Hello Sebastien,
to reproduce my problem, open the main_win.cpp file in debug mode
with visual studio compiler (I used MSVS2013) - the output will end
with "0 intersection(s) with plane", which is incorrect - it should
be 9 intersections. The release version outputs the correct number.
The problem how I see it is described in the first paragraph of my
previous answer.
Then, open main_lin.cpp, change line 83 to "#define
SHOW_WORKING_VERSION 0" and compile with gcc compiler (I did
it in linux, but likely mingw build will show the similar behavior).
What I see is that the code outputs "Building tree" and hangs up. If
the line 83 is changed back to "#define SHOW_WORKING_VERSION 1"
- there's some additional output, but the the tree is built and
the output is correct. The problem is that if I remove the copy
constructor from the iterator or even remove the output to std::out
- the application will hang. I described this in the second
paragraph of my previous answer.
Note that both builds were made in 64 bits.
Hope this helps to reproduce the problem.
Thank you,
Rostislav.
On 23/09/2014 08:59, Sebastien Loriot
(GeometryFactory) wrote:
It
would help if you write small answers.
I'm not able to reproduce any pb.
Please tell me what should I do to reproduce the error.
Note that AABB-tree does not have specific about the iterator
except that it must be a valid ForwardIterator.
Thanks,
Sebastien.
On 09/22/2014 06:09 PM, Rostislav Khlebnikov wrote:
Hello Sebastien,
I made some more experiments and here are the results.
First, the debug version for MSVS 2013. It seems to me that the
fact
that the release version works might be just a lucky
coincidence. Please
refer to the code attached (I tried to keep it as clean as
possible and
even removed any references to VTK, but maintained the overall
iterator
structure). What I witnessed when debugging is that the triangle
returned for bbox computation (see AABB_traits.h, Line 356) is
invalidated before the bbox() method is called. Diving deeper
into the
code I noticed that the problem (if it is in fact a problem) is
in
property_map.h, Line 54. The get() method accepts iterator by
value,
meaning in my case that the iterator is created, the
within-iterator
cache is created, and then upon return from get() function, the
iterator
is destroyed, making the cached triangle (returned by reference)
invalid! When I changed this line to accept the iterator by
const
reference, the debug version also started working well. Note,
that
changing the Reference type in the iterator_facade to
K::Triangle_3 also
solves the problem (at some expense of performance I assume).
For Linux version, however, this changes nothing, but something
tells me
that there is still something wrong with the iterator. I am
completely
lost what though.
With Linux, I decided to start afresh and installed Ubuntu 14.04
LTS.
The default compiler that comes with this version is gcc 4.8.2.
Once I
had no luck with it, I installed 4.9.1 although I don't think
the
compiler is the issue. As an additional measure, I removed the
-std=c++11 flag (just in case). I have also used CGAL 4.5-beta1.
I have
attached the code with a #define within that show what I
observe. Notice
that this experiments use the Reference type of iterator_facade
set to
K::Triangle_3 (if SHOW_WORKING_VERSION is set to 0), so the
aforementioned issue within property_map.h should have no
effect.
Basically the only code that doesn't hang for me is: when the
Reference
type of iterator_facade is left as default, and my iterator has
the copy
constructor /*which writes something about the _cache variable
to the
std::out*/. I would guess that this is a similar "lucky
coincidence" as
with the MSVS 2013 release version. Some combinations of writing
to
std::cout or not, having a copy constructor or not, and setting
the
Reference type to Value type or leaving it at Value& lead to
seg fault,
but something tells me that this is quite irrelevant.
Anyway, what I would like to know is: does my iterator not
satisfy some
requirements of the AABB_Tree? Or perhaps my "proposed" change
to
property_map makes sense?
Also, it seems to me that the whole thing with this caching
iterator is
pretty useless - originally I thought that it would help save
memory
(which it would if the triangles were to be built on the fly),
but I
think at least for now performance is more important for me. In
this
case, it would be easier and less code if I basically just
converted the
triangles from VTK to CGAL and stored them in an
std::vector<K::Triangle_3> which would likely work just as
fast and 100%
correctly. Do you think this is correct?
Thank you,
Rostislav.
On 22/09/2014 14:50, Sebastien Loriot (GeometryFactory) wrote:
On 09/18/2014 08:08 PM, Khlebnikov,
Rostislav wrote:
Please let me know if a minimal code
with data would help - I'd be
happy to send it.
Yes please.
Sebastien.
Rostislav.
On 18 Sep 2014, at 18:25, "Rostislav
Khlebnikov"
<> wrote:
Hello,
I have some very weird behavior of the same code on
different
platforms and for different build types.
So basically the code works fine only on one configuration
out of
four for me. It is Release version on Windows (Windows,
MSVS 2013,
x64, CGAL 4.4 installed with the CGAL-4.4-Setup.exe
installer and
then built with CMake and MSVS 2013).
The Debug version always returns zero intersections. The
code and
the data are literally the same.
I have also tried to build the Linux version. I used
Ubuntu 13.10
x64, gcc 4.8.1, libgmp and libmpfr installed using
apt-get, and CGAL
4.4 compiled from source using CMake. The only flag I
changed when
building CGAL and my test application is adding
-std=c++11 - i.e.
they are compiled with -frounding-math.
