- To:
- Subject: Re: [cgal-discuss] AABB tree with custom iterator for VTK polydata
- Date: Tue, 23 Sep 2014 09:59:38 +0200
It would help if you write small answers.
I'm not able to reproduce any pb.
Please tell me what should I do to reproduce the error.
Note that AABB-tree does not have specific about the iterator
except that it must be a valid ForwardIterator.
Thanks,
Sebastien.
On 09/22/2014 06:09 PM, Rostislav Khlebnikov wrote:
Hello Sebastien,
I made some more experiments and here are the results.
First, the debug version for MSVS 2013. It seems to me that the fact
that the release version works might be just a lucky coincidence. Please
refer to the code attached (I tried to keep it as clean as possible and
even removed any references to VTK, but maintained the overall iterator
structure). What I witnessed when debugging is that the triangle
returned for bbox computation (see AABB_traits.h, Line 356) is
invalidated before the bbox() method is called. Diving deeper into the
code I noticed that the problem (if it is in fact a problem) is in
property_map.h, Line 54. The get() method accepts iterator by value,
meaning in my case that the iterator is created, the within-iterator
cache is created, and then upon return from get() function, the iterator
is destroyed, making the cached triangle (returned by reference)
invalid! When I changed this line to accept the iterator by const
reference, the debug version also started working well. Note, that
changing the Reference type in the iterator_facade to K::Triangle_3 also
solves the problem (at some expense of performance I assume).
For Linux version, however, this changes nothing, but something tells me
that there is still something wrong with the iterator. I am completely
lost what though.
With Linux, I decided to start afresh and installed Ubuntu 14.04 LTS.
The default compiler that comes with this version is gcc 4.8.2. Once I
had no luck with it, I installed 4.9.1 although I don't think the
compiler is the issue. As an additional measure, I removed the
-std=c++11 flag (just in case). I have also used CGAL 4.5-beta1. I have
attached the code with a #define within that show what I observe. Notice
that this experiments use the Reference type of iterator_facade set to
K::Triangle_3 (if SHOW_WORKING_VERSION is set to 0), so the
aforementioned issue within property_map.h should have no effect.
Basically the only code that doesn't hang for me is: when the Reference
type of iterator_facade is left as default, and my iterator has the copy
constructor /*which writes something about the _cache variable to the
std::out*/. I would guess that this is a similar "lucky coincidence" as
with the MSVS 2013 release version. Some combinations of writing to
std::cout or not, having a copy constructor or not, and setting the
Reference type to Value type or leaving it at Value& lead to seg fault,
but something tells me that this is quite irrelevant.
Anyway, what I would like to know is: does my iterator not satisfy some
requirements of the AABB_Tree? Or perhaps my "proposed" change to
property_map makes sense?
Also, it seems to me that the whole thing with this caching iterator is
pretty useless - originally I thought that it would help save memory
(which it would if the triangles were to be built on the fly), but I
think at least for now performance is more important for me. In this
case, it would be easier and less code if I basically just converted the
triangles from VTK to CGAL and stored them in an
std::vector<K::Triangle_3> which would likely work just as fast and 100%
correctly. Do you think this is correct?
Thank you,
Rostislav.
On 22/09/2014 14:50, Sebastien Loriot (GeometryFactory) wrote:
On 09/18/2014 08:08 PM, Khlebnikov, Rostislav wrote:
Please let me know if a minimal code with data would help - I'd be
happy to send it.
Yes please.
Sebastien.
Rostislav.
On 18 Sep 2014, at 18:25, "Rostislav Khlebnikov"
wrote:
Hello,
I have some very weird behavior of the same code on different
platforms and for different build types.
So basically the code works fine only on one configuration out of
four for me. It is Release version on Windows (Windows, MSVS 2013,
x64, CGAL 4.4 installed with the CGAL-4.4-Setup.exe installer and
then built with CMake and MSVS 2013).
The Debug version always returns zero intersections. The code and
the data are literally the same.
I have also tried to build the Linux version. I used Ubuntu 13.10
x64, gcc 4.8.1, libgmp and libmpfr installed using apt-get, and CGAL
4.4 compiled from source using CMake. The only flag I changed when
building CGAL and my test application is adding -std=c++11 - i.e.
they are compiled with -frounding-math.
Here, none of the versions actually work. The Debug version reports
incorrect (I mean not even close to the windows ones) results or
crashes with segfault, and the Release version hangs on building the
AABB tree if I use my custom iterator or crashes with segfault is I
use a simple std::list of triangles.
Do you have any hints why this might happen?
Thank you for your help,
Rostislav.
On 10/08/2014 15:24, Rostislav Khlebnikov wrote:
Hello Sebastien,
yes, indeed - it is the tree.build() call that makes everything
logical.
Honestly, I just should RTFM better - I thought that
accelerate_distance_queries() call was responsible for this, which
does no good for intersections anyway and just eats more memory for
KD tree.
So, I reverted to the iterator which returns triangles by value
constructing them on-the-fly and set the CGAL::Tag_true as the last
template parameter for primitive.
