- To:
- Subject: Re: [cgal-discuss] Alpha Shape 2D: Input point index
- Date: Fri, 30 May 2014 10:44:33 -0700 (PDT)
Thanks a lot Sebastien. Your advice works.
Following your advice [1], I successfully created the Delaunay triangulation with "index inserted in the vertices".
However, I failed to use the established Delaunay triangulation to build the alpha shape [3].Following your advice [1], I successfully created the Delaunay triangulation with "index inserted in the vertices".
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef K::FT FT;
typedef CGAL::Triangulation_vertex_base_with_info_2<unsigned, K> Vb;
typedef CGAL::Triangulation_data_structure_2<Vb,> Tds;
typedef CGAL::Delaunay_triangulation_2<K, Tds> Delaunay_2;
typedef CGAL::Alpha_shape_2<Delaunay> Alpha_shape_2;
Delaunay_2 T;
T.insert(points.begin(), points.end()); // Compile and runs fine until now
Alpha_shape_2 A(T); // compiler gives lots of errors!!!
Previously when I just used a bunch of points to construct alpha shape it works fine, like this:
typedef K::FT FT;
typedef CGAL::Alpha_shape_vertex_base_2<K> Vb;
typedef CGAL::Alpha_shape_face_base_2<K> Fb;
typedef CGAL::Triangulation_data_structure_2<Vb,Fb> Tds;
typedef CGAL::Delaunay_triangulation_2<K,Tds> Triangulation_2;
typedef CGAL::Alpha_shape_2<Triangulation_2> Alpha_shape_2;
typedef K::FT FT;
Alpha_shape_2 A(input.begin(), input.end()); // Works fine
Any advice to get rid of the compiler errror? I will highly appreciate it. Thanks.
On Thu, May 29, 2014 at 1:09 AM, Sebastien Loriot (GeometryFactory) [via cgal-discuss] <[hidden email]> wrote:
You can try to build the triangulation (with simplex types suited for
the Alpha-shape of course) like in this example [1] or any
"insert_with_info*" example [2].
Then you can build the alpha shape from the triangulation [3].
Sebastien.
[1]
http://doc.cgal.org/latest/Triangulation_2/Triangulation_2_2info_insert_with_pair_iterator_2_8cpp-example.html
[2] http://doc.cgal.org/latest/Triangulation_2/examples.html
[3]
http://doc.cgal.org/latest/Alpha_shapes_2/classCGAL_1_1Alpha__shape__2.html#a9d026da2568aed80884a5053bae0039b
On 05/28/2014 09:24 PM, morrischen2008 wrote:> Sent from the cgal-discuss mailing list archive at Nabble.com.
> Hi everyone,
> I am currently using Alpha Shape to construct the surface of a bunch of
> points. The process is simple: the input is a bunch of points, and I get a
> bunch of points as output. However, when I have indexes for the input
> points, like this
> input
> index location
> 1 (1.0, 2.0)
> 2 (2.1, 2.3)
> 3 (2.3, 1.8)
> 731 (7.1, 9.3)
> I want to have to get, in the output points, also the indexes, like this
> output
> index location
> 2 (2.1, 2.3)
> 333 (3.5, 7.8)
> However, I do not know how to obtain the indexes in outputs. Anyone here can
> help me with this? I will appreciate your kind help. Below is how I obtain
> the output points.
> First, use the constructor
> Alpha_shape_2 A(input.begin(), input.end(), FT(0.0001));
> , while "input" is a "list<Point_2>".
> The output I can obtain from "A" is a bunch of points, by using the
> iterators (I know I can also get a bunch of "Segment_2 as outputs as well"),
> like this
> for(Alpha_shape_vertices_iterator it = A.alpha_shape_vertices_begin();
> it != A.alpha_shape_vertices_end();
> ++it) {
> Vertex_handle vh = *it;
> Point_2 p(vh->point().x(), vh->point().y());
> output.push_back(p);
> , while "output" is a "vector<Point_2>".
> View this message in context: http://cgal-discuss.949826.n4.nabble.com/Alpha-Shape-2D-Input-point-index-tp4659360.html
If you reply to this email, your message will be added to the discussion below:http://cgal-discuss.949826.n4.nabble.com/Alpha-Shape-2D-Input-point-index-tp4659360p4659362.html
Morris
View this message in context: Re: Alpha Shape 2D: Input point index
- [cgal-discuss] Alpha Shape 2D: Input point index, morrischen2008, 05/28/2014
- Re: [cgal-discuss] Alpha Shape 2D: Input point index, Sebastien Loriot (GeometryFactory), 05/29/2014
- Re: [cgal-discuss] Alpha Shape 2D: Input point index, morrischen2008, 05/30/2014
