cgal-discuss - Re: [cgal-discuss] Building CGAL 4.5 with EIGEN3
  • To:
  • Subject: Re: [cgal-discuss] Building CGAL 4.5 with EIGEN3
  • Date: Tue, 28 Oct 2014 16:35:58 +0100
On 10/28/2014 08:21 AM, Sebastien Loriot (GeometryFactory) wrote:
On 10/28/2014 07:22 AM, Adam Getchell wrote:
Hello all,
I also went back and looked at the Homebrew formula for CGAL 4.4,
which works fine installing Eigen, and tried (which produced the same
error):
Note that you don't need Eigen when compiling the CGAL library.
When compiling your example your cmake script should look something like
the one attached.
The file I meant is the one attached.
sorry,
Sebastien.
Sebastien.
[adam][Hapkido][~/CGAL-4.5/build]
└─▪ cmake -DCMAKE_BUILD_TYPE=Release -DWITH_Eigen3=ON ..
-- The CXX compiler identification is AppleClang 6.0.0.6000054
-- The C compiler identification is AppleClang 6.0.0.6000054
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
== Setting paths ==
-- Build CGAL from release in directory CGAL-4.5
-- Packagenames: CGAL-4.5
== Setting paths (DONE) ==
== Generate version files ==
-- CGAL_MAJOR_VERSION=4
-- CGAL_MINOR_VERSION=5
-- CGAL_BUGFIX_VERSION=0
-- CGAL_SONAME_VERSION=10
-- CGAL_SOVERSION =10.0.4
-- CGAL_REFERENCE_CACHE_DIR=
-- Building shared libraries
-- Targetting Unix Makefiles
-- Using /usr/bin/c++ compiler.
-- DARWIN_VERSION=14
-- Mac Leopard detected
-- USING CMake version: 3.0.2
-- System: Darwin
== Generate version files (DONE) ==
== Set up flags ==
-- Build type: Release
-- USING CXXFLAGS = ' -O3 -DNDEBUG'
-- USING LDFLAGS = ' '
== Set up flags (DONE) ==
== Detect external libraries ==
-- External libraries supported:
GMP;GMPXX;MPFR;ZLIB;OpenGL;LEDA;MPFI;RS;RS3;OpenNL;Eigen3;BLAS;LAPACK;QGLViewer;ESBTL;Coin3D;NTL;IPE
-- Preconfiguring library: GMP ...
-- Found GMP: /usr/local/lib/libgmp.dylib
-- GMP has been preconfigured:
-- UseGMP-file:
-- GMP include: /usr/local/include
-- GMP libraries: /usr/local/lib/libgmp.dylib
-- GMP definitions:
-- USING GMP_VERSION = '6.0.0'
-- Preconfiguring library: MPFR ...
-- Found MPFR: /usr/local/lib/libmpfr.dylib
-- MPFR has been preconfigured:
-- UseMPFR-file:
-- MPFR include: /usr/local/include
-- MPFR libraries: /usr/local/lib/libmpfr.dylib
-- MPFR definitions:
-- USING MPFR_VERSION = '3.1.2'
-- Preconfiguring library: Eigen3 ...
