- To:
- Subject: Re: [cgal-discuss] Reading p/q formatted floting point numbers in cgal
- Date: Fri, 4 Jul 2014 08:25:00 +0200 (CEST)
On Thu, 3 Jul 2014, dg wrote:
Hello all,
I have a file with floating point numbers but they are stored in the file as
p/q format so as to have a better precision. How can we read such numbers
into CGAL ?
All the number types CGAL::Gmpq, mpq_class, CGAL::Quotient<whatever> should support reading such numbers with operator>>. If you want a double, you can then convert with CGAL::to_double. Did you hit any particular issue?
Marc Glisse
- [cgal-discuss] Reading p/q formatted floting point numbers in cgal, dg, 07/04/2014
- Re: [cgal-discuss] Reading p/q formatted floting point numbers in cgal, Marc Glisse, 07/04/2014
