- To:
- Cc: Dmitriy Morozov <>, Tom Peterka <>, Hal Finkel <>
- Subject: [cgal-discuss] Compiling CGAL on the BG/Q with an IBM XL C/C++ toolchain
- Date: Thu, 29 May 2014 11:20:03 -0400
Dear CGAL community,
First off, I would like to thank you for developing and maintaining CGAL. It is an excellent piece of software that I have found useful at various stages throughout my academic and professional career.
More recently, I have ported a CGAL-based application for the BG/Q architecture, specifically on mira (http://www.alcf.anl.gov/user-guides/mira-cetus-vesta) , compiling with an all IBM XL C/C++ toolchain.
While I was able to compile CGAL statically, I was running in to problems when compiling the CGAL portions of the application. The issue was that Mpzf.h was using GCC builtin functions that were not recognized by the IBM XL C/C++ compiler. The fix was to use the corresponding builtin functions for the IBM compiler.
Attached is the modified Mpzf header and a patch in case others find useful.
Best Regards,
George
George
// Copyright (c) 2013 // INRIA Saclay - Ile de France (France). // All rights reserved. // // This file is part of CGAL (www.cgal.org); you can redistribute it and/or // modify it under the terms of the GNU Lesser General Public License as // published by the Free Software Foundation; either version 3 of the License, // or (at your option) any later version. // // Licensees holding a valid commercial license may use this file in // accordance with the commercial license agreement provided with the software. // // This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE // WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. // // Author(s) : Marc Glisse #ifndef CGAL_MPZF_H #define CGAL_MPZF_H #include <cstdlib> #include <algorithm> #include <climits> #include <vector> #include <math.h> #include <cmath> #include <iostream> #include <stdexcept> #ifdef CGAL_USE_GMPXX # include <CGAL/gmpxx.h> #else # include <CGAL/gmp.h> #endif #include <CGAL/enum.h> #include <CGAL/Interval_nt.h> #include <CGAL/Gmpz.h> #include <CGAL/Gmpq.h> //#include <CGAL/Gmpzf.h> #include <CGAL/Coercion_traits.h> // The following is currently assumed in several places. I hope I am not // making too many other assumptions. // * limbs are 64 bits // * if using gcc, sizeof(long long)==8 // * mpn_neg(_n) exists // * IEEE double // * not too fancy endianness #if !defined(CGAL_DO_NOT_USE_MPZF) \ && __GNU_MP_VERSION * 10 + __GNU_MP_VERSION_MINOR >= 43 \ && GMP_NUMB_BITS == 64 #define CGAL_HAS_MPZF 1 // GMP-4.3.* has a different name for mpn_neg. #ifndef mpn_neg #define mpn_neg mpn_neg_n #endif // GMP before 5.0 doesn't provide mpn_copyi. #ifndef mpn_copyi #define mpn_copyi(dst, src, siz) std::copy((src), (src)+(siz), (dst)) #endif #include <boost/cstdint.hpp> #ifdef _MSC_VER #include <intrin.h> #pragma intrinsic(_BitScanForward64) #pragma intrinsic(_BitScanReverse64) #endif #ifdef __xlC__ #include "builtins.h" #endif #if defined(BOOST_MSVC) # pragma warning(push) # pragma warning(disable:4146 4244 4267 4800) // warning on - applied on unsigned number // conversion with loss of data // conversion with loss of data // int to bool performance #endif #if defined(__GNUC__) && defined(__GNUC_MINOR__) \ && (__GNUC__ * 100 + __GNUC_MINOR__) >= 408 \ && __cplusplus >= 201103L #define CGAL_CAN_USE_CXX11_THREAD_LOCAL #endif /* #ifdef CGAL_MPZF_NO_USE_CACHE # ifdef CGAL_MPZF_USE_CACHE # undef CGAL_MPZF_USE_CACHE # endif #else # if !defined(CGAL_MPZF_USE_CACHE) \ && defined(CGAL_HAS_THREADS) \ && !defined(CGAL_I_PROMISE_I_WONT_USE_MANY_THREADS) # define CGAL_MPZF_USE_CACHE 1 # endif #endif */ #define CGAL_MPZF_USE_CACHE 1 // On a dataset provided by Andreas, replacing Gmpq with this type in // Epick reduced the running time of the construction of a Delaunay // triangulation by a factor larger than 6 #if !defined(CGAL_HAS_THREADS) #define CGAL_MPZF_THREAD_LOCAL #define CGAL_MPZF_TLS #elif defined(CGAL_CAN_USE_CXX11_THREAD_LOCAL) #define CGAL_MPZF_THREAD_LOCAL thread_local #define CGAL_MPZF_TLS thread_local #elif defined(_MSC_VER) #define CGAL_MPZF_THREAD_LOCAL __declspec(thread) #define CGAL_MPZF_TLS #else #define CGAL_MPZF_THREAD_LOCAL __thread #define CGAL_MPZF_TLS // Too bad for the others #endif namespace CGAL { namespace Mpzf_impl { // Warning: these pools aren't generic at all! // Not thread-safe template <class T, class = void> struct pool1 { static T pop() { T ret = data.back(); data.pop_back(); return ret; } static void push(T t) { data.push_back(t); } static bool empty() { return data.empty(); } static const int extra = 0; private: // thread_local would be fine, but not __declspec(thread) and for most // compilers not __thread, since data is not POD. static std::vector<T> data; }; template <class T, class D> std::vector<T> pool1<T,D>::data; // Use an intrusive single-linked list instead (allocate one more limb and use // it to store the pointer to next), the difference isn't that noticable (still // the list wins). Neither is thread-safe (both can be with threadlocal, and // the list can be with an atomic compare-exchange (never tried)). With gcc, // TLS has a large effect on classes with constructor/destructor, but is free // for a simple pointer. The slowdown is because of PR55812. // Leaks at thread destruction template <class T, class = void> struct pool2 { static T pop() { T ret = data(); data() = ptr(data()); return ret; } static void push(T t) { ptr(t) = data(); data() = t; } static bool empty() { return data() == 0; } static const int extra = 1; // TODO: handle the case where a pointer is larger than a mp_limb_t private: BOOST_STATIC_ASSERT(sizeof(T) >= sizeof(T*)); static T& data () { static CGAL_MPZF_TLS T data_ = 0; return data_; } static T& ptr(T t) { t -= extra+1; return *reinterpret_cast<T*>(t); } }; #if defined(CGAL_CAN_USE_CXX11_THREAD_LOCAL) template <class T, class = void> struct pool3 { static T pop() { T ret = data(); data() = ptr(data()); return ret; } static void push(T t) { ptr(t) = data(); data() = t; } static bool empty() { return data() == 0; } static const int extra = 1; // TODO: handle the case where a pointer is larger than a mp_limb_t private: BOOST_STATIC_ASSERT(sizeof(T) >= sizeof(T*)); struct cleaner { T data_ = 0; ~cleaner(){ // Deallocate everything. As an alternative, we could store it in a // global location, for re-use by a later thread. while (!empty()) delete[] (pop() - (extra + 1)); } }; static T& data () { static thread_local cleaner obj; return obj.data_; } static T& ptr(T t) { t -= extra+1; return *reinterpret_cast<T*>(t); } }; #endif // No caching template <class T, class = void> struct no_pool { static T pop() { throw "Shouldn't be here!"; } static void push(T t) { delete [] (t - (extra+1)); } static bool empty() { return true; } static const int extra = 0; }; // Only used with an argument known not to be 0. inline int ctz (boost::uint64_t x) { #if defined(_MSC_VER) unsigned long ret; _BitScanForward64(&ret, x); return (int)ret; #elif defined(__xlC__) return __cnttz8 (x); #else // Assume long long is 64 bits return __builtin_ctzll (x); #endif } inline int clz (boost::uint64_t x) { #if defined(_MSC_VER) unsigned long ret; _BitScanReverse64(&ret, x); return 63 - (int)ret; #elif defined(__xlC__) return __cntlz8 (x); #else return __builtin_clzll (x); #endif } // In C++11, std::fill_n returns a pointer to the end, but in C++03, // it returns void. inline mp_limb_t* fill_n_ptr(mp_limb_t* p, int n, int c) { #if __cplusplus >= 201103L return std::fill_n (p, n, c); #else mp_limb_t* q = p + n; std::fill (p, q, c); //std::fill_n (p, n, c); //memset (p, sizeof(mp_limb_t)*n, c); return q; #endif } } // namespace Mpzf_impl #undef CGAL_MPZF_THREAD_LOCAL #undef CGAL_MPZF_TLS // TODO: // * make data==0 a valid state for number 0. Incompatible