-- Found Eigen3: /usr/local/include/eigen3 (found suitable version
"3.2.2", minimum required is "3.1.0")
-- Eigen3 has been preconfigured:
-- UseEigen3-file: UseEigen3
-- Eigen3 include: /usr/local/include/eigen3
-- Eigen3 libraries:
-- Eigen3 definitions:
-- Boost version: 1.56.0
-- Found the following Boost libraries:
-- thread
-- system
-- Boost include: /usr/local/include
-- Boost libraries:
/usr/local/lib/libboost_thread-mt.dylib;/usr/local/lib/libboost_system-mt.dylib
-- Boost definitions:
-- USING BOOST_VERSION = '1.56.0'
== Detect external libraries (DONE) ==
== Write compiler_config.h ==
-- Performing Test CGAL_CFG_BOOST_VARIANT_SWAP_BUG - Success
-- Performing Test CGAL_CFG_DENORMALS_COMPILE_BUG - Success
-- Performing Test CGAL_CFG_FPU_ROUNDING_MODE_UNWINDING_VC_BUG - Success
-- Performing Test CGAL_CFG_IEEE_754_BUG - Success
-- Performing Test CGAL_CFG_ISTREAM_INT_BUG - Success
-- Performing Test CGAL_CFG_MATCHING_BUG_5 - Success
-- Performing Test CGAL_CFG_MATCHING_BUG_6 - Success
-- Performing Test CGAL_CFG_MATCHING_BUG_7 - Success
-- Performing Test CGAL_CFG_MATCHING_BUG_8 - Success
-- Performing Test CGAL_CFG_NESTED_CLASS_FRIEND_DECLARATION_BUG - Failed
-- Performing Test CGAL_CFG_NO_LIMITS - Success
-- Performing Test CGAL_CFG_NO_NEXTAFTER - Success
-- Performing Test CGAL_CFG_NO_STL - Success
-- Performing Test CGAL_CFG_NO_WARNING_CPP_DIRECTIVE_BUG - Success
-- Performing Test CGAL_CFG_NUMERIC_LIMITS_BUG - Success
-- Performing Test CGAL_CFG_OUTOFLINE_MEMBER_DEFINITION_BUG - Success
-- Performing Test CGAL_CFG_TEMPLATE_IN_DEFAULT_PARAMETER_BUG - Success
-- Performing Test CGAL_CFG_TYPENAME_BEFORE_DEFAULT_ARGUMENT_BUG -
Success
-- Performing Test CGAL_CFG_USING_BASE_MEMBER_BUG_2 - Success
== Write compiler_config.h (DONE) ==
== Generating build files ==
Configuring libCGAL
-- Requested component: MPFR
-- Requested component: GMP
libCGAL is configured
-- Sources for CGAL component library 'CGAL_Core' detected
Configuring libCGAL_Core
libCGAL_Core is configured
-- Sources for CGAL component library 'CGAL_ImageIO' detected
Configuring libCGAL_ImageIO
-- Found OpenGL: /System/Library/Frameworks/OpenGL.framework
-- Found ZLIB: /usr/lib/libz.dylib (found version "1.2.5")
-- OpenGL include: /System/Library/Frameworks/OpenGL.framework
-- OpenGL libraries:
/System/Library/Frameworks/AGL.framework;/System/Library/Frameworks/OpenGL.framework
-- USING ZLIB_VERSION = '1.2.5'
libCGAL_ImageIO is configured
-- Sources for CGAL component library 'CGAL_Qt3' detected
Configuring libCGAL_Qt3
-- libCGAL_Qt3 needs Qt3, cannot be configured.
-- Sources for CGAL component library 'CGAL_Qt4' detected
Configuring libCGAL_Qt4
-- Looking for Q_WS_X11
-- Looking for Q_WS_X11 - not found
-- Looking for Q_WS_WIN
-- Looking for Q_WS_WIN - not found
-- Looking for Q_WS_QWS
-- Looking for Q_WS_QWS - not found
-- Looking for Q_WS_MAC
-- Looking for Q_WS_MAC - found
-- Looking for QT_MAC_USE_COCOA
-- Looking for QT_MAC_USE_COCOA - found
-- USING OPENGL_VERSION = '2.1'
-- USING QT4_VERSION = '4.8.6'
-- OpenGL definitions:
-- Qt4 include:
/usr/local/Cellar/qt/4.8.6/include;/usr/local/Cellar/qt/4.8.6/lib/QtCore.framework
-- Qt4 libraries:
/usr/local/Cellar/qt/4.8.6/lib/QtOpenGL.framework;/usr/local/Cellar/qt/4.8.6/lib/QtGui.framework;/usr/local/Cellar/qt/4.8.6/lib/QtCore.framework
-- Qt4 definitions:
-- moc executable: /usr/local/Cellar/qt/4.8.6/bin/moc
-- uic executable: /usr/local/Cellar/qt/4.8.6/bin/uic
libCGAL_Qt4 is configured
-- Sources for CGAL component libraries
'CGAL_Core;CGAL_ImageIO;CGAL_Qt3;CGAL_Qt4' detected
== Generating build files (DONE) ==
-- Configuring done
-- Generating done
-- Build files have been written to: /Users/adam/CGAL-4.5/build
Adam Getchell
about.me/adamgetchell
On Oct 27, 2014, at 9:59 PM, Adam Getchell
wrote:
Okay, never mind. I manually installed CGAL 4.5, which gives me the
Epick_d.h kernel.