Here, none of the versions actually work. The Debug
version reports
incorrect (I mean not even close to the windows ones)
results or
crashes with segfault, and the Release version hangs on
building the
AABB tree if I use my custom iterator or crashes with
segfault is I
use a simple std::list of triangles.
Do you have any hints why this might happen?
Thank you for your help,
Rostislav.
On 10/08/2014 15:24, Rostislav
Khlebnikov wrote:
Hello Sebastien,
yes, indeed - it is the tree.build() call that makes
everything
logical.
Honestly, I just should RTFM better - I thought that
accelerate_distance_queries() call was responsible for
this, which
does no good for intersections anyway and just eats more
memory for
KD tree.
So, I reverted to the iterator which returns triangles
by value
constructing them on-the-fly and set the CGAL::Tag_true
as the last
template parameter for primitive.
The test results with are mixed (Isect shows the average
over 100
all_intersections() calls, timed with
QueryPerformanceCounter):
NO CACHE:
Build tree: 8.97505s
nConversions: 82950772
Isect: 2.97875ms
CGAL CACHE:
Build tree: 8.69819s
nConversions: 72620628
Isect: 1.97289ms
WITHIN-ITERATOR CACHE:
Build tree: 0.647395s
nConversions: 568938
Isect: 1.81151ms
Hope this helps,
Rostislav.
On 10/08/2014 14:39, Sebastien
On 08/09/2014 05:59 PM,
Hello again,
I am just quite curious that the first call to the
all_intersections is
very very slow compared to the rest. For example for
mesh with about
500k triangles, the first call takes about 10
seconds, while the
all the
following ones with the same cutting query take
about 3
milliseconds,
giving the difference of 3000 times! Is there some
lazy
processing going
on that are triggered by the first call? Is this
normal anyway?
Try to call tree.build() before, it is probably the
construction
of the
tree that is happening at the first call.
Sebastien.
Additionally, by adding the
cached converted triangle as a member of
Triangles_const_iterator, setting the reference
template
parameter to
default and returning K::Triangle_3 const& from
derefence() will
speed
up the first 10 times (down to 1 second) and also
speed up the
subsequent calls to about 2 milliseconds. It is
clear why this
happens,
but I just wanted to mention it.
Note that the last template parameter of
AABB_triangle_primitive
can be
used to cache the triangle in the primitive. Could you
give it a try
and confirm it is as fast as your setting?
Thanks,
Sebastien.
So, if you could answer the
questions in the first paragraph - that
would be absolutely great!
Thank you,
Rostislav.
On 08/08/2014 00:30,
Hello Sebastien,
yes, indeed changing the signature of the
Triangles_const_iterator to
class Triangles_const_iterator
: public boost::iterator_facade<
, K::Triangle_3 const // Value
, boost::forward_traversal_tag //
CategoryOrTraversal
, *K::Triangle_3*
helped resolving the issue. Just writing this to
say thanks to
you and
perhaps help anyone looking into similar problem.
Thanks again,
Rostislav.
PS: still weird that it worked in release :)
On 07/08/2014 23:33,
Thanks for the minimal reproducible example!
Actually, if you read again the doc of
you'll see you're using the default for
reference, which is
value&. In your case, reference should be
value (Triangle is a
temporary).
Sebastien.
On 08/07/2014 11:14 PM,
Hi everyone,
I'm using AABB_tree to compute intersections
of a VTK poly
data with a
plane. When I just convert the triangles from
VTK to CGAL and
store
them
in std list, everything works fine. However, I
would like to
reduce
storage requirements by creating a triangle
iterator that
iterates over
the VTK triangle data.
Code in main.cpp here shows how I do it
http://pastebin.com/kNLQevXV
<http://pastebin.com/sKPFHTT2>
In Release version everything works fine, but
in Debug version -
intersections are never found! (Funnily enough
it's a debug
version
that
fails). I tried finding the problem - but I
don't seem to
understand
it.
What I found is that when CGAL uses the kernel
to convert from
Triangle_3 to TriangleC3 with rep() and then
uses this
TriangleC3's
vertex() method on line 1909 in
function_objects.h, the
TriangleC3
'base' variable becomes corrupted during
get(base) call at
line 94 in
Triangle_3.h (i.e. correct coordinates are
overwritten in what
seems to
be stack initialization in function call when
I looked at
disassembly).
Is it something wrong that I do with my custom
iterator? Or
perhaps
it's
a bug in VS2013 compiler (I saw some bug
reports regarding stack
corruption for VS2012 such as this
<http://stackoverflow.com/questions/11000798/structure-parameter-corrupted-on-function-call>,
so perhaps it's not completely resolved).
I attached all the code, input files and cmake
file, so if
someone who
has VTK and CGAL could quitckly test it on
their platform. For
me the
release version returns 54 intersections and
debug - 0.
Thank you in advance,
Rostislav.
CGAL installation info:
Windows 8.1, MSVS 2013, x64
installer and then
built
with CMake and MSVS 2013.