with the cache. I // tried, and it doesn't seem to help (may even hurt a bit). struct Mpzf { private: #ifdef CGAL_MPZF_USE_CACHE // More experiments to determine the best value would be good. It likely // depends on the usage. Note that pool2 is fast enough that a conditional // cache slows it down. A purely static cache (crash if it isn't large // enough) still wins by about 11% on the Delaunay_3 construction, but is // more complicated to handle. // Evaluating a polynomial in double will never require more than roughly // (2100*degree) bits, or (33*degree) mp_limb_t, which is very small. I // checked by including an array of 150 limbs in every Mpzf (that's where // the 11% number comes from). // BONUS: doing that is thread-safe! static const unsigned int cache_size = 8; #endif //#if !defined(CGAL_HAS_THREADS) || defined(CGAL_I_PROMISE_I_WONT_USE_MANY_THREADS) // typedef Mpzf_impl::pool2<mp_limb_t*,Mpzf> pool; //#elif defined(CGAL_CAN_USE_CXX11_THREAD_LOCAL) // typedef Mpzf_impl::pool3<mp_limb_t*,Mpzf> pool; //#else typedef Mpzf_impl::no_pool<mp_limb_t*,Mpzf> pool; //#endif mp_limb_t* data_; /* data_[0] is never 0 (except possibly for 0). */ inline mp_limb_t*& data() { return data_; }; inline mp_limb_t const* data() const { return data_; }; #ifdef CGAL_MPZF_USE_CACHE mp_limb_t cache[cache_size + 1]; #endif int size; /* Number of relevant limbs in data_. */ int exp; /* The number is data_ (an integer) * 2 ^ (64 * exp). */ struct allocate{}; struct noalloc{}; void init(unsigned mini=2){ #ifdef CGAL_MPZF_USE_CACHE if (mini <= cache_size) { cache[0] = cache_size; data() = cache + 1; return; } #endif if(!pool::empty()){ data() = pool::pop(); if(data()[-1] >= mini) return; // TODO: when mini==2, no need to check delete[] (data() - (pool::extra+1)); // too small, useless } if(mini<2) mini=2; data() = (new mp_limb_t[mini+(pool::extra+1)]) + (pool::extra+1); data()[-1] = mini; } void clear(){ while(*--data()==0); // in case we skipped final zeroes #ifdef CGAL_MPZF_USE_CACHE if (data() == cache) return; #endif ++data(); pool::push(data()); } Mpzf(noalloc){} Mpzf(allocate,int i) { init(i); } public: static void clear_pool () { while (!pool::empty()) delete[] (pool::pop() - (pool::extra + 1)); } ~Mpzf(){ clear(); } Mpzf(): size(0), exp(0) { init(); } Mpzf& operator=(Mpzf const& x){ unsigned asize=std::abs(x.size); if(asize==0) { exp=0; size=0; return *this; } if(this==&x) return *this; while(*--data()==0); // factor that code somewhere? if(*data()<asize){ #ifdef CGAL_MPZF_USE_CACHE if (data() != cache) #endif delete[] (data() - pool::extra); init(asize); } else ++data(); size=x.size; exp=x.exp; mpn_copyi(data(),x.data(),asize); return *this; } Mpzf(Mpzf const& x){ int asize=std::abs(x.size); init(asize); size=x.size; exp=x.exp; if(size!=0) mpn_copyi(data(),x.data(),asize); } #if !defined(CGAL_CFG_NO_CPP0X_RVALUE_REFERENCE) \ && !defined(CGAL_MPZF_USE_CACHE) Mpzf(Mpzf&& x):data_(x.data()),size(x.size),exp(x.exp){ x.init(); // yes, that's a shame... x.size = 0; x.exp = 0; } Mpzf& operator=(Mpzf&& x){ std::swap(size,x.size); exp = x.exp; std::swap(data(),x.data()); return *this; } friend Mpzf operator-(Mpzf&& x){ Mpzf ret = std::move(x); ret.size = -ret.size; return ret; } #endif Mpzf(int i) : exp(0) { // assume that int is smaller than mp_limb_t init(); if (i == 0) { size = 0; } else if (i > 0) { size = 1; data()[0] = i; } else /* (i < 0) */ { size =-1; data()[0] = -(mp_limb_t)i; } // cast to mp_limb_t because -INT_MIN is undefined } Mpzf(unsigned int i) : exp(0) { // assume that int is smaller than mp_limb_t init(); if (i == 0) { size = 0; } else /* (i > 0) */ { size = 1; data()[0] = i; } } Mpzf(long i) : exp(0) { // assume that long is smaller than mp_limb_t init(); if (i == 0) { size = 0; } else if (i > 0) { size = 1; data()[0] = i; } else /* (i < 0) */ { size =-1; data()[0] = -(mp_limb_t)i; } // cast to mp_limb_t because -LONG_MIN is