cgal-discuss - Re: [cgal-discuss] Adding data to Delaunay_d::Point_d
  • To:
  • Subject: Re: [cgal-discuss] Adding data to Delaunay_d::Point_d
  • Date: Mon, 27 Oct 2014 02:14:10 -0700
Thanks Sebastien,
Since I am looking for the most accurate possible triangulations, and
calculations that don’t crash or compute incorrect results (after, possibly,
months of runtime), should I use Homogenous_d?
Is mpz_class an appropriate substitute for leda_integer under these
conditions, or should I go obtain LEDA?
I also looked at using the Epick_d kernel, but it does not appear to be
present in CGAL 4.4.
Adam Getchell
about.me/adamgetchell
> On Oct 23, 2014, at 5:03 AM, Sebastien Loriot (GeometryFactory)
> wrote:
> On 10/23/2014 09:28 AM, Adam Getchell wrote:
>> Hello all,
>> Is there an equivalent of CGAL::Triangulation_vertex_base_with_info_3 for
>> Delaunay_d?
>> From looking over the documentation, it appears that unlike
>> Delaunay_triangulation_3 which is built on a Triangulation_vertex_base_3,
>> Delaunay_d seems to be built on the Convex_hull_d?
>> Where would be the best place to insert such data? I have, for example,
>> written a Delaunay : public Delaunay_d which includes member functions
>> such as number_of_cells() which are available in Delaunay_triangulation_3
>> but not implemented in Delaunay_d.
>> Suggestions most appreciated.
>> Adam Getchell
> I just looked at the code and there is no elegant way to do it
> (using a template parameter).
> What you could try is create a traits class inheriting from the
> recommended one and it might be sufficient to define a new Point_d
> class with your info inheriting from traits::Point_d.
> Just a guess I haven't try whether it works.
> Sebastien.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
