- To:
- Subject: Re: [cgal-discuss] Bug in Triangle_3-Triangle_3 intersection?
- Date: Mon, 21 Jul 2014 13:48:52 +0200
IIRC, the intersection of the supporting planes if first computed and the line is then intersected with one of the triangles.
In this setting, I'm not surprised you didn't get the correct result.
You could use some filtered construction when the intersection would be
computed with EPECK and then converter back to the kernel with inexact
construction.
Sebastien.
On 07/21/2014 01:31 PM, Rostislav Khlebnikov wrote:
Hi Sebastien,
yes, if I use the exact stuff it works fine. Again, it just seems
strange that double is "not good enough" - it's not like one of
triangles is 10 million times larger than the other or the intersection
is almost nil (it is a segment with coordinates {6.791 3.52889 27.5591},
{6.791 6.82325 45.9274}).
Rostislav.
On 21/07/2014 06:46, Sebastien Loriot (GeometryFactory) wrote:
What if you are using CGAL::Exact_predicates_exact_constructions_kernel?
See also:
http://www.cgal.org/FAQ.html#inexact_NT
Sebastien.
On 07/20/2014 08:22 PM, Rostislav Khlebnikov wrote:
Hello guys,
I'm having the intersection procedure not returning correct results for
triangle-triangle intersection in 3D. I have compile a minimal example
that shows the problem:
#include <CGAL/Simple_cartesian.h>
typedef CGAL::Simple_cartesian<double> K;
typedef K::FT FT;
typedef K::Point_3 Point;
typedef K::Triangle_3 Triangle;
typedef K::Segment_3 Segment;
void main()
Triangle tri1 (Point(6.7910000000, -1.09375, -0.900025),
Point(6.791, 18.9, -0.9), Point(6.791, -1.09375, 144.321));
Triangle tri1a(Point(6.7910000001, -1.09375, -0.900025),
Triangle tri2(Point(7.8, 5.6, 6.7269), Point(5.9, 1.7, 45.955),
Point(7.9, 13.2, 45.893));
std::cout << CGAL::intersection(tri1, tri2) << " " <<
CGAL::intersection(tri1a, tri2);
The output of this code is "0 1" which is quite strange. Do you think it
is a bug for some special case or is it the floating-point problem? The
thing is - I don't feel like the values are big or small enough for
"double" to be insufficient. Is there anything I can do to fix this
problem without changing to Exact_predicates_exact_constructions_kernel?
I would really like to avoid this - I need performance over accuracy -
but I feel that in this case the accuracy is far off what one would
expect. I could even detect this special case and add 1e-8 or whateve to
one of the points - it just feels weird and looks like a bug to me.
CGAL installation info:
Windows 8.1, MSVS 2013, x64
CGAL 4.4 installed with the CGAL-4.4-Setup.exe installer and then built
with CMake and MSVS 2013.
All best,
Rostislav.
- [cgal-discuss] Bug in Triangle_3-Triangle_3 intersection?, Rostislav Khlebnikov, 07/20/2014
- Re: [cgal-discuss] Bug in Triangle_3-Triangle_3 intersection?, Sebastien Loriot (GeometryFactory), 07/21/2014
- Re: [cgal-discuss] Bug in Triangle_3-Triangle_3 intersection?, Rostislav Khlebnikov, 07/21/2014