undefined } Mpzf(unsigned long i) : exp(0) { // assume that long is smaller than mp_limb_t init(); if (i == 0) { size = 0; } else /* (i > 0) */ { size = 1; data()[0] = i; } } Mpzf(double d){ init(); using boost::uint64_t; union { #ifdef CGAL_LITTLE_ENDIAN struct { uint64_t man:52; uint64_t exp:11; uint64_t sig:1; } s; #else /* CGAL_BIG_ENDIAN */ //WARNING: untested! struct { uint64_t sig:1; uint64_t exp:11; uint64_t man:52; } s; #endif double d; } u; u.d = d; uint64_t m; uint64_t dexp = u.s.exp; CGAL_assertion_msg(dexp != 2047, "Creating an Mpzf from infinity or NaN."); if (dexp == 0) { if (d == 0) { size=0; exp=0; return; } else { // denormal number m = u.s.man; ++dexp; } } else { m = (1LL<<52) | u.s.man; } int e1 = (int)dexp+13; // FIXME: make it more general! But not slower... BOOST_STATIC_ASSERT(GMP_NUMB_BITS == 64); int e2 = e1 % 64; exp = e1 / 64 - 17; // 52+1023+13==17*64 ? #if 0 // This seems very slightly faster if(Mpzf_impl::ctz(m)+e2>=64){ data()[0] = m >> (64-e2); size = 1; ++exp; }else{ data()[0] = m << e2; if(e2>11){ // Wrong test for denormals data()[1] = m >> (64-e2); size = 2; } else { size = 1; } } #else mp_limb_t d0 = (m << e2) & GMP_NUMB_MASK; mp_limb_t d1 = 0; if (e2 != 0) // shifting by 64 is UB d1 = m >> (GMP_NUMB_BITS - e2); if (d0 == 0) { data()[0] = d1; size = 1; ++exp; } else { data()[0] = d0; if (d1 == 0) { size = 1; } else { data()[1] = d1; size = 2; } } #endif if(u.s.sig) size=-size; //assert(to_double()==IA_force_to_double(d)); } #ifdef CGAL_USE_GMPXX Mpzf(mpz_class const&z){ init_from_mpz_t(z.get_mpz_t()); } #endif Mpzf(Gmpz const&z){ init_from_mpz_t(z.mpz()); } void init_from_mpz_t(mpz_t const z){ exp=mpz_scan1(z,0)/GMP_NUMB_BITS; size=mpz_size(z)-exp; init(size); mpn_copyi(data(),z->_mp_d+exp,size); } #if 0 // For debug purposes only void print()const{ //std::cout << "size: " << size << std::endl; if(size==0) { std::cout << "zero\n"; return; } if(size<0) std::cout << "- "; int asize = std::abs(size); std::cout << std::hex; while(--asize>=0) { std::cout << data()[asize] << ' '; } std::cout << std::dec << "exp " << exp << ' '; std::cout << std::dec << "size " << size << ' '; asize = std::abs(size); std::cout << "double: " << std::ldexp((double)data()[asize-1],64*(exp+asize-1))*((size<0)?-1:1) << '\n'; } #endif friend int Mpzf_abscmp(Mpzf const&a, Mpzf const&b){ int asize=std::abs(a.size); int bsize=std::abs(b.size); // size==0 should mean exp==-infinity, like with double. // Since it doesn't, test for it explicitly. if (bsize == 0) return asize; if (asize == 0) return -1; int ah=asize+a.exp; int bh=bsize+b.exp; if(ah!=bh) return ah-bh; int minsize=(std::min)(asize,bsize); const mp_limb_t* adata=a.data()+(asize-1); const mp_limb_t* bdata=b.data()+(bsize-1); for(int i=0;i<minsize;++i,--adata,--bdata){ const mp_limb_t aa=*adata; const mp_limb_t bb=*bdata; if(aa!=bb) return (aa<bb)?-1:1; } return asize-bsize; // this assumes that we get rid of trailing zeros... } friend int Mpzf_cmp (Mpzf const&a, Mpzf const&b){ if ((a.size ^ b.size) < 0) return (a.size < 0) ? -1 : 1; int res = Mpzf_abscmp(a, b); return (a.size < 0) ? -res : res; } friend bool operator<(Mpzf const&a, Mpzf const&b){ if((a.size ^ b.size) < 0) return a.size < 0; return ((a.size < 0) ? Mpzf_abscmp(b, a) : Mpzf_abscmp(a, b)) < 0; } friend bool operator>(Mpzf const&a, Mpzf const&b){ return b<a; } friend bool operator>=(Mpzf const&a, Mpzf const&b){ return !(a<b); } friend bool operator<=(Mpzf const&a, Mpzf const&b){ return !(a>b); } friend bool operator==(Mpzf const&a, Mpzf const&b){ if (a.exp != b.exp || a.size != b.size) return false; if (a.size == 0) return true; return mpn_cmp(a.data(), b.data(), std::abs(a.size)) == 0; } friend bool operator!=(Mpzf const&a, Mpzf const&b){ return !(a==b); } private: static Mpzf aors(Mpzf const&a, Mpzf const&b, int bsize){ Mpzf res=noalloc(); if(bsize==0){ int size=std::abs(a.size); res.init(size); res.exp=a.exp; res.size=a.size; if(size!