bunch of
points. The process is simple: the input is a bunch of points, and I get a
bunch of points as output. However, when I have indexes for the input
points, like this
input
index location
1 (1.0, 2.0)
2 (2.1, 2.3)
3 (2.3, 1.8)
731 (7.1, 9.3)
I want to have to get, in the output points, also the indexes, like this
output
index location
2 (2.1, 2.3)
333 (3.5, 7.8)
However, I do not know how to obtain the indexes in outputs. Anyone here can
help me with this? I will appreciate your kind help. Below is how I obtain
the output points.
First, use the constructor
Alpha_shape_2 A(input.begin(), input.end(), FT(0.0001));
, while "input" is a "list<Point_2>".
The output I can obtain from "A" is a bunch of points, by using the
iterators (I know I can also get a bunch of "Segment_2 as outputs as well"),
like this
for(Alpha_shape_vertices_iterator it = A.alpha_shape_vertices_begin();
it != A.alpha_shape_vertices_end();
++it) {
Vertex_handle vh = *it;
Point_2 p(vh->point().x(), vh->point().y());
output.push_back(p);
, while "output" is a "vector<Point_2>".
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Alpha-Shape-2D-Input-point-index-tp4659360.html
