[cgal-discuss] Bug in halfspaces_intersection.h - or - How to efficiently compute intersection of half-planes (continued)
- To:
- Cc: , Evan Behar <>, Olivier Devillers <>
- Subject: [cgal-discuss] Bug in halfspaces_intersection.h - or - How to efficiently compute intersection of half-planes (continued)
- Date: Wed, 29 Oct 2014 20:35:55 +0300
- Envelope-from:
Hi Quentin,
I'm using file halfspaces_intersection.h that was published by you here:
http://cgal-discuss.949826.n4.nabble.com/How-to-efficiently-compute-intersection-of-half-planes-td4657312.html
It seems to me that there is a bug in it. There is a function that constructs
duals of given planes, constructs a convex hull, and then maps polyhedron
them back to primal space.
Inside the dual polyhedron construction there is the following code:
> typename CGAL::Polyhedron_incremental_builder_3<HDS> B( hds, true);
> B.begin_surface(_primal.size_of_facets(),
> _primal.size_of_vertices(),
> _primal.size_of_vertices());
When I try to run function halfspaces_intersection in my project the
following error occurs:
> CGAL::Polyhedron_incremental_builder_3<HDS>::
> lookup_halfedge(): capacity error: more than 490 halfedges added while
> creating facet39.
So I suggest to change it as follows:
> _primal.size_of_halfedges());
After this change the function begins to work.
I have tried to find whether anybody else use this function, but have found
only this repo at GitHub:
https://github.com/mrgt/voronoi_covariance
The author of it is Quentin.
To all:
Is there any official way of fast and efficient computation of halfspaces
intersections? Was it added to CGAL release?
Best regards,
Ilya Palachev
- [cgal-discuss] Bug in halfspaces_intersection.h - or - How to efficiently compute intersection of half-planes (continued), Илья Палачев, 10/29/2014