=0) mpn_copyi(res.data(),a.data(),size); return res; } int asize=a.size; if(asize==0){ int size=std::abs(bsize); res.init(size); res.exp=b.exp; res.size=bsize; mpn_copyi(res.data(),b.data(),size); return res; } if((asize^bsize)>=0){ // Addition int absasize=std::abs(asize); int absbsize=std::abs(bsize); const mp_limb_t* adata=a.data(); const mp_limb_t* bdata=b.data(); int aexp=a.exp; int bexp=b.exp; if(aexp<bexp){ res.exp=a.exp; aexp=0; bexp=b.exp-a.exp; } else { res.exp=b.exp; aexp=a.exp-b.exp; bexp=0; } res.init((std::max)(absasize+aexp,absbsize+bexp)+1); mp_limb_t* rdata=res.data(); res.size=0; // TODO: if aexp>0, swap a and b so we don't repeat the code. if(0<bexp){ if(absasize<=bexp){ // no overlap mpn_copyi(rdata, adata, absasize); rdata+=absasize; rdata=Mpzf_impl::fill_n_ptr(rdata,bexp-absasize,0); mpn_copyi(rdata, bdata, absbsize); res.size=absbsize+bexp; if(bsize<0) res.size=-res.size; return res; } else { mpn_copyi(rdata, adata, bexp); adata+=bexp; absasize-=bexp; rdata+=bexp; res.size=bexp; } } else if(0<aexp){ if(absbsize<=aexp){ // no overlap mpn_copyi(rdata, bdata, absbsize); rdata+=absbsize; rdata=Mpzf_impl::fill_n_ptr(rdata,aexp-absbsize,0); mpn_copyi(rdata, adata, absasize); res.size=absasize+aexp; if(asize<0) res.size=-res.size; return res; } else { mpn_copyi(rdata, bdata, aexp); bdata+=aexp; absbsize-=aexp; rdata+=aexp; res.size=aexp; } } if(absasize>=absbsize){ mp_limb_t carry=mpn_add(rdata,adata,absasize,bdata,absbsize); res.size+=absasize; if(carry!=0){ res.size++; rdata[absasize]=carry; } } else { mp_limb_t carry=mpn_add(rdata,bdata,absbsize,adata,absasize); res.size+=absbsize; if(carry!=0){ res.size++; rdata[absbsize]=carry; } } // unnecessary if a.exp != b.exp while(/*res.size>0&&*/res.data()[0]==0){--res.size;++res.data();++res.exp;} if(bsize<0) res.size=-res.size; } else { // Subtraction const Mpzf *x, *y; int xsize=a.size; int ysize=bsize; int cmp=Mpzf_abscmp(a,b); if(cmp==0){ res.init(); res.size=0; res.exp=0; return res; } if(cmp<0) { x=&b; y=&a; std::swap(xsize, ysize); } else { x=&a; y=&b; } int absxsize=std::abs(xsize); int absysize=std::abs(ysize); const mp_limb_t* xdata=x->data(); const mp_limb_t* ydata=y->data(); int xexp=x->exp; int yexp=y->exp; if(xexp<yexp){ res.exp=xexp; yexp-=xexp; xexp=0; } else { res.exp=yexp; xexp-=yexp; yexp=0; } res.init((std::max)(absxsize+xexp,absysize+yexp)+1); mp_limb_t* rdata=res.data(); res.size=0; bool carry1=false; if(0<yexp){ // must have overlap since x is larger mpn_copyi(rdata, xdata, yexp); xdata+=yexp; absxsize-=yexp; rdata+=yexp; res.size=yexp; } else if(0<xexp){ if(absysize<=xexp){ // no overlap mpn_neg(rdata, ydata, absysize); // assert that it returns 1 rdata+=absysize; rdata=Mpzf_impl::fill_n_ptr(rdata,xexp-absysize,-1); mpn_sub_1(rdata, xdata, absxsize, 1); res.size=absxsize+xexp; if(res.data()[res.size-1]==0) --res.size; if(xsize<0) res.size=-res.size; return res; } else { mpn_neg(rdata, ydata, xexp); // assert that it returns 1 ydata+=xexp; absysize-=xexp; rdata+=xexp; res.size=xexp; carry1=true; // assumes no trailing zeros } } CGAL_assertion_code( mp_limb_t carry= ) mpn_sub(rdata, xdata, absxsize, ydata, absysize); if(carry1) CGAL_assertion_code( carry+= ) mpn_sub_1(rdata, rdata, absxsize, 1); CGAL_assertion(carry==0); res.size+=absxsize; while(/*res.size>0&&*/res.data()[res.size-1]==0) --res.size; while(/*res.size>0&&*/res.data()[0]==0){--res.size;++res.data();++res.exp;} if(xsize<0) res.size=-res.size; } return res; } public: friend Mpzf operator+(Mpzf const&a, Mpzf const&b){ return aors(a,b,b.size); } friend Mpzf operator-(Mpzf const&a, Mpzf const&b){ return aors(a,b,-b.size); } friend Mpzf operator*(Mpzf const&a, Mpzf const&b){ int asize=std::abs(a.size); int bsize=std::abs(b.size); int siz=asize+bsize; Mpzf res(allocate(),siz); if(asize==0||bsize==0){res.exp=0;res.size=0;return res;} res.exp=a.exp+b.exp; mp_limb_t