- To:
- Subject: Re: [cgal-discuss] Adding data to Delaunay_d::Point_d
- Date: Mon, 27 Oct 2014 10:21:08 +0100
On 10/27/2014 10:14 AM, Adam Getchell wrote:
Thanks Sebastien,
Since I am looking for the most accurate possible triangulations, and
calculations that don’t crash or compute incorrect results (after, possibly,
months of runtime), should I use Homogenous_d?
Is mpz_class an appropriate substitute for leda_integer under these
conditions, or should I go obtain LEDA?
I also looked at using the Epick_d kernel, but it does not appear to be
present in CGAL 4.4.
Epick_d is the one you should use. Robust and fast.
If you can't you can try using CGAL::Cartesian_d<CGAL::Lazy_exact_nt<CGAL::Gmpq> >
Sebastien.
Adam Getchell
about.me/adamgetchell
On Oct 23, 2014, at 5:03 AM, Sebastien Loriot (GeometryFactory)
wrote:
On 10/23/2014 09:28 AM, Adam Getchell wrote:
Hello all,I just looked at the code and there is no elegant way to do it
Is there an equivalent of CGAL::Triangulation_vertex_base_with_info_3 for
Delaunay_d?
From looking over the documentation, it appears that unlike
Delaunay_triangulation_3 which is built on a Triangulation_vertex_base_3,
Delaunay_d seems to be built on the Convex_hull_d?
Where would be the best place to insert such data? I have, for example,
written a Delaunay : public Delaunay_d which includes member functions such
as number_of_cells() which are available in Delaunay_triangulation_3 but not
implemented in Delaunay_d.
Suggestions most appreciated.
Adam Getchell
(using a template parameter).
What you could try is create a traits class inheriting from the
recommended one and it might be sufficient to define a new Point_d
class with your info inheriting from traits::Point_d.
Just a guess I haven't try whether it works.
Sebastien.
- [cgal-discuss] Adding data to Delaunay_d::Point_d, Adam Getchell, 10/23/2014
- Re: [cgal-discuss] Adding data to Delaunay_d::Point_d, Sebastien Loriot (GeometryFactory), 10/23/2014
- Re: [cgal-discuss] Adding data to Delaunay_d::Point_d, Adam Getchell, 10/27/2014
- Re: [cgal-discuss] Adding data to Delaunay_d::Point_d, Sebastien Loriot (GeometryFactory), 10/27/2014
- Re: [cgal-discuss] Adding data to Delaunay_d::Point_d, Adam Getchell, 10/28/2014
- Re: [cgal-discuss] Building CGAL 4.5 with EIGEN3, Adam Getchell, 10/28/2014
- Re: [cgal-discuss] Building CGAL 4.5 with EIGEN3, Sebastien Loriot (GeometryFactory), 10/28/2014
- Re: [cgal-discuss] Adding data to Delaunay_d::Point_d, Marc Glisse, 10/28/2014
