cgal-discuss - Re: [cgal-discuss] Bug in Triangle_3-Triangle_3 intersection?
  • To: <>
  • Subject: Re: [cgal-discuss] Bug in Triangle_3-Triangle_3 intersection?
  • Date: Mon, 21 Jul 2014 13:20:21 +0100
I will try that. Thank you, Sebastien!
On 21/07/2014 13:19, Sebastien Loriot (GeometryFactory) wrote:
On 07/21/2014 02:07 PM, Rostislav Khlebnikov wrote:
Hello Sebastien
thanks for the quick answer.
Yes, I looked into the code and it is indeed computed as you said. The
thing is, I don't intersect triangles directly - I just found two
triangles with incorrect result to make a minimal example.
I use AABB tree to get a section of mesh with a triangle representing a
viewport. I could use a plane query, but it's quite a bit slower
especially when the mesh is not intersected by the viewport at all.
Perhaps you could suggest some modification to
Triangle_3_Triangle_3_intersection.h that would make it more robust in
these cases (perhaps sacrificing some of the performance for that -
something like line direction vector normalization? It's just not quite
clear for me what causes the problem and that's why I decided to ask for
some advice from people more involved in CGAL.
I suggest to use a different traits class for the AABB-tree where
the Intersect_3 do the filtered construction I proposed.
Sebastien.
Rostislav.
On 21/07/2014 12:48, Sebastien Loriot (GeometryFactory) wrote:
IIRC, the intersection of the supporting planes if first computed and
the line is then intersected with one of the triangles.
In this setting, I'm not surprised you didn't get the correct result.
You could use some filtered construction when the intersection would be
computed with EPECK and then converter back to the kernel with inexact
construction.
Sebastien.
On 07/21/2014 01:31 PM, Rostislav Khlebnikov wrote:
Hi Sebastien,
yes, if I use the exact stuff it works fine. Again, it just seems
strange that double is "not good enough" - it's not like one of
triangles is 10 million times larger than the other or the intersection
is almost nil (it is a segment with coordinates {6.791 3.52889 27.5591},
{6.791 6.82325 45.9274}).
Rostislav.
On 21/07/2014 06:46, Sebastien Loriot (GeometryFactory) wrote:
What if you are using
CGAL::Exact_predicates_exact_constructions_kernel?
See also:
http://www.cgal.org/FAQ.html#inexact_NT
Sebastien.
On 07/20/2014 08:22 PM, Rostislav Khlebnikov wrote:
Hello guys,
I'm having the intersection procedure not returning correct results
for
triangle-triangle intersection in 3D. I have compile a minimal example
that shows the problem:
#include <CGAL/Simple_cartesian.h>
typedef CGAL::Simple_cartesian<double> K;
typedef K::FT FT;
typedef K::Point_3 Point;
typedef K::Triangle_3 Triangle;
typedef K::Segment_3 Segment;
void main()
Triangle tri1 (Point(6.7910000000, -1.09375, -0.900025),
Point(6.791, 18.9, -0.9), Point(6.791, -1.09375, 144.321));
Triangle tri1a(Point(6.7910000001, -1.09375, -0.900025),
Triangle tri2(Point(7.8, 5.6, 6.7269), Point(5.9, 1.7, 45.955),
Point(7.9, 13.2, 45.893));
std::cout << CGAL::intersection(tri1, tri2) << " " <<
CGAL::intersection(tri1a, tri2);
The output of this code is "0 1" which is quite strange. Do you
think it
is a bug for some special case or is it the floating-point problem?
The
thing is - I don't feel like the values are big or small enough for
"double" to be insufficient. Is there anything I can do to fix this
problem without changing to
I would really like to avoid this - I need performance over accuracy -
but I feel that in this case the accuracy is far off what one would
expect. I could even detect this special case and add 1e-8 or
whateve to
one of the points - it just feels weird and looks like a bug to me.
CGAL installation info:
Windows 8.1, MSVS 2013, x64
CGAL 4.4 installed with the CGAL-4.4-Setup.exe installer and then
built
with CMake and MSVS 2013.
All best,
Rostislav.