Now I have the usual problem associated with installing CGAL with
Eigen. I manually specified the EIGEN3_INCLUDE_DIR, but it was ignored:
┌─[adam][Hapkido][~/CGAL-4.5]
└─▪ cd /usr/local/include/eigen3
┌─[adam][Hapkido][±][master ✓][/usr/local/include/eigen3]
└─▪ ll
total 8
drwxr-xr-x 5 adam admin 170 Oct 16 17:03 .
drwxr-xr-x 3 adam admin 102 Oct 16 15:57 ..
drwxr-xr-x 35 adam admin 1190 Oct 16 17:13 Eigen
-rw-r--r-- 1 adam admin 216 Aug 4 03:51
signature_of_eigen3_matrix_library
drwxr-xr-x 3 adam admin 102 Oct 16 15:58 unsupported
└─▪ cd ~/CGAL-4.5
└─▪ mkdir build
└─▪ cd build
┌─[adam][Hapkido][~/CGAL-4.5/build]
└─▪ cmake -DEIGEN3_INCLUDE_DIR=/usr/local/include/eigen3 ..
== Setting paths ==
-- System: Darwin
== Set up flags ==
-- UseGMP-file:
-- GMP definitions:
-- UseMPFR-file:
-- thread
-- system
-- Boost libraries:
Success
Configuring libCGAL
-- Qt4 include:
-- Qt4 libraries:
-- Qt4 definitions:
-- Configuring done
-- Generating done
CMake Warning:
Manually-specified variables were not used by the project:
EIGEN3_INCLUDE_DIR
Doing ‘make’ and ‘make install’ and then compiling my program yields:
<elided>
Scanning dependencies of target unittests
[ 28%] Building CXX object CMakeFiles/unittests.dir/unittests/main.cpp.o
[ 42%] Building CXX object
CMakeFiles/unittests.dir/unittests/PointTest.cpp.o
In file included from
/Users/adam/CDT-plusplus/unittests/PointTest.cpp:2:
In file included from /Users/adam/CDT-plusplus/src/Point.h:4:
In file included from /usr/local/include/CGAL/Epick_d.h:22:
/usr/local/include/CGAL/NewKernel_d/Cartesian_base.h:24:
/usr/local/include/CGAL/NewKernel_d/Cartesian_complete.h:23:
/usr/local/include/CGAL/NewKernel_d/function_objects_cartesian.h:309:31:
error:
no member named 'NoChange' in namespace 'Eigen'
m.conservativeResize(Eigen::NoChange, n);
/usr/local/include/CGAL/NewKernel_d/Cartesian_base.h:25:
/usr/local/include/CGAL/NewKernel_d/Cartesian_LA_base.h:38:2: error:
Eigen3 is
required
#error Eigen3 is required
/usr/local/include/CGAL/NewKernel_d/Cartesian_LA_base.h:39:10: fatal
error:
'CGAL/NewKernel_d/LA_default/LA.h' file not found
#include <CGAL/NewKernel_d/LA_default/LA.h>
Adam Getchell
On Oct 27, 2014, at 8:22 PM, Adam Getchell
wrote:
Sebastien,
Thank you for the advice. I’m missing something. This:
#ifndef CDT_POINT_H
#define CDT_POINT_H
#include <CGAL/Lazy_exact_nt.h>
#include <CGAL/Gmpq.h>
#include <CGAL/Kernel_d/Point_d.h>
#include <CGAL/Cartesian.h>
typedef CGAL::Lazy_exact_nt<CGAL::Gmpq> > NT;
typedef CGAL::Cartesian<NT> Kernel;
CGAL::Point_d<Kernel> Point_d;
class Point : public Point_d
public:
Point() : Point_d()
#endif // CDT_POINT_H
Produces:
┌─[adam][Hapkido][±][master ✗][~/CDT-plusplus]
└─▪ ./build.sh
-- USING EXEFLAGS = '
-Wl,-dylib_file,/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib:/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
-- Requested component: Core
-- Configuring done
-- Generating done
-- Build files have been written to: /Users/adam/CDT-plusplus/build
Scanning dependencies of target cdt
[ 14%] Building CXX object CMakeFiles/cdt.dir/src/cdt.cpp.o
Linking CXX executable cdt
[ 14%] Built target cdt
