cgal-discuss - Re: [cgal-discuss] Compiling CGAL on the BG/Q with an IBM XL C/C++ toolchain
  • To:
  • Cc: Dmitriy Morozov <>, Tom Peterka <>, Hal Finkel <>
  • Subject: Re: [cgal-discuss] Compiling CGAL on the BG/Q with an IBM XL C/C++ toolchain
  • Date: Thu, 29 May 2014 20:21:57 -0400
Hi Marc,
Take a look here for some documentation: http://pic.dhe.ibm.com/infocenter/compbg/v121v141/index.jsp
Specifically take a look at:
(1) [XL C/C++ Compiler for Blue Gene/Q V12.1] => [Compiler Reference] => [Compiler Predefined Macros]
(2) [XL C/C++ Compiler for Blue Gene/Q V12.1] => [Compiler Reference] => [Compiler built-in functions]
That's the documentation I used.
Hope this helps.
Best,
George
On Thu, May 29, 2014 at 6:46 PM, Marc Glisse <> wrote:
On Thu, 29 May 2014, George Zagaris wrote:
Attached is the modified Mpzf header and a patch in case others find useful.
I am having trouble finding this information on IBM's website: what compilers define the macro __xlC__ exactly? And do they all support the __cnt[lt]z8 builtins? I would assume the linux and aix versions are fine (32 bit mode has already been excluded by the GMP test), but I am wondering about the z/OS or z/VM version.
I am also thinking of adding something like the attached patch so XL C++ is not too penalized compared to g++, but again I am not sure what macros I should check.
Since I doubt anyone wants to run CGAL on a mainframe I'll probably just go with __xlC__, but if you know the answer...
Marc Glisse