high; if(asize>=bsize) high = mpn_mul(res.data(),a.data(),asize,b.data(),bsize); else high = mpn_mul(res.data(),b.data(),bsize,a.data(),asize); if(high==0) --siz; if(res.data()[0]==0) { ++res.data(); ++res.exp; --siz; } res.size=((a.size^b.size)>=0)?siz:-siz; return res; } friend Mpzf Mpzf_square(Mpzf const&a){ int asize=std::abs(a.size); int siz=2*asize; Mpzf res(allocate(),siz); res.exp=2*a.exp; if(asize==0){res.size=0;return res;} mpn_sqr(res.data(),a.data(),asize); mp_limb_t high = res.data()[siz-1]; if(high==0) --siz; if(res.data()[0]==0) { ++res.data(); ++res.exp; --siz; } res.size=siz; return res; } friend Mpzf operator/(Mpzf const&a, Mpzf const&b){ // FIXME: Untested int asize=std::abs(a.size); int bsize=std::abs(b.size); int siz=asize+2-bsize; Mpzf res(allocate(),asize+2); if(bsize==0){throw std::range_error("Division by zero");} if(asize==0){res.exp=0;res.size=0;return res;} res.size=siz; res.exp=a.exp-b.exp; const mp_limb_t *adata = a.data(); const mp_limb_t *bdata = b.data(); mp_limb_t *qp = res.data(); mp_limb_t *rp = qp + siz; if(Mpzf_impl::ctz(adata[0]) >= Mpzf_impl::ctz(bdata[0])){ // Easy case --res.size; mpn_tdiv_qr(qp, rp, 0, adata, asize, bdata, bsize); CGAL_assertion_code( for (int i=0; i<bsize; ++i) if (rp[i] != 0) throw std::logic_error("non exact Mpzf division"); ) } else if(adata[-1]==0){ // We are lucky --adata; ++asize; --res.exp; mpn_tdiv_qr(qp, rp, 0, adata, asize, bdata, bsize); CGAL_assertion_code( for (int i=0; i<bsize; ++i) if (rp[i] != 0) throw std::logic_error("non exact Mpzf division"); ) } else{ --res.exp; Mpzf a2(allocate(),asize+1); a2.data()[0]=0; mpn_copyi(a2.data()+1,a.data(),asize); // No need to complete a2, we just want the buffer. //a2.size=(a.size<0)?(a.size-1):(a.size+1); //a2.exp = a.exp-1; mpn_tdiv_qr(qp, rp, 0, a2.data(), asize+1, bdata, bsize); CGAL_assertion_code( for (int i=0; i<bsize; ++i) if (rp[i] != 0) throw std::logic_error("non exact Mpzf division"); ) } while(/*res.size>0&&*/res.data()[res.size-1]==0) --res.size; //while(/*res.size>0&&*/res.data()[0]==0){--res.size;++res.data();++res.exp;} if((a.size^b.size)<0) res.size=-res.size; return res; } friend Mpzf Mpzf_gcd(Mpzf const&a, Mpzf const&b){ // FIXME: Untested if (a.size == 0) return b; if (b.size == 0) return a; int asize=std::abs(a.size); int bsize=std::abs(b.size); int atz=Mpzf_impl::ctz(a.data()[0]); int btz=Mpzf_impl::ctz(b.data()[0]); int rtz=(std::min)(atz,btz); Mpzf tmp(allocate(), asize); Mpzf res(allocate(), bsize); if (atz != 0) { mpn_rshift(tmp.data(), a.data(), asize, atz); if(tmp.data()[asize-1]==0) --asize; } else { mpn_copyi(tmp.data(), a.data(), asize); } if (btz != 0) { mpn_rshift(res.data(), b.data(), bsize, btz); if(res.data()[bsize-1]==0) --bsize; } else { mpn_copyi(res.data(), b.data(), bsize); } res.exp = 0; // Pick b.exp? or the average? 0 helps return 1 more often. if (asize < bsize) res.size = mpn_gcd(res.data(), res.data(), bsize, tmp.data(), asize); else res.size = mpn_gcd(res.data(), tmp.data(), asize, res.data(), bsize); if(rtz!=0) { mp_limb_t c = mpn_lshift(res.data(), res.data(), res.size, rtz); if(c) { res.data()[res.size]=c; ++res.size; } } return res; } friend bool Mpzf_is_square(Mpzf const&x){ if (x.size < 0) return false; if (x.size == 0) return true; // Assume that GMP_NUMB_BITS is even. return mpn_perfect_square_p (x.data(), x.size); } friend Mpzf Mpzf_sqrt(Mpzf const&x){ // FIXME: Untested if (x.size < 0) throw std::range_error("Sqrt of negative number"); if (x.size == 0) return 0; if (x.exp % 2 == 0) { Mpzf res(allocate(), (x.size + 1) / 2); res.exp = x.exp / 2; res.size = (x.size + 1) / 2; CGAL_assertion_code(mp_size_t rem=) mpn_sqrtrem(res.data(), 0, x.data(), x.size); CGAL_assertion(rem==0); return res; } else if (x.data()[-1] == 0) { Mpzf res(allocate(), (x.size + 2) / 2); res.exp = (x.exp - 1) / 2; res.size = (x.size + 2) / 2; CGAL_assertion_code(mp_size_t