/Users/adam/CDT-plusplus/src/Point.h:9:41: error: expected
unqualified-id
/Users/adam/CDT-plusplus/src/Point.h:10:25: error: use of undeclared
identifier
'NT'
In file included from /Users/adam/CDT-plusplus/src/Point.h:6:
/usr/local/Cellar/cgal/4.4/include/CGAL/Kernel_d/Point_d.h:42:24:
error: type
'int' cannot be used prior to '::' because it has no members
class Point_d : public pR::Point_d_base
plus more errors as detailed here:
https://gist.github.com/acgetchell/6a31617bfd6839203553
Adam Getchell
On Oct 27, 2014, at 2:21 AM, Sebastien Loriot (GeometryFactory)
wrote:
On 10/27/2014 10:14 AM, Adam Getchell wrote:
Thanks Sebastien,
Since I am looking for the most accurate possible triangulations,
and calculations that don’t crash or compute incorrect results
(after, possibly, months of runtime), should I use Homogenous_d?
Is mpz_class an appropriate substitute for leda_integer under
these conditions, or should I go obtain LEDA?
I also looked at using the Epick_d kernel, but it does not appear
to be present in CGAL 4.4.
Epick_d is the one you should use. Robust and fast.
If you can't you can try using
CGAL::Cartesian_d<CGAL::Lazy_exact_nt<CGAL::Gmpq> >
Sebastien.
Adam Getchell
On Oct 23, 2014, at 5:03 AM, Sebastien Loriot (GeometryFactory)
wrote:
On 10/23/2014 09:28 AM, Adam Getchell wrote:
Hello all,
Is there an equivalent of
CGAL::Triangulation_vertex_base_with_info_3 for Delaunay_d?
From looking over the documentation, it appears that unlike
Delaunay_triangulation_3 which is built on a
Triangulation_vertex_base_3, Delaunay_d seems to be built on the
Convex_hull_d?
Where would be the best place to insert such data? I have, for
example, written a Delaunay : public Delaunay_d which includes
member functions such as number_of_cells() which are available
in Delaunay_triangulation_3 but not implemented in Delaunay_d.
Suggestions most appreciated.
Adam Getchell
I just looked at the code and there is no elegant way to do it
(using a template parameter).
What you could try is create a traits class inheriting from the
recommended one and it might be sufficient to define a new Point_d
class with your info inheriting from traits::Point_d.
Just a guess I haven't try whether it works.
Sebastien.
# Created by the script cgal_create_cmake_script
# This is the CMake script for compiling a CGAL application.
# Then modified by hand to add Eigen3.
project( NewKernel_d_test )
cmake_minimum_required(VERSION 2.6.2)
if("${CMAKE_MAJOR_VERSION}.${CMAKE_MINOR_VERSION}" VERSION_GREATER 2.6)
if("${CMAKE_MAJOR_VERSION}.${CMAKE_MINOR_VERSION}.${CMAKE_PATCH_VERSION}"
VERSION_GREATER 2.8.3)
cmake_policy(VERSION 2.8.4)
else()
cmake_policy(VERSION 2.6)
endif()
endif()
find_package(CGAL QUIET)
if ( CGAL_FOUND )
include( ${CGAL_USE_FILE} )
include( CGAL_CreateSingleSourceCGALProgram )
find_package(Eigen3)
if (EIGEN3_FOUND)
include( ${EIGEN3_USE_FILE} )
include_directories (BEFORE "../../include")
create_single_source_cgal_program( "Epick_d.cpp" )
else()
message(STATUS "NOTICE: This program requires the Eigen3 library, and
will not be compiled.")
endif()
else()
message(STATUS "NOTICE: This program requires the CGAL library, and will
not be compiled.")
endif()