The test results with are mixed (Isect shows the average over 100
all_intersections() calls, timed with QueryPerformanceCounter):
NO CACHE:
Build tree: 8.97505s
nConversions: 82950772
Isect: 2.97875ms
CGAL CACHE:
Build tree: 8.69819s
nConversions: 72620628
Isect: 1.97289ms
WITHIN-ITERATOR CACHE:
Build tree: 0.647395s
nConversions: 568938
Isect: 1.81151ms
Hope this helps,
Rostislav.
On 10/08/2014 14:39, Sebastien Loriot (GeometryFactory) wrote:
On 08/09/2014 05:59 PM, Rostislav Khlebnikov wrote:
Hello again,
I am just quite curious that the first call to the
all_intersections is
very very slow compared to the rest. For example for mesh with about
500k triangles, the first call takes about 10 seconds, while the
all the
following ones with the same cutting query take about 3
milliseconds,
giving the difference of 3000 times! Is there some lazy
processing going
on that are triggered by the first call? Is this normal anyway?
Try to call tree.build() before, it is probably the construction
of the
tree that is happening at the first call.
Sebastien.
Additionally, by adding the cached converted triangle as a member of
Triangles_const_iterator, setting the reference template
parameter to
default and returning K::Triangle_3 const& from derefence() will
speed
up the first 10 times (down to 1 second) and also speed up the
subsequent calls to about 2 milliseconds. It is clear why this
happens,
but I just wanted to mention it.
Note that the last template parameter of AABB_triangle_primitive
can be
used to cache the triangle in the primitive. Could you give it a try
and confirm it is as fast as your setting?
Thanks,
Sebastien.
So, if you could answer the questions in the first paragraph - that
would be absolutely great!
Thank you,
Rostislav.
On 08/08/2014 00:30, Rostislav Khlebnikov wrote:
Hello Sebastien,
yes, indeed changing the signature of the
Triangles_const_iterator to
class Triangles_const_iterator
: public boost::iterator_facade<
, K::Triangle_3 const // Value
, boost::forward_traversal_tag // CategoryOrTraversal
, *K::Triangle_3*
helped resolving the issue. Just writing this to say thanks to
you and
perhaps help anyone looking into similar problem.
Thanks again,
Rostislav.
PS: still weird that it worked in release :)
On 07/08/2014 23:33, Sebastien Loriot (GeometryFactory) wrote:
Thanks for the minimal reproducible example!
Actually, if you read again the doc of boost::iterator_facade
you'll see you're using the default for reference, which is
value&. In your case, reference should be value (Triangle is a
temporary).
Sebastien.
On 08/07/2014 11:14 PM, Rostislav Khlebnikov wrote:
Hi everyone,
I'm using AABB_tree to compute intersections of a VTK poly
data with a
plane. When I just convert the triangles from VTK to CGAL and
store
them
in std list, everything works fine. However, I would like to
reduce
storage requirements by creating a triangle iterator that
iterates over
the VTK triangle data.
Code in main.cpp here shows how I do it
http://pastebin.com/kNLQevXV
<http://pastebin.com/sKPFHTT2>
In Release version everything works fine, but in Debug version -
intersections are never found! (Funnily enough it's a debug
version
that
fails). I tried finding the problem - but I don't seem to
understand
it.
What I found is that when CGAL uses the kernel to convert from
Triangle_3 to TriangleC3 with rep() and then uses this
TriangleC3's
vertex() method on line 1909 in function_objects.h, the
TriangleC3
'base' variable becomes corrupted during get(base) call at
line 94 in
Triangle_3.h (i.e. correct coordinates are overwritten in what
seems to
be stack initialization in function call when I looked at
disassembly).
Is it something wrong that I do with my custom iterator? Or
perhaps
it's
a bug in VS2013 compiler (I saw some bug reports regarding stack
corruption for VS2012 such as this
<http://stackoverflow.com/questions/11000798/structure-parameter-corrupted-on-function-call>,
so perhaps it's not completely resolved).
I attached all the code, input files and cmake file, so if
someone who
has VTK and CGAL could quitckly test it on their platform. For
me the
release version returns 54 intersections and debug - 0.
Thank you in advance,
Rostislav.
CGAL installation info:
Windows 8.1, MSVS 2013, x64
CGAL 4.4 installed with the CGAL-4.4-Setup.exe installer and then
built
with CMake and MSVS 2013.
- Re: [cgal-discuss] AABB tree with custom iterator for VTK polydata, Rostislav Khlebnikov, 09/18/2014
- Re: [cgal-discuss] AABB tree with custom iterator for VTK polydata, Khlebnikov, Rostislav, 09/18/2014
- Re: [cgal-discuss] AABB tree with custom iterator for VTK polydata, Sebastien Loriot (GeometryFactory), 09/22/2014
- Re: [cgal-discuss] AABB tree with custom iterator for VTK polydata, Rostislav Khlebnikov, 09/22/2014
- Re: [cgal-discuss] AABB tree with custom iterator for VTK polydata, Sebastien Loriot (GeometryFactory), 09/23/2014
- Re: [cgal-discuss] AABB tree with custom iterator for VTK polydata, Rostislav Khlebnikov, 09/23/2014