rem=) mpn_sqrtrem(res.data(), 0, x.data()-1, x.size+1); CGAL_assertion(rem==0); return res; } else { Mpzf res(allocate(), (x.size + 2) / 2); res.exp = (x.exp - 1) / 2; res.size = (x.size + 2) / 2; CGAL_assertion_code(mp_size_t rem=) mpn_sqrtrem(res.data(), 0, x.data(), x.size); CGAL_assertion(rem==0); mpn_lshift(res.data(), res.data(), res.size, GMP_NUMB_BITS / 2); return res; } } friend Mpzf operator-(Mpzf const&x){ Mpzf ret = x; ret.size = -ret.size; return ret; } Mpzf& operator+=(Mpzf const&x){ *this=*this+x; return *this; } Mpzf& operator-=(Mpzf const&x){ *this=*this-x; return *this; } Mpzf& operator*=(Mpzf const&x){ *this=*this*x; return *this; } bool is_canonical () const { if (size == 0) return true; if (data()[0] == 0) return false; if (data()[std::abs(size)-1] == 0) return false; return true; } bool is_zero () const { return size==0; } bool is_one () const { return exp==0 && size==1 && data()[0]==1; } CGAL::Sign sign () const { return CGAL::sign(size); } double to_double () const { // Assumes GMP_NUMB_BITS == 64 using std::ldexp; if(size==0) return 0; int asize = std::abs(size); mp_limb_t top = data()[asize-1]; double dtop = top; if(top >= (1LL<<53) || asize == 1) /* ok */ ; else { dtop += (double)data()[asize-2] * ldexp(1.,-GMP_NUMB_BITS); } return ldexp( (size<0) ? -dtop : dtop, (asize-1+exp) * GMP_NUMB_BITS); } std::pair<double, double> to_interval () const { // Assumes GMP_NUMB_BITS == 64 if (size == 0) return std::make_pair(0., 0.); double dl, dh; int asize = std::abs(size); int e = 64 * (asize - 1 + exp); mp_limb_t x = data()[asize-1]; int lz = Mpzf_impl::clz(x); if (lz <= 11) { if (lz != 11) { e += (11 - lz); x >>= (11 - lz); } dl = x; dh = x + 1; // Check for the few cases where dh=x works (asize==1 and the evicted // bits from x were 0s) } else if (asize == 1) { dl = dh = x; // conversion is exact } else { mp_limb_t y = data()[asize-2]; e -= (lz - 11); x <<= (lz - 11); y >>= (75 - lz); x |= y; dl = x; dh = x + 1; // Check for the few cases where dh=x works (asize==2 and the evicted // bits from y were 0s) } typedef Interval_nt<> IA; IA res (dl, dh); res = ldexp (res, e); if (size < 0) res = -res; return CGAL::to_interval(res); // Use ldexp(Interval_nt,int) to delegate the hard thinking // about over/underflow. } #ifdef CGAL_USE_GMPXX #ifndef CGAL_CFG_NO_CPP0X_EXPLICIT_CONVERSION_OPERATORS explicit #endif operator mpq_class () const { mpq_class q; export_to_mpq_t(q.get_mpq_t()); return q; } #endif #ifndef CGAL_CFG_NO_CPP0X_EXPLICIT_CONVERSION_OPERATORS explicit #endif operator Gmpq () const { Gmpq q; export_to_mpq_t(q.mpq()); return q; } void export_to_mpq_t(mpq_t q) const { /* q must be 0/1 before this call */ CGAL_precondition(mpq_cmp_ui(q,0,1)==0); if (size != 0) { mpz_import (mpq_numref (q), std::abs(size), -1, // data()[0] is the least significant part sizeof(mp_limb_t), 0, // native endianness inside mp_limb_t GMP_NAIL_BITS, // should be 0 data()); if (exp > 0) mpq_mul_2exp(q, q, (sizeof(mp_limb_t) * CHAR_BIT * exp)); else if (exp < 0) mpq_div_2exp(q, q, (sizeof(mp_limb_t) * CHAR_BIT * -exp)); if (size < 0) mpq_neg(q,q); } } #if 0 #ifndef CGAL_CFG_NO_CPP0X_EXPLICIT_CONVERSION_OPERATORS explicit #endif // This makes Mpzf==int ambiguous operator Gmpzf () const { mpz_t z; z->_mp_d=const_cast<mp_limb_t*>(data()); z->_mp_size=size; Gmpzf m(z); // Only works for a very limited range of exponents Gmpzf e(std::ldexp(1.,GMP_NUMB_BITS*exp)); return m*e; } #endif friend void simplify_quotient(Mpzf& a, Mpzf& b){ // Avoid quotient(2^huge_a/2^huge_b) a.exp -= b.exp; b.exp = 0; // Simplify with gcd? } }; // Copied from Gmpzf, not sure that's the best thing to do. inline std::ostream& operator<< (std::ostream& os, const Mpzf& a) { return os << a.to_double(); } inline std::istream& operator>> (std::istream& is, Mpzf& a) { double d; is >> d; if (is) a = d; return is; } template <> struct Algebraic_structure_traits< Mpzf > : public Algebraic_structure_traits_base< Mpzf, Integral_domain_without_division_tag > { typedef Tag_true Is_exact; typedef Tag_false Is_numerical_sensitive; struct Is_zero : public std::unary_function< Type, bool > { bool operator()( const Type& x ) const { return x.is_zero(); } }; struct Is_one : public std::unary_function< Type, bool > { bool operator()( const Type& x ) const { return x.is_one(); } }; struct Gcd : public std::binary_function< Type, Type, Type > { Type operator()( const Type& x, const Type& y ) const { return Mpzf_gcd(x, y); } }; struct Square : public std::unary_function< Type, Type > { Type operator()( const Type& x ) const { return Mpzf_square(x); } }; struct Integral_division : public std::binary_function< Type, Type, Type > { Type operator()( const Type& x, const Type& y ) const { return x / y; } }; struct Sqrt : public std::unary_function< Type, Type > { Type operator()( const Type& x) const { return Mpzf_sqrt(x); } }; struct Is_square : public std::binary_function< Type, Type&, bool > { bool operator()( const Type& x, Type& y ) const { // TODO: avoid doing 2 calls. if (!Mpzf_is_square(x)) return false; y = Mpzf_sqrt(x); return true; } bool operator()( const Type& x) const { return Mpzf_is_square(x); } }; }; template <> struct Real_embeddable_traits< Mpzf > : public INTERN_RET::Real_embeddable_traits_base< Mpzf , CGAL::Tag_true > { struct Sgn : public std::unary_function< Type, ::CGAL::Sign > { ::CGAL::Sign operator()( const Type& x ) const { return x.sign(); } }; struct To_double : public std::unary_function< Type, double > { double operator()( const Type& x ) const { return x.to_double(); } }; struct Compare : public std::binary_function< Type, Type, Comparison_result > { Comparison_result operator()( const Type& x, const Type& y ) const { return CGAL::sign(Mpzf_cmp(x,y)); } }; struct To_interval : public std::unary_function< Type, std::pair< double, double > > { std::pair<double, double> operator()( const Type& x ) const { return x.to_interval(); } }; }; CGAL_DEFINE_COERCION_TRAITS_FOR_SELF(Mpzf) CGAL_DEFINE_COERCION_TRAITS_FROM_TO(short ,Mpzf) CGAL_DEFINE_COERCION_TRAITS_FROM_TO(int ,Mpzf) CGAL_DEFINE_COERCION_TRAITS_FROM_TO(long ,Mpzf) CGAL_DEFINE_COERCION_TRAITS_FROM_TO(float ,Mpzf) CGAL_DEFINE_COERCION_TRAITS_FROM_TO(double ,Mpzf) CGAL_DEFINE_COERCION_TRAITS_FROM_TO(Gmpz ,Mpzf) #ifdef CGAL_USE_GMPXX CGAL_DEFINE_COERCION_TRAITS_FROM_TO(mpz_class,Mpzf) #endif } #if defined(BOOST_MSVC) # pragma warning(pop) #endif #endif // GMP_NUMB_BITS == 64 #endif // CGAL_MPZF_H
--- /projects/DarkUniverse_esp/software/CGAL-4.4/include/CGAL/Mpzf.h 2014-02-15 20:00:24.000000000 +0000 +++ Mpzf-modified-for-xlC.h 2014-05-29 14:45:59.237033000 +0000 @@ -67,6 +67,10 @@ #pragma intrinsic(_BitScanReverse64) #endif +#ifdef __xlC__ +#include "builtins.h" +#endif + #if defined(BOOST_MSVC) # pragma warning(push) # pragma warning(disable:4146 4244 4267 4800) @@ -189,20 +193,24 @@ // Only used with an argument known not to be 0. inline int ctz (boost::uint64_t x) { -#ifdef _MSC_VER +#if defined(_MSC_VER) unsigned long ret; _BitScanForward64(&ret, x); return (int)ret; +#elif defined(__xlC__) + return __cnttz8 (x); #else // Assume long long is 64 bits return __builtin_ctzll (x); #endif } inline int clz (boost::uint64_t x) { -#ifdef _MSC_VER +#if defined(_MSC_VER) unsigned long ret; _BitScanReverse64(&ret, x); return 63 - (int)ret; +#elif defined(__xlC__) + return __cntlz8 (x); #else return __builtin_clzll (x); #endif
- [cgal-discuss] Compiling CGAL on the BG/Q with an IBM XL C/C++ toolchain, George Zagaris, 05/29/2014
- Re: [cgal-discuss] Compiling CGAL on the BG/Q with an IBM XL C/C++ toolchain, Marc Glisse, 05/29/2014
- Re: [cgal-discuss] Compiling CGAL on the BG/Q with an IBM XL C/C++ toolchain, Marc Glisse, 05/30/2014
- Re: [cgal-discuss] Compiling CGAL on the BG/Q with an IBM XL C/C++ toolchain, George Zagaris, 05/30/2014
