- To: <>
- Subject: Re: [cgal-discuss] Bug in Triangle_3-Triangle_3 intersection?
- Date: Mon, 21 Jul 2014 12:31:26 +0100
Hi Sebastien,
yes, if I use the exact stuff it works fine. Again, it just seems strange that double is "not good enough" - it's not like one of triangles is 10 million times larger than the other or the intersection is almost nil (it is a segment with coordinates {6.791 3.52889 27.5591}, {6.791 6.82325 45.9274}).
Rostislav.
On 21/07/2014 06:46, Sebastien Loriot (GeometryFactory) wrote:
What if you are using CGAL::Exact_predicates_exact_constructions_kernel?
See also:
http://www.cgal.org/FAQ.html#inexact_NT
Sebastien.
On 07/20/2014 08:22 PM, Rostislav Khlebnikov wrote:
Hello guys,
I'm having the intersection procedure not returning correct results for
triangle-triangle intersection in 3D. I have compile a minimal example
that shows the problem:
#include <CGAL/Simple_cartesian.h>
typedef CGAL::Simple_cartesian<double> K;
typedef K::FT FT;
typedef K::Point_3 Point;
typedef K::Triangle_3 Triangle;
typedef K::Segment_3 Segment;
void main()
Triangle tri1 (Point(6.7910000000, -1.09375, -0.900025),
Point(6.791, 18.9, -0.9), Point(6.791, -1.09375, 144.321));
Triangle tri1a(Point(6.7910000001, -1.09375, -0.900025),
Triangle tri2(Point(7.8, 5.6, 6.7269), Point(5.9, 1.7, 45.955),
Point(7.9, 13.2, 45.893));
std::cout << CGAL::intersection(tri1, tri2) << " " <<
CGAL::intersection(tri1a, tri2);
The output of this code is "0 1" which is quite strange. Do you think it
is a bug for some special case or is it the floating-point problem? The
thing is - I don't feel like the values are big or small enough for
"double" to be insufficient. Is there anything I can do to fix this
problem without changing to Exact_predicates_exact_constructions_kernel?
I would really like to avoid this - I need performance over accuracy -
but I feel that in this case the accuracy is far off what one would
expect. I could even detect this special case and add 1e-8 or whateve to
one of the points - it just feels weird and looks like a bug to me.
CGAL installation info:
Windows 8.1, MSVS 2013, x64
CGAL 4.4 installed with the CGAL-4.4-Setup.exe installer and then built
with CMake and MSVS 2013.
All best,
Rostislav.
- [cgal-discuss] Bug in Triangle_3-Triangle_3 intersection?, Rostislav Khlebnikov, 07/20/2014
- Re: [cgal-discuss] Bug in Triangle_3-Triangle_3 intersection?, Sebastien Loriot (GeometryFactory), 07/21/2014
- Re: [cgal-discuss] Bug in Triangle_3-Triangle_3 intersection?, Rostislav Khlebnikov, 07/21/2014
