- To:
- Subject: Re: [cgal-discuss] Python binding of Poisson_reconstruction_function
- Date: Fri, 06 Jun 2014 13:53:05 +0200
On 06/05/2014 01:34 PM, hcherkaoui wrote:
Thank you Sebastien,
I will first try the example in the wiki then try to mimic what's already
done in the Python-binding.
To do so, could you explain me the differents command-lines that I should
use, I have, for example, some problems with the compilation of the
_wrap.cxx generated.
I don't know what you did. The wiki should be self-contain and
it makes no sense that I write here what should already be in the wiki.
You should make a new post in the mailing list dedicated to
cgal-bindings giving more details about the error you have
(at least what you did+error message).
Sebastien.
Thanks
Regards
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Python-binding-of-Poisson-reconstruction-function-tp4659400p4659406.html
- [cgal-discuss] Python binding of Poisson_reconstruction_function, hcherkaoui, 06/04/2014
- Re: [cgal-discuss] Python binding of Poisson_reconstruction_function, Sebastien Loriot (GeometryFactory), 06/04/2014
- Re: [cgal-discuss] Python binding of Poisson_reconstruction_function, hcherkaoui, 06/05/2014
- Re: [cgal-discuss] Python binding of Poisson_reconstruction_function, Sebastien Loriot (GeometryFactory), 06/06/2014
