cgal-discuss - Re: [cgal-discuss] Use of ESBTL and Skin Surface create errors
  • To:
  • Subject: Re: [cgal-discuss] Use of ESBTL and Skin Surface create errors
  • Date: Fri, 04 Jul 2014 08:45:51 +0200
I just gave it a try and it worked here.
Could you give some details about your platform and what error you encountered?
Sebastien.
On 07/03/2014 07:41 PM, Rinaldo wrote:
Dear Sebastien,
Thank you for your reply. I am using CGAL 4.4. The code is as follows:
#include <CGAL/Skin_surface_3.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/mesh_skin_surface_3.h>
#include <CGAL/Skin_surface_polyhedral_items_3.h>
#include <list>
#include <ESBTL/CGAL/EPIC_kernel_with_atom.h>
#include <ESBTL/default.h>
typedef ESBTL::CGAL::EPIC_kernel_with_atom K;
typedef ESBTL::CGAL::Default_system System;
typedef CGAL::Skin_surface_traits_3<K> Traits;
typedef CGAL::Skin_surface_3<Traits> Skin_surface_3;
typedef Skin_surface_3::FT FT;
typedef Skin_surface_3::Weighted_point Weighted_point;
typedef Weighted_point::Point Bare_point;
typedef CGAL::Polyhedron_3<K> Polyhedron;
#include <list>
#include <fstream>
#include "skin_surface_writer.h"
#include "extract_balls_from_pdb.h"
int main(int argc, char *argv[]) {
const char *filename;
if (argc == 2) {
filename = argv[1];
} else {
filename = "4lfq.pdb";
std::list<Weighted_point> l;
double shrinkfactor = 0.5;
//Container for molecular system
std::vector<System> systems;
// Retrieve input balls:
extract_balls_from_pdb<K>(filename,systems,std::back_inserter(l));
// Construct skin surface:
std::cout << "Constructing skin surface..." <<std::endl;
Skin_surface_3 skin_surface(l.begin(), l.end(), shrinkfactor);
// Extract mesh from the skin surface:
std::cout << "Meshing skin surface..." <<std::endl;
Polyhedron p;
CGAL::mesh_skin_surface_3(skin_surface, p);
std::cout << "Subdividing ..." << std::endl;
CGAL::subdivide_skin_surface_mesh_3(skin_surface, p, 1);
std::ofstream out("mesh.off");
out << p;
return 0;
*From:*Sebastien Loriot (GeometryFactory) [via cgal-discuss]
[ email] </user/SendEmail.jtp?type=node&node=4659518&i=0>]
*Sent:* quinta-feira, 3 de julho de 2014 02:33
*To:* Rinaldo
*Subject:* Re: Use of ESBTL and Skin Surface create errors
On 07/02/2014 10:45 PM, Rinaldo wrote:
> I am having the same problem using the latest version for both ESBTL and
> CGAL.
> Do you know if the problem of using subdivide_skin_surface_mesh_3
with ESBTL
> has been fixed?
> Best wishes,
> Rinaldo
The fixes have been integrated into the release 4.2. What version of
CGAL are you using?
Do you have a small example showing the pb?
Sebastien.
> View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Use-of-ESBTL-and-Skin-Surface-create-errors-tp4656653p4659514.html
> Sent from the cgal-discuss mailing list archive at Nabble.com.
*If you reply to this email, your message will be added to the
discussion below:*
http://cgal-discuss.949826.n4.nabble.com/Use-of-ESBTL-and-Skin-Surface-create-errors-tp4656653p4659516.html
To unsubscribe from Use of ESBTL and Skin Surface create errors, click here.
NAML
<http://cgal-discuss.949826.n4.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: RE: Use of ESBTL and Skin Surface create
errors
<http://cgal-discuss.949826.n4.nabble.com/Use-of-ESBTL-and-Skin-Surface-create-errors-tp4656653p4659518.html>
<http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com